coil over cross member with NEW spline sway bar
Here it is guys... let us know what you think
Happy to be here
![]() Join Date: Mar 2000
Re: coil over cross member with NEW spline sway bar
Thats some sexy pics your posting there.
Thanks Ken!
Nice work guys!!! Turning it up a notch huh?
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
#5 | |
1.We will have our bolt-in rear 4-bar for c-10 with a rear step notch coming shortly. 2.We have more stuff coming but cannot tell you guys what it is yet.lol Justin |
what kind of technical specs does this kit produce? camber curve, bumpsteer, scrub radius, roll center, etc.?
I'll buy that for a Dollar! |
Specs will be posted soon today or wed.
Thankyou, Justin Last edited by Scottshotrods; 02-08-2011 at 01:27 PM. Reason: added |
Here are some specs of our bolt in coil-over ifs for c-10 trucks.Keep in mind that are airbag version is differnt on the specs.This will also change on your tire dia as well.General specs and keep in mind all of our frontends are differnt in many ways.
1.The track we build these to is 62 1/2 2.Camber curve 1.750 this is at ride height to full compresed total suspension gets 6 inches of travel. 3.Bump steer 2 -2 1/2 degrees through travel of suspension 4.Scrub radius 2 1/16 at ride height 5.Roll center changes 1 13/16 this was all tested on a 28' tall tire. Last edited by Scottshotrods; 02-08-2011 at 04:07 PM. Reason: added |
#9 | |
couple more questions what is the caster? and what height of roll center does kit get? does steering toe in or out during bumpsteer? TIA
Cool... Sprint Car Inspired Sway bar. Have you done any load testing on the arms? Are you concerned about them bending or twisting axially under load due to the bend?
#11 | |
To add to the sway-bar post here.Speedway eng has been making sway-bars for over
35 years and they have been proven over and over by many race teams and many and I would say all Companies who sell a spline bar by them from Speedway and the arms that are in question are made out of 3/4 thick 4130 steel cnc machined precision broached and timed.Hopefully this helps |
So are you saying the arms on your set-up are heat treated steel arms like those used on the cup cars?
Only reason I ask is the bend bend lines on the arms in the photos you posted above don't look like heat treated steel based on the steel displacement at the bends? (Arms shown below are from Speedway International) Thanks, John |
#14 | |
and increased to just 1 3/4 degrees of caster at full compression. Roll center was tested at ride height to full compressed Toe goes out not in during bump steer |
#15 | |
I would say it will take alot of force to break these arms and I will say there are not to many trucks or cars that really take the abuse of the race car that is used for racing only. |
#16 |
looks great, and look forward to seeing what all you guys are going to offer..really top notch guys
![]() the only 'improvement' id do, is round the corners of the sway bar arms, at the links to the control arm..that make sence? |
#17 |
The Speedway Engineering catalog states “bend them yourself and have them heat-treated locally”. Do you heat treat them after bending them?
With the drastic bends you show in the photos above I would be concerned with the arms bending or rolling over during loading, not breaking. From an engineering perspective, wouldn’t the fact that our trucks are considerably heavier than a cup car, and the roads we drive on have defects, speed bumps – pot holes - etc. (they aren’t “speedway smooth”), mean that our street truck applications for a sway bar would be much more severe? Thanks, John |
#18 |
Good idea and we discussed this the other day on rounding the ends will look even better.
#19 | |
#20 | |
to customers specs as well if somebody wants something differnt.For the handling on this frontend our customers who have this set up now our very happy with the ride quality.We are building a shop truck in the shop now that will be our truck to take out and abuse and we will have this at many shows this year where customers will be able to take it out and drive to see how it feels and handle.Maybe we will be able to meet up this year at a show we will give you the keys to go out and drive and you can be the judge on how it handles and then you can let us know.We are doing around 20 shows this years all around the country. |
#21 |
and the price is ?????
#22 |
#23 | |
60-66 Nut
I would have to agree with you on this John.
Myself being a fabricator, I am concerned that those arms would fail at those bend points. The material is severely displaced at the one brake line. This has drastically stretched the metal beyond it's acceptable limits. To form .750, A36 mild steel a 8" vee die and a punch with a 1.312" radius is the correct tooling. It appears that this tooling was not used. I'm not just trying to bust your balls Scotts Hotrods, but I feel a responsibility to point out as what I see as a failure point on that sway bar arm. I would hate to see you end up in trouble over something like that on an otherwise nice front suspension. Quote:
#24 | |
Justin |
#25 |
here are pictures of the production arms as you can see we do heat treat them
![]() ![]() ![]() ![]() ![]() ![]() [IMG] |
