02-08-2011, 08:22 PM | #1 |
vw guy & now c-10 guy
250 6 cyl. monojet choke setup- can somebody show me some pics?
Ive be running my truck with a spring holding the throttle plate- I have a manual choke cable but I dont have the linkage for the carb- can I get some pics to see what I need to find and/or make? thanks guys!!!
02-08-2011, 11:21 PM | #2 |
Re: 250 6 cyl. monojet choke setup- can somebody show me some pics?
anybody? just love to see some pics of the parts i'm missing
02-08-2011, 11:28 PM | #3 |
here's mine ('72 if it makes a difference) (pre rebuild)
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
02-08-2011, 11:52 PM | #4 |
mine doesn't have any of the stuff on the front of yours- no choke pull-off and no choke thermostat or rod. but I have a brand new choke cable if I can figure out how to mount it and make it operate. thanks for the pic! I'm open to either way, I just want it to work!
02-09-2011, 12:00 AM | #5 |
aaahhhh they are over rated! hahahahhaah I still have to stay with mine for about 2 minutes before I can leave it to settle out on it's own. I recently rebuilt the carb but can't find the pics. If I do, I'll add some more pics.
found it: http://67-72chevytrucks.com/vboard/s...d.php?t=439692
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! Last edited by Luvlegs; 02-09-2011 at 12:06 AM. |
02-09-2011, 10:44 AM | #6 |
There were several different choke configurations used through the early years of these carbs. Most of them didn't work right from day one. Often the carb or manifold has been changed & do not match. Often parts are missing off the carb. The best one to use is the electric choke model from the early 80's. It is self contained. Or a manual choke model is good. It is hard to convert to a cable control.
02-09-2011, 11:11 AM | #7 | |
Active Member
When you say you have a "manual choke and don't have the linkage to the carb" do you need to know how the choke cable attaches to the carb or the throttle linkage to the carb? |
02-09-2011, 11:38 AM | #8 | |
Active Member
Here's some pics of mine: Well, I thought I was going to be able to send pics, but it's not letting me upload them. I'll try to figure out what's wrong and post pics later. |
02-09-2011, 12:44 PM | #9 |
Active Member
Let me know if you need some more pics.
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] Last edited by 68gmsee; 02-09-2011 at 12:45 PM. |
02-09-2011, 03:11 PM | #10 |
thanks guys! that should help me out a lot
02-09-2011, 03:26 PM | #11 |
a few pics from my 68......................
02-09-2011, 07:11 PM | #12 |
ok, sorry to make this thread so long... I'm sure this is really simple to lots of you, but this is my first chevy- up til I started building this 68, it was 20 straight years of VWs for me
Here's some pics, not the best, but pics nonetheless: |
02-10-2011, 11:57 AM | #13 |
that is a work of art stepside fan. very nice!
02-10-2011, 06:06 PM | #14 |
Thankyou..............
