Old 02-15-2011, 12:05 AM   #26
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: Got some work done
Heres a little better pic.just trying to help.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 02-15-2011, 12:07 AM   #27
CHIZZLER
CHIZZLER's Avatar
I agree with ratty.lengthen the lowers.shorten the uppers.easily fixed.
61-crew cab D-max
Old 02-15-2011, 01:14 AM   #28
cajundragger
you need to measure it before you do anything.
with the truck level the engine and trans should be at 3 degrees leaning back. dont measure from where the carb mounts because that is angled up approx 3 degrees to offset this.
and the rear end should point up 3 degrees at ride height.
cajundragger is offline   Reply With Quote
Old 02-15-2011, 06:27 AM   #29
BC Toy chest
BC Toy chest's Avatar
Looks good nice truck, like the way she just lays there, very kool.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 02-15-2011, 09:46 PM   #30
Kid
Kid's Avatar
stance is looking really good. Looking fwd to a build thread showing progress. cajungragger is on track. Simply put, get your engine / trans installed, then with truck at ride height (very important), measure & match your pinion angle to your trans out put shaft angle. (example: if trans out put shaft angle is 2 degrees down, then make your pinion angle 2 degrees up) this will insure no drive line vibrations due to U-joint harmonics
Kid is offline   Reply With Quote
Old 02-15-2011, 09:55 PM   #31
Laid_Out_50
Laid_Out_50's Avatar
I went and checked the bars on the 4 link and they are adjustable top and bottom
Laid_Out_50 is offline   Reply With Quote
Old 02-15-2011, 11:07 PM   #32
chevytroy
quick question what rearend are you running? what lenght wheel mounting plate to whell mounting plate? and are you running wheel adapters to mount the dodge wheels? thank you
chevytroy is offline   Reply With Quote
Old 02-15-2011, 11:15 PM   #33
Laid_Out_50
Im running a Ford 8.8 out of an Explorer. I am running wheel adaptors
