"Junkyard Dog"
![]() Join Date: Jan 2008
50 plus misc parts for sale
Misc parts from a 1969 GMC C20 and 1972 GMC C20. All prices include shipping unless otherwise stated. Shipping minimum is 5.00 as the cheapest shipment is in a flat rate usps box @ 4.95. Combined shipping no problem. All parts are cleaned.
2 TH350 - 350 vac modulator line. 18.00 SOLD TH400 - 350 vac modulator line. 18.00 350 fan spacer one off 69 and other 72 (different lengths) 10.00 each TH350 dipstick and tube. 22.50 71-72 gas pedal assy complete. 30.00 67-70 gas pedal assy complete. 22.50 Custom Camper emblems. 25.00 SOLD Custom emblems. 15.00 Center tailgate molding not new but nice. 10.00 Steering column support loop and cover plate. 10.00 Cover plate at column rubber. 8.00 GMC 1500 V8 fender emblems. 25.00 GMC 2500 V8 fender emblems. 25.00 2 Amber marker lights good color. 10.00 each 15.00 pair SOLD 2 red marker lights. 10.00 each 15.00 pair SOLD RH 72 only inner door release mech. 12.50 LH 71-down inner door release mech. 12.50 RH 71-down inner door release mech. 12.50 2 sb oil lines with fittings. 10.00 ea. TH350 kick down cable. 17.50 TH350 cable bracket. 10.00 Steering shaft. 22.00 2 Speedo cables 2wd TH350 24.00 each Single groove sb crank pulley. 15.00 350 Vac advance line with support clip. 10.00 SOLD Clutch return spring original from 69. 10.00 2 Wiper arms. 12.50 each 20.00 pair SOLD E-brake support rod. 12.50 69-71 rear view mirror, glass in typical cond. 20.00 69 GMC owners manual 15.00 RH door latch dipped and glass beaded. 35.00 SOLD LH door latch dipped and glass beaded. 35.00 SOLD 2 cig lighters. 12.50 each one SOLD one left 2 wiper switches. 10.00 each 2 headlamp switches. 10.00 each 1972 C20 P/B booster w-prop. valve. 65.00 1969 C20 P/B booster w-prop. valve. 65.00 Rear sway bar off a 1972 GMC C20 with leaf springs. 50.00 plus shipping Front sway bar 67-72 2WD complete. 50.00 plus shipping Seat tracks off 1969. 40.00 dome lens and cover. 10.00 SOLD sb motor mount. 10.00 Steering columns: 1969 floor shift green, olive on the spid. 75.00 1970 AT tan, gold interior on the spid. 75.00 1972 AT green, olive on the spid. 75.00 Sold local
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw Last edited by tll74; 03-05-2011 at 02:55 AM. Reason: post sold on items |
Re: 50 plus misc parts for sale
I am interested in the rear sway bar, shipping to 28387?
Pm me, I tend to forget things........... Thanks, steve |
![]() Join Date: Jun 2006
i am interested in the th400 modulator line shipped to 49905
interested in both sway bars shipped to 28787?
VA72C10
![]() Join Date: Mar 2008
ttt for some good prices
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 02-21-2011 at 12:09 AM. |
"Junkyard Dog"
The prices include shipping unless otherwise stated. But, I'll except more.
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
![]() Join Date: Sep 2002
I would like the following:
2 TH350 - 350 vac modulator line. 18.00 dome lens and cover. 10.00 Please pm me payment info. Thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
"Junkyard Dog"
Shipping via UPS is 49.85. PM sent
"Junkyard Dog"
Shipping for both is 54.04
Lets give qksilver a bit to answer back on rear as he asked first. Thanks, Tom
Active Member
![]() Join Date: Dec 2004
Are the mounting pins intact on the custom camper emblems, and no pitting? If so, I'll take them.
"Junkyard Dog"
The vac mod line is suppose to be 18.00 each. I forgot to put that in. I will honor what the text say's if needed. PM sent
"Junkyard Dog"
No broken pins. Two of them are bent over a bit. That's how they were when I removed them. No pitting! If, you don't like them I take them back.
"Junkyard Dog"
qksilver is a pass for now. Your in 1st place. LMK
I'm interested in the cigarette lighters but I can't see them very well in your pic. I need one for my 69 Chev I'm not sure they are the same as GMC. Can you post a closeup ? Thank you.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
#15 |
Interested in the amber side markers. Could I get a better pic? Thanks.
#16 |
"Junkyard Dog"
Close up pics for all to come tomorrow.
#17 |
A guy with a truck
'69 booster assembly. If it is in working order, I'll take it. Need everything from the pedal out.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#18 |
Active Member
Ok, I'll take the custom camper embs.
#19 |
I will take the wipers if they are in nice shape.
#20 |
Words under my name
![]() Join Date: Nov 2010
If both sets of amber and red marker lights will fit on a 69 chevy fleetside, Ill take them, 98496...please.
and do you use paypal, let me know and add the paypal usage charge, if not, let me know the info, thanks!!
69 Chevy CST/10 "Project: Bloody Knuckles" ![]() 2010 VW Golf, daily driver Wrench Rookie Last edited by steelscout; 02-22-2011 at 10:42 AM. |
#21 |
"Junkyard Dog"
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw Last edited by tll74; 02-22-2011 at 11:10 PM. |
#22 | |
"Junkyard Dog"
PM sent. Thanks
#23 |
"Junkyard Dog"
ScottH....Pm sent
6t727t2....PM sent bollybib.....Problems getting pics up. These are not perfect but nice driver quality ls1nova71....steelscout posted "I'll take them" that puts him in first place but I have more I'll get them off and post pics. bigsnookmaster.....PM sent
#24 |
Payment sent for the wipers!
#25 | |
