MadMan
Found a 2002 Corvette LS1 for the Shortbox
I hit the jackpot.... I found a 2002 Corvette engine with the all aluminum block/engine combo. The block and heads are like 130lbs
![]() ![]() ![]() ![]() ![]() ![]() anyone rolling a 6speed in their C10???? I need input please
81" Shortbed C10 Full Restoration underway, who needs a budget?? LS Pro Touring Build Last edited by 81ShrtBox; 02-24-2011 at 09:19 AM. |
Slots go on anything!
Re: Found a 2002 Corvette LS1 for the Shortbox
I hate to burst your bubble, but a Corvette uses a transaxle. That will be tough to adapt, but a 4L60E or T56 are easy enough to find. Should be a cool project!
1974 Jimmy- 5.3/4L80e/NP241 |
Happy to be here
![]() Join Date: Mar 2000
Nice find, but how much? Finding them isn't hard, but finding them cheap can be.
MadMan
Whole deal will run roughly $700-$800
81" Shortbed C10 Full Restoration underway, who needs a budget?? LS Pro Touring Build |
What are your plans with the motor? keep it stock orrr??
Home Built '87
Going to be a cool project!!!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
Happy to be here
Ok, now your talking. Keep us posted so we can be envious.
Man I would have to resell that thing and buy a regular old 6.0, that is a cool engine though.
#9 | |
MadMan
The price is awesome. If it falls through check into the all aluminum LS2. It's about the same weight as the LS1 but has more cubes and better compression ratio with mo power.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
#11 | |
MadMan
![]() Posted via Mobile Device
My buddy has about 5500 into his ls1 in his firebird. HEads cam crank pistons intake exhaust. With the t56 and 12 bolt he made 505 hp and 503 ft lbs. he changed over to a th400 w/ a brake so the car will be more consistant and he wont have to keep replacing clutches. I dont know what your plans are for the ls1, but you can make a lot of power with them. Just doing an intake exhaust, heads, cam, and tune. you should make between 4-450 hp with that. Maybe refer to LS1 tech's website or performance trucks website. Just sayin.
Thats my .02 Last edited by JBRAVO383; 02-25-2011 at 01:46 PM. |
MadMan
I plan on swapping camshafts, new rings, new gaskets etc.. get it programed and ride. not looking to break any records. 400-450hp is fine...
I am adding single chamber race mufflers and headers...
Chevys Kick A$$
Damn that's a great find for that price. I think I would just scoop it up if I could but that's just me. Gonna to be one hella of sweet ride that's for sure
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
#15 |
MadMan
He's sending me pics today. From what I was told its a Z06. I will post pics when I get some. It has low mileage, the car was totalled in a roll over.
81" Shortbed C10 Full Restoration underway, who needs a budget?? LS Pro Touring Build Last edited by 81ShrtBox; 02-26-2011 at 07:14 AM. |
#16 |
![]() Join Date: Jul 2010
If it's a low miler ..leave tha rings alone..no need in cracking a good motor open//
#17 |
MadMan
I need to check out some Z06's with free flowing exhaust... if it sounds nice I wont even touch the cam.
#18 |
MadMan
Forgot to post that the engine ended up being a LS6 with the 6speed. I swapped the 6speed for a 4L65 from a wrecked GTO
![]() But... its on hold for a minute until my daily driver is back operational... ![]()
#19 |
MadMan
that package didnt work out... but I found a 6.0 LS1 already done up with Carb and MSD setup. This one is definately the real deal... I have video of the car running, pics of the engine in the car and I know the seller personally. Went into depression behind that last engine. Truck had been in the same spot almost 2yrs.
#20 |
Definitely wanna see this!
86 Short Bed Build I don't always downshift when I want to change lanes... But when I do, I make sure it's next to a prius so they know I'm hurting the environment! |
#21 |
MadMan
before he took the 6.0 out the Monte....
#22 |
MadMan
#23 |
MadMan
I wont leave it up for long....
#24 | |
But LATERRRR I'd like to put something else in there, and perhaps a 6.0 pushing one of these heavy older trucks down the road would MAYBEEEE help fuel mileage? Even though it's a completely rebuilt 305, it still doesn't feel like it has as much power as I'd like, mostly for getting onto the highway or taking off quick to get out of a parking lot etc.
#25 |
I put an ls1 5.7 in my truck and love it! The weight reduction with the aluminum block is my prefered over the iron 6.0. The added cubes might get you 10-15 hp apples to apples but the 50+ lbs weight savings makes up for and then some with how the truck drives and handles. I also moved my motor back 1 inch so that the trans bolted up in the factory location thus shifting more weight to the rear. I weighed my truck with corner scales and this is what i ended up with. All aluminum ls1, 1/2 tank gas, no driver. This is my normal daily weight..
