Old 02-25-2011, 11:06 PM   #1
65GMCFirstride
65GMCFirstride's Avatar
My 65 restoration!!!
here are some of the before and after pics of my truck before restoration
65GMCFirstride is offline   Reply With Quote
Old 02-25-2011, 11:08 PM   #2
65GMCFirstride
Re: My 65 restoration!!!
here are some more
Old 02-25-2011, 11:10 PM   #3
65GMCFirstride
and more etc...
Old 02-25-2011, 11:15 PM   #4
65GMCFirstride
heres more
Old 02-25-2011, 11:17 PM   #5
65GMCFirstride
and a few more
Old 02-25-2011, 11:20 PM   #6
65GMCFirstride
last ones
Old 02-26-2011, 01:19 AM   #7
xxangeloxx
looks like a solid truck!
xxangeloxx is offline   Reply With Quote
Old 02-26-2011, 01:30 AM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by 65GMCFirstride View Post
last ones
Looking at that door, the metal looks pretty good.
I just started digging into my passenger's - I'm going to need some patch panels.
Your bed looks to be in nice shape also.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 02-26-2011, 01:40 AM   #9
LostMy65
LostMy65's Avatar
I just noticed, yours is leafs in the back.
Edit: Never-mind, after doing a search, I see most GMCs were leafs in the back.
Old 02-26-2011, 02:15 PM   #10
Bugeyev8
Bugeyev8's Avatar
Great work so far...I see you have what looks to be a summit radiator, what bottom hose did you use? I have one like it and am having issues getting a good fitting hose
Thanks !!
Bugeyev8 is offline   Reply With Quote
Old 02-26-2011, 05:03 PM   #11
mikie 1954
Was the truck originally a 4speed 4x4 or did you put in a different center hump? I see it has the ebrake under the dash so the other hole was for a transfer case shift? NICE work, looks like it will be a nice truck when done.
mikie 1954 is offline   Reply With Quote
Old 02-26-2011, 06:08 PM   #12
65GMCFirstride
i actually bougt it with most of the drive train done but i will go look and get back to u soon
Old 02-26-2011, 09:48 PM   #13
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Nice progress so far. Is that a summit radiator? If so do you have a part number for the lower hose? Keep up the great progress.
Alan's Classic is offline   Reply With Quote
Old 02-27-2011, 01:13 AM   #14
65GMCFirstride
it is a summit radiator
Old 02-27-2011, 01:40 AM   #15
65GMCFirstride
65 GMC 1/2 ton truck with all the hard work done! Long bed fleetside. It has a late model front end with 5 lug, power disc brakes, power steering and tilt column, also 5 lug rear end. Late model 5.0 vortec motor with rv cam, edelbrock intake and edelbrock carb, HEI ign, chrome valve covers, new alt and batt, serpetine belt system, custom alumn radiator. 700R4 overdrive automatic trans with shift kit. New brakes, 2 into 1 exhaust with headman headers. 85K orig miles on truck. The motor and trans are about two years old. Was pulled from a doner truck. (1990) Nice body with some rust, mostly in the rockers, floor is solid. Good glass. bought it on august 6th and i am still working on it here are some of the most recent pics.the seats came out of a 93 suburban. will have oak bed, soon sending bed to sandblaster soon and sending truck of to get chassie pulled because it was hit bfore i got it and we could tell because the bumber had 4 holes insted of 2 one on inside of front bumber and other was on ouside of other bolt. each of by inch and we did some measurments from certin points of the trucks frame and it proved that the entireframe is crooked and that the body is straight but the frame its self is all shifted to the right about 1 inch! there is a long wa to go but this is my first car and second rebuild.
other project:
2004 dimondback weedwacker 30 cc 21 speed w/ clutch bike
Old 02-27-2011, 01:50 AM   #16
Alan's Classic
Is there a name and part number on the lower hose? Thanks
Old 02-27-2011, 01:56 AM   #17
65GMCFirstride
i will go check tommarow for ya. also canu tell if my frame is off because i have measured it and it said it was off by 1 inch ? in the front mainly past the radiator
Old 02-27-2011, 02:04 AM   #18
Alan's Classic
Get your center section of the frame level first then see if the front or rear rails are not level. It could be something other than a bent frame. Tire pressure, sagging spring etc.
Old 02-27-2011, 02:07 AM   #19
65GMCFirstride
i did all of those but i got a place that will pull it for like 350
Old 02-27-2011, 02:08 AM   #20
Rich 5150 69
Rich 5150 69's Avatar
Not sure if its an optical illusion but from that pic the right front frame horn looks to be off to the outside a little,,,
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 02-27-2011, 02:47 AM   #21
LostMy65
LostMy65's Avatar
I liked to know this also.
I found if I cut 4 inches off the 73-87 upper hose where it connects to the manifold, it fits perfect.
I still haven't found a good lower hose option.
looking forward to hearing back from 65GMCFirstride.
Old 02-27-2011, 10:24 AM   #22
65GMCFirstride
The number on the radiator is SUM-381328
then below the barcode
000004577-2-1.
Then for the hose the olny numbers i could see are 01 29 05 9....
Old 02-27-2011, 10:33 AM   #23
65GMCFirstride
Here is my new mufflers that i got. They are dual Cherry Bomb Vortex, as of now I only have 1 pipe coming out. but i plan to convert it to dual over summer break.
Old 02-27-2011, 10:44 AM   #24
65GMCFirstride
here is the bed and radiator pics
Old 02-27-2011, 11:26 AM   #25
kieth
kieth's Avatar
gmcfirstride, is that a stock tach in your dash ? it looks pretty large, and is it a 5000 rpm tach or is is a newer one? Kieth
kieth is offline   Reply With Quote
