Re: Attention All Air Baggers..
Another setup I ran across
-M.J. 1968 Stepside |
I might go this right too... Seems cheap and simple and i am all about that atleast right now.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074 Toys: 2014 Dodge Ram 1967 SHORTBED |
![]() Join Date: Apr 2004
I assume the upper T fittings are supply air to the bags and the lower barbed fittings are exhaust. Where is the supply air to the valves? In other words, where does the air from the tank/compressor hook up?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#4 | |
way2lo2
![]() Join Date: Sep 2004
The valve is normally closed, when moved up the valve opens between supply and delivery letting air flow to the bags. When pushed down it only exhaust the delivery side, letting the air out of the bags. Quite simple actually.
Dealer for Billet Specialties, Ridetech, Airlift, Vintage Air and others. Feel free to call, email, or PM for a quote. 216 481-5219 office 216 481-4240 fax 216 789-1647 mobile Way2Lo2@aol.com <----also my paypal http://www.hubgarage.com/mygarage/way2Lo2 |
Registered Cruiser
Do most guys running these run exhaust lines out of the cab through the floor pan?
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
#6 | |
I was thinking one of them had a barbed fitting for the exhaust. If so, it would be possible to 'T' them together to 1 'exhuast' line that routes to the exterior. It stinks about as long as one of your buddies farts if there's a bunch of moisture in the tank/s. If you don't jack w/the pressure often, it's definitely acceptable for the 1K+ savings ![]()
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-04-2011 at 12:14 AM. |
![]() Join Date: Aug 2009
I'm sold on this setup, just have to figure what size line to run from the tank to the paddles, 3/8 which I have or 1/2 which I'd have to buy. I'm not looking for a fast fill or drop. Maybe spend the saved money on good filter/dryer for the system.
Posted via Mobile Device |
#8 | |
Mind you if it smelt anything like some of my buddies....i'd be worried! ![]() |
Happy to be here
![]() Join Date: Mar 2000
This is in the Suspension Marketplace now.... "Paddle Valve Special"
The only problem I found is the line fit on the barb. When I was first building my systen I found small leak at the barb. By small it would leak down about every 4-3 days. To fix that I used some saftey wire around the hose and barb with good results. I have no smell in the cab from the exhaust. I recomend using some type of mainfold to keep the hoses from rubbing going thru the cab. If you need help with a mainfold PM me and I can get you a diagram.
#11 | |
Ya that works too: I just got bord at work one night and made the mainfold. Bulkhead connectors would work also.
Here are a couple clearer pics of the MIC manual set up.
i like how that system uses push connect fittings instead of hose barbs. Where do you get something like that?
#15 |
I know RideTech has them.
#16 |
Would anyone be willing to post a video of these valves in action? Maybe a little run down of the install? Or if anyone knows of an existing video link out there? Thanks
#17 | |
Keep It Simple S......
#18 | |
#19 |
^ those are sweet! im figuring 8 are needed?
My Build Thread. 70 C-20, SFBD, angled Z, 3 linked. impressive for a noob? http://67-72chevytrucks.com/vboard/s...d.php?t=438132 |
#20 |
nope only 4, each valve has a fill and dump.
#21 |
way2lo2
where do you get those?
#22 |
I want to know too. Where are those manual valves from?
#23 |
I am getting them made, should have them avail in a few weeks.
#24 |
#25 |
Found a video of an S10 with paddle valves and 1/4" line:
May be others can comment if this is a good idea of what one could expect as far as fill/dump speed is concerned. If this is about right, seems pretty reasonable to me. mR Last edited by memphisrain; 03-08-2011 at 06:31 PM. |
