02-26-2011, 09:40 PM | #101 |
Re: Barn raising
Got a little more done on the truck today, I am in the middle of fabricating a spoiler for the tailgate. My plan is to have a spray in bed liner and a roll up bed cover so the spoiler should transition nicely. Sorry I don't have great pics because it has been raining in So Cal this weekend. to finish it I will have it powder coated satin black.
Tack, tack, tack End pieces ready to be welded in place First fit up
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 02-26-2011 at 09:44 PM. |
02-27-2011, 12:22 AM | #102 |
GEARHEAD
Re: Barn raising
When I read spoiler, I thought, please no big wing. This should look alright though.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
02-27-2011, 01:32 AM | #104 |
Re: Barn raising
Ha Ha my wife said the same thing when I told her I was going to build a spoiler. This should be very modest and classy addition, Once the bed liner and roll top cover are installed it should look even better. I figure if I am going to have a NASCAR inspired shop truck it would need a spoiler.
I finished welding the end caps on but the rain got too bad to pull it out and take a picture. I will be bolting it on with four S.S. button head screws. Two inside and two outside. The finish will be black satin powder coat.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 02-27-2011 at 01:37 AM. |
02-28-2011, 10:59 AM | #105 |
67cheby
Re: Barn raising
i like it
02-28-2011, 12:42 PM | #106 |
Badass
Re: Barn raising
You could paint it black then go over it with a gray and use a heat gun to give it the aged effect . Or something like that
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
03-01-2011, 07:46 PM | #107 |
Re: Barn raising
Love those tires hope to see more,not a Nascar fan myself but those tires just look classy
03-04-2011, 03:12 AM | #108 |
Re: Barn raising
hey whats up with the truck man hate to see this die
03-06-2011, 03:02 AM | #109 |
Re: Barn raising
Been pretty busy lately. but I did get the spoiler back from powder coat and promptly twisted off a S.S. button head sheet metal screw in the mounting hole. Had to take it off to see how I am going to extract the remnant w/o damaging the tailgate.
Also I prefit a F350 bench seat that I had bought last week. This seat is the same width on the bracket and only needs minimal mods to get it to fit our trucks. Going to have it re upholstered to match the original bench seat stitch pattern. I am going to change the color to black and the carpet also.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
03-06-2011, 09:38 AM | #110 |
GEARHEAD
Re: Barn raising
I always figured it would have racing buckets and huge belts that say simpson or something. And window nets...
03-06-2011, 04:54 PM | #111 |
Re: Barn raising
I have one daughter and one wife, So I can take my whole family, including my two yellow labs in the bed, on a cruise if I have a bench. I thought about getting a modern split bench seat with all the adjustments that come with it but I really wanted to maintain the vintage look.
03-20-2011, 12:35 AM | #112 |
Re: Barn raising
Your truck looks sweet! I've been pondering doing something like this with mine but I have to paint the whole thing first. Gonna try the "fake" patina on it since I just can't handle the mental stress of having a nice paint job
Just my opinion, leave it long. Too nice of a truck to hack down. |
03-24-2011, 12:05 AM | #113 |
I'm just glad to be here!
Re: Barn raising
Mike
I just found and read thru you whole build. The tire idea is really cool and I like your spoiler idea. Looks similar to something I was thinking of for my '98 before I sold it. Is your 9" out of a Lincoln Mark V? The brakes look similar to mine. I was looking at how the caliper mounts to the bracket. It has been so long since mine was together I forgot how they go back together. Looks like I guessed right, I have the spring steel and retainer on the side end of the caliper as you do. The only difference is that my bracket puts the retainer to the top instead of the bottom. I will need to go check mine to see if I have the brackets flipped side to side. Do you know if they are marked as to what side they go on?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
03-24-2011, 02:04 AM | #114 |
Re: Barn raising
Mine is a 77 Mark V, the brackets for the e brake are from an 80's Mark VII. The bracket geometry is reversed so that the cable can pull in the direction I wanted. The brackets are not interchangeable left to right so you cannot get them backwards because they do not fit on the wrong caliper as well as they fit on the correct one.
03-24-2011, 04:41 AM | #115 |
Re: Barn raising
Love the spoiler! Very nice, not too drastic. I want one!! I'm a huge Nascar fan and love the ideas!
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
04-24-2011, 02:51 PM | #116 |
Re: Barn raising
Finally got around to snapping some photos of the finished spoiler. I finished it with a S.S. molding so it matches the rest of the trim but also protects the edge from getting dinged.
I also found a '95 F350 seat that fits in our trucks with some minor reshaping of the front bracket. Had it recovered and made sure it was stitched in the 60's style white thread with parallel seams. I loved the old seat and there was only minor tears in the vinyl but being a low back the rear window is the first thing my head would hit in a crash. My wife convinced me that the turquoise is a better color for the vinyl rather than black.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 04-24-2011 at 03:04 PM. |
04-24-2011, 03:09 PM | #117 |
PROJECT 7DEUCE
Re: Barn raising
That spoiler turned out waaaayyy better than I thought it would nice work.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-24-2011, 04:08 PM | #118 |
Re: Barn raising
I'm running a mid 90's ford seat in my step also, I was quite suprised how well it fit. and its alot more comfy than the origanal bench. I like the spoiler idea, it looks sharp. Did you think about putting some peices molded into the rear bed corners kinda like a 3 piece spoiler. just a thought.
04-24-2011, 05:40 PM | #119 |
Re: Barn raising
Thought about it but I wanted to keep it simple and not drill into the fleetsides.
On my seat I did notice that the Fords have an arm rest on the door that runs the entire length of the door and the back of the bench is narrower than the original Chevy but the bottom is just about the same. I had the upholstery guy add 2" of foam on each side to fill in the gap worked out great.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 04-25-2011 at 12:54 AM. |
04-24-2011, 06:37 PM | #120 |
Resident of Here
Re: Barn raising
Lookin good mike!
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
04-25-2011, 01:42 AM | #121 |
Re: Barn raising
Very nice! Glad to see it turner out well! I like the matching vinyl. Goes good with the truck.
04-25-2011, 10:49 AM | #122 |
GEARHEAD
Re: Barn raising
Looking good. My seat is a 60/40 split vinyl bench from a early 90's suburban. I'll have to get it recovered in turquoise also. Did the seat match the original door panels and arm rests good? If so, could you get me the specs on the seat cover material?
I still need to find some arm rests in that color. Been looking for a year or 2 and haven't had any luck yet.
06-03-2011, 04:21 AM | #123 |
Re: Barn raising
Mate ya chev is the ducks guts! love the sign writing, love that old garage truck look. if that make any sense?? Any updates?
06-03-2011, 08:54 AM | #124 |
Re: Barn raising
dude love the side pipes. where'd you get them? i was kind of diggin the 4-1 collectors.
69 Chevy lwb Fully built 350 3 on the Tree |
06-03-2011, 11:04 AM | #125 | |
Re: Barn raising
Is the What??? ducks guts?? Ok...HAHA
________________________________ 1972 SWB stepside pro tour build thread http://67-72chevytrucks.com/vboard/s...d.php?t=452840 |
