Old 03-06-2011, 07:50 PM   #1
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
What did you get done 3/6/11 edition
weve been working alot lately and havent gotten any truck stuff done.. how about you all?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-06-2011, 07:59 PM   #2
monte0185
monte0185's Avatar
Re: What did you get done 3/6/11 edition
Took my truck apart and took it to the paint shop.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 03-06-2011, 08:03 PM   #3
87 chevy silverado
got some goodies
87 chevy silverado is offline   Reply With Quote
Old 03-06-2011, 08:36 PM   #4
S10Fan
Old Heap Driver
Delivered my buddy's 84 C-10 back to his house after completing a motor swap. Scored a smoking deal a couple months ago on a non-smoking 305 to replace the smoking leaking 305 in his truck. The smile on his 70 year old face was worth every minute I spent on the truck.
Rained all day today so I hunkered down in the garage and worked on my 50'.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 03-06-2011, 08:41 PM   #5
sumran
sumran's Avatar
Pulled the motor and tranny out of the parts truck. Stripped most of the other parts as well. After I pull the steering column it will be ready for the scrap yard.
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
Old 03-06-2011, 08:42 PM   #6
Toxic Redline
Toxic Redline's Avatar
Fixed my lights so now all four of them work (DANG YOU PO'S WHO CUT OFF THE GROUNDS!!), and got my brake lines underway
84 K20 Long Box W.I.P
78 Burb - parts now [Rolled]
68 c20 dump bed
WHEN IN DOUBT--- FLOOR IT
Toxic Redline is offline   Reply With Quote
Old 03-07-2011, 12:35 AM   #7
85burb
85burb's Avatar
Put stiffer secondary spring in carb.....Gas prices suck....set idle mix and spent over 60 bucks for 6 dang spark plugs for wifes toyota and managed to get stuck in the engine doing the back 3.....................HATE toyotas. Did manage to dislodge my self from engines death grip.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 03-07-2011, 12:41 AM   #8
scooter122983
The Man The Myth The Mystery
Took the cracked LMC repop dash out of my truck and scraped off all of the foam and vinyl. This week at work in the heated garage i will be laying glass over the plastic shell. Not really sure what im doing but its better than the alternative.
scooter122983 is offline   Reply With Quote
Old 03-07-2011, 12:49 AM   #9
mongoose
mongoose's Avatar
replaced the control arm bushings... what a pain that was haha...
other than that, finally built a shelter for my crap working in the rain/snow just sucks... pretty good... also... blazer's are laminated 2x6 proof... so if you happen to drop one on your truck like i did.. no worries just wipe off the dust it leaves behind.. lol
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 03-07-2011, 01:30 AM   #10
SBTork
Garage wrench
SBTork's Avatar
not much, got two fenders and lower grille metal filler panel. One of the fenders was a GM replacement. Not sure what to do with them yet, may wind up cutting them up for my burb eventually, not sure.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 03-07-2011, 01:49 AM   #11
Altec
Getcha Pull
Altec's Avatar
Nothing on my truck. Raining. Worked on a four wheeler. The owner rolled it, and it wouldn't run after. Cleaned the carb out first. Gotta pick up a new spark plug today. Then I gotta "test it."
Cleaning the carb wasn't a easy task. It is a Suzuki, and the carb is under a ton of crap, and has about fifty hoses hooked to it. Managed to get it out though. One of the screws for the bowl was FUBAR'd so I took a hack saw and cut a groove for a flat blade screw driver. Then I called my Father out to the shop for a second pair of hands. He took a chisel, and a hammer and tapped on the corner of the screw while I held the carb. That broke the screw loose.
Put the carb back on, and it was getting fuel now, but no start. So I pulled the plug and checked to see if it fires. Yep. Timing correct? Yep. Fuel making it to the cylinder? Yep. Try starting with starting fluid? No bang... So now I'm just going to pick a plug up. Got a feeling that the plug isn't firing correctly under load.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 03-07-2011, 01:54 AM   #12
BIG KRIS
BIG KRIS's Avatar
Nothing today went to the chicago world of wheels show.I ordered dropmember and 20inch raceline wheels and nittos with the new rear drag radials.
Flowershop Hip Hop & Street Rods
Dropmember
83 Custom Deluxe Almond on Almond
85 Silverado White on Red/Now Chevy LeMans Blue
Rendering in Truckin magazine vol 36 no. 11,2010
BIG KRIS is offline   Reply With Quote
Old 03-07-2011, 04:34 AM   #13
Leedogg
I done Plugs/wire/cap and rotor on the dually, and rechecked the timing. Idles smoother than before- but is still sputtering some while accelerating. Will move on to the fuel system basics next(filter, pressure test).
1989 Chevy Crew Cab Dually - 454/400, Trans Am Hauler, Future bagged project.
96 Trans Am: 383/m6 - 11.98@115 on 315 M/T D/R's - 408rwhp 394 rwtq
05 VW Passat TDI - 38mpg @75mph
07 Bandit 1250S - Two wheeled fun!
Click here to see my FQuick Garage!
Leedogg is offline   Reply With Quote
Old 03-07-2011, 06:47 AM   #14
Prong
Make sure the kill switch didn't get bumped to the "off" position in the slightest--they are extremely sensitive. I've seen it happen before.
Prong is offline   Reply With Quote
Old 03-07-2011, 06:54 AM   #15
ghettoluxury
ghettoluxury's Avatar
Got all 23 feet of the truck in my garage and pulled the motor. My stainless headers also arived.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 03-07-2011, 07:41 AM   #16
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I bought an 87 short wide truck to part out for my fuel injection stuff and some body parts.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-07-2011, 07:45 AM   #17
D13
D13's Avatar
Picked up 16' more pallet rack. Put a fuel filter in my rebuilt carb, just need a choke unloader rod and it can replace the carb on the 77 (which doesen't have the rod either. Dang.). Got the steel crank pully hung on the diesel, just have to figure out how I tensioned the PS belt last time. Worked on cleaning up my scrap pile. Measured up a clutch hole for Tx Firefighter.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 03-07-2011, 08:46 AM   #18
RuralRoute C-30
RuralRoute C-30's Avatar
New job has had me busier than usual and coming home tired until I get the mess I walked into cleaned up.
I did finally order a new dash pad for the C-30 this week. Will update the dash and door trim in the process as well. With some elbow grease cleaning on the door panels, seat and sheet metal plus installing the new dash gauge bezel that I got this winter the interior should come out looking fairly good.
Also had to take it out Friday afternoon to get a new inspection sticker. First time it's been out on the road since last December actually. While driving and looking at that dash it was then I decided it was time for a new one. That old one isn't going to get any nicer!
At least it's ready to go to work for another 6 months. Passed Illinois safety inspection without a problem and have that much needed new sticker in the windshield now.
Now if the weather will just warm up soon!
Mark
1985 Chevy C-30 Hydraulic Dump Bed
2001 Saturn SC2 (go to work car)
2010 PT Cruiser (wife's car)
"Reality is just a hallucination brought on by lack of alcohol."
RuralRoute C-30 is offline   Reply With Quote
Old 03-07-2011, 11:43 AM   #19
DriverDown
Junior Member
DriverDown's Avatar
I finally took some pictures of my truck at the park just across the highway - made it in right before closing:
DriverDown is offline   Reply With Quote
Old 03-07-2011, 11:47 AM   #20
DriverDown
Junior Member
DriverDown's Avatar
It's not clean right now, but it looks good to me, dirt and all!
Old 03-07-2011, 08:18 PM   #21
jrcaprai
Got My MSD Iginition in and wired up
And My Pro-systems Carb installed and running
jrcaprai is offline   Reply With Quote
Old 03-07-2011, 08:23 PM   #22
75ChevyGuy
GM Parts Guy
75ChevyGuy's Avatar
Pulled off my old dash cover to find a original dash pad underneath. Goota fill some cracks and what not, but it should be worth it. Installed a 08 Malibu onstar mirror, and almost finished wiring the auto dim for it. Also will be buying some nice rallye wheels for it.
1975 Chevrolet C-10 Custom Deluxe (DD/WIP)
1989 Chevrolet C1500 reg cab stepside (Winter Truck)
1977 Harley Davidson XLH 1000 (Summer Cruiser)
75ChevyGuy is offline   Reply With Quote
Old 03-07-2011, 09:15 PM   #23
Altec
Getcha Pull
Altec's Avatar
jrcaprai- Worried about that plug wire laying on the header?
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Old 03-07-2011, 11:10 PM   #24
slammed427
slammed427's Avatar
Looked at it, drove it a little bit. Went and looked at 5 speeds for it.
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 03-08-2011, 01:39 AM   #25
355bullet
355bullet's Avatar
i didnt do anything, entered my truck for a display at the monster trucks
link to show
http://www.southwestdrags.com/forum/...ad.php?t=13227
355bullet is offline   Reply With Quote
