Old 03-24-2011, 07:45 PM   #1
aggieguy713
aggieguy713's Avatar
What's that sound?.....
I've had a squealing sound coming from the engine/transmission for about a month now, i have replaced the following: Harmonic balancer, water pump, ac pulley, alternator pulley, and throwout bearing and re- aligned clutch and pressure plate.
Heres where it gets tricky... It makes a loud squeaking sound when the clutch is pressed in, or after it has been when your driving it. I made some calls today and was told that it could be the thrust bearings in the engine? Engine is off a fresh rebuild...havent even met the 500 mile mark yet..any help appericated.
70 Chevy C10, LT1, T5, "Blue Beast"
aggieguy713 is offline   Reply With Quote
Old 03-24-2011, 08:05 PM   #2
dznucks
dznucks's Avatar
Re: What's that sound?.....
If your thrust bearing goes out you should see brass/bronze/copper looking metal pieces in you oil.
Could also be your input shaft bearing to the tranny or the throw out bearing.
Does it act funny when you drive it or does it just make a noise.
dznucks is offline   Reply With Quote
Old 03-24-2011, 08:10 PM   #3
Spoof
Spoof's Avatar
fly wheel?
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 03-24-2011, 08:12 PM   #4
OLEBEATER
OLEBEATER's Avatar
Belts?.............
OLEBEATER is offline   Reply With Quote
Old 03-24-2011, 08:16 PM   #5
aggieguy713
No it dosent shift or drive any different, its just a loud squeal or squeak. The thing that was pointed out to me, is that the harmonic balancer moves slightly when the clutch is pressed in, hence where everyone said thrust bearings. also I should mention that the squeal does not happen when parked in neutral, only with the clutch engaged. New fly wheel, got it when we rebuilt the engine. The serpentine belt is new, so im pretty sure its not slipping.
Old 03-24-2011, 08:18 PM   #6
aggieguy713
Also would the thrust bearing going out cause it to squeal like a freakin pig?
Old 03-24-2011, 08:24 PM   #7
DaBigKahuna
DaBigKahuna's Avatar
Do these things have pilot bearings/bushings?? Might be that.
DaBigKahuna is offline   Reply With Quote
Old 03-24-2011, 08:25 PM   #8
Dunenutt
Newbee
Dunenutt's Avatar
Cut the oil filter apart, and look for copper chunks in the filter pleats. That is the easiest/cheapest way to check for bearing dammage. A moving damper on a fresh motor is not a good sign.
Dunenutt is offline   Reply With Quote
Old 03-24-2011, 08:26 PM   #9
aggieguy713
Yeah, when i pulled the transmission to replace the throwout bearing it was fine.
Old 03-24-2011, 08:27 PM   #10
71Sixer
71Sixer's Avatar
Does it do it only when driving or also sitting. I ask because mine squeals sometimes when driving but I know it's the speedometer cable making the noise.
71Sixer is offline   Reply With Quote
Old 03-24-2011, 08:28 PM   #11
Dunenutt
Newbee
Dunenutt's Avatar
I had one go out! The counter weights spinning against the block webs will make a wierd sound.
Old 03-24-2011, 08:28 PM   #12
aggieguy713
it does it at both times AS long as the clutch is pressed in.
Old 03-24-2011, 08:29 PM   #13
aggieguy713
ok. Makes sense, im going to change the oil tomorrow...i hope its not that...less than 500 miles and ill have to go through it again...lol.
Old 03-24-2011, 08:50 PM   #14
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Does it only do this after the motor has warmed up?
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 03-24-2011, 09:16 PM   #15
stich626
if you can see the balancer move when hitting the clutch you got bigger problems
stich626 is offline   Reply With Quote
Old 03-24-2011, 11:07 PM   #16
68gmsee
Active Member
68gmsee's Avatar
This is what my brother and I did to find a rattle on his vehicle many years ago but if you do it it's at your own risk. (Gotta say this these days...)
We chocked the front wheels, raised the rear wheels and put them on jack stands. Started the engine and I got under the car and watched and listened with my "stethoscope" -a 2 foot piece of gardent hose while my brother worked the clutch and shifted the gears. With the garden hose to my ear I could listen at various locations to get an idea where the sound was coming from.
IIRC, in our case it turned out to be a rattle inside the tranny.
68gmsee is offline   Reply With Quote
Old 03-25-2011, 06:06 PM   #17
lil hoodlum
lil hoodlum's Avatar
My guess the squeeling is coming from your wallet!!
I really don't know. I'm not a very good mechanic but I sure am a good parts changer!!
Good luck!
Keith
lil hoodlum is offline   Reply With Quote
Old 03-30-2011, 11:42 AM   #18
Dunenutt
Newbee
Dunenutt's Avatar
The suspense is killing me...
Any updates?
Old 03-30-2011, 01:09 PM   #19
JORGIE95961
throwout bearing. i had this hapen in an old truck i had
JORGIE95961 is offline   Reply With Quote
Old 03-30-2011, 01:19 PM   #20
70STOVEBOLT
70STOVEBOLT's Avatar
Me too, wonder what it is?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-30-2011, 01:29 PM   #21
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
I know this is going to sound crazy, but i had a loud squealing noise on a fresh rebuild and it was driving me crazy. It took me a couple of hours to figure it out. And what it was i had all my breather holes on the valve covers blocked and the squealing noise was comming from the dipstick tube. and when i pulled the dipstick out it went away. Bottom line engine was creating to much vacum in the block.I put a breather cap on and never heard it again. This might be your case. but it happens
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 03-30-2011, 02:40 PM   #22
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by Mr Chevorlet View Post
I know this is going to sound crazy, but i had a loud squealing noise on a fresh rebuild and it was driving me crazy. It took me a couple of hours to figure it out. And what it was i had all my breather holes on the valve covers blocked and the squealing noise was comming from the dipstick tube....
That's a new one on me and I've heard noises come from where you least expect them.
A friend once complained that his transmission was going out on his old datsun with floor shift. It was making a whirring sound when he shifted to second gear. I drove with him for a block or two and found out the boot was torn and when he shifted up it opened it up. He was hearing road noise. Saved him from buying a transmission.
Old 03-30-2011, 02:50 PM   #23
dougminton
dougminton's Avatar
I agree, thats where I would look first
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 03-30-2011, 03:34 PM   #24
keanevann
He said he has already replaced the throwout bearing....
keanevann is offline   Reply With Quote
Old 03-30-2011, 06:46 PM   #25
BLAZERMAN
BLAZERMAN's Avatar
I dont think your crazy at all!! Thats why I asked if it only did it once the engine had warmed up. I spent weeks trying to track down a very annoying noise it a fresh 400..it would only do it once the engine had warmed up and then only in drive and usually at a stop light. It sounded just like a bearing and was very loud..it ended up being my pvc line was crimped shut..too much pressure in the cranckcase...it always sounded like the noise was coming from the rear main, transmission area.
