Old 03-28-2011, 02:02 PM   #1
HARJO
HARJO's Avatar
What was the Previous Owner Thinking?!?!?!
Is there anyone else that gets furious when thinking about what the previous owner has done to your truck?
The PO of my truck (and the shop here in Vegas doing some of his work) seemed to have been dropped on their heads a bunch when they were babies. Too many dollars and not enough sense.
For example:
1. Cutting the front crossmember to clear the oil pan, leaving only 1/4" of material in 4 places (pictures attached)
2. Cutting a hole in the center of the bed for the gas cap of a fuel cell.
3. Screwing up a Painless wiring setup (how does this happen?!)
4. Using wheel spacers to fix backspacing issues, leaving only 4 threads to hold on a set of 35" tires.
5. Buys a RamJet 350, can't figure out the fuel injection needs so unbolts it and throws it away in favor of a way oversized carb.
6. Using a fuel injection electric fuel pump at 60 psi, plumbed to a carb that requires only 6 psi.
7. Pulls spark plug wires off with need nose pliers, tearing the boots and causing spark jump to the headers.
8. Pinion angles way off.
The list goes on and on and on...
1968 Chevy C10:
4x4 conversion, 6" lift, 37" GoodYear Military OZ's, carb'd GMPP RamJet 350, Be Cool aluminum radiator, Flex-o-Lite electric fans, March accessory brackets, T350 trans, NP205, 4 wheel disc, fuel cell... etc.
HARJO is offline   Reply With Quote
Old 03-28-2011, 02:17 PM   #2
6772owner
Gearhead
6772owner's Avatar
Re: What was the Previous Owner Thinking?!?!?!
WOW! Some scary stuff there!
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 03-28-2011, 02:20 PM   #3
Riveted1
Tasty Cakes!
Riveted1's Avatar
I just had to pick my jaw up off of the floor!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 03-28-2011, 02:47 PM   #4
cam.man67
cam.man67's Avatar
Whoa! I mean, I've often wondered that about my black spraybombed interior, an intake manifold with some interesting throttle linkage, but nothing as serious as that!
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 03-28-2011, 02:51 PM   #5
292farmer
292farmer's Avatar
wait did you say a shop did this?! my god what kinda workers do they allow these days! though a hole in the bed for a fuel cell though weird i don't think is bad so long as you never haul anything and need to fill up.... and isn't the ramjet just a plug and go system i mean thats based off a 60-70's tech for the corvette right?
1972 gmc c25 292/sm465 dana 60 w/5.13s
1973 vw super beetle 1600cc/4spd(baja bug)
1974 chevy c60 351v6/np-540+2 speed eaton rear
2005 chevy cobalt 2.2l
292farmer is offline   Reply With Quote
Old 03-28-2011, 03:01 PM   #6
Robertjust777
what part of vegas do you live in and what shop im here in vegas or well henderson
Robertjust777 is offline   Reply With Quote
Old 03-28-2011, 03:04 PM   #7
Beelzeburb
Devil's in the Details
Beelzeburb's Avatar
Wow. Just wow.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread
Datsun 240Z, 510 2 door and an old Honda motorcycle
Beelzeburb is offline   Reply With Quote
Old 03-28-2011, 03:10 PM   #8
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
crazy mods right there!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 03-28-2011, 03:44 PM   #9
Cobble job #29,783. A whole lotta ignorant can set in over a 40 year period.
Old 03-28-2011, 03:58 PM   #10
YBNORML
YBNORML's Avatar
Some people should have thier tools taken away!
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 03-28-2011, 04:31 PM   #11
HARJO
HARJO's Avatar
I'm over by 215 and Windmill, not too far away it seems. It was some "creations" shop out at the speedway, not totally sure of the name.
1968 Chevy C10:
Old 03-28-2011, 04:32 PM   #12
68 IRON
68 IRON's Avatar
Soooo........Beavis and Butthead did get a job after their show!!! Can you imagine the thought process behind this? Ya, wow!
68 IRON is offline   Reply With Quote
Old 03-28-2011, 04:36 PM   #13
HARJO
HARJO's Avatar
Yeah, the hole in the bed is just dumb and lazy. It's not like there aren't cleaner ways to install a cell and a gas cap system on the cheap.
Yeah, the "modern" RamJet crate was supposed to be plug and play; bolt it up, 1 fuel, 1 fuel return, 12v power, throttle cable and radiator hoses. About as simple a setup for FI that you can get.
1968 Chevy C10:
Old 03-28-2011, 05:00 PM   #14
cdowns
cdowns's Avatar
if the previous owner didnt sell you the truck you'd have nothing to say
Old 03-28-2011, 08:26 PM   #15
674x4ton
Some people think ,with a cutting torch you can fix any thing. That get in your way.
674x4ton is offline   Reply With Quote
Old 03-28-2011, 08:58 PM   #16
Spoof
Spoof's Avatar
They put a carb on a Ramjet? WTF! The RJ IS plug and play but I still can't figure out how to wire up my tach without killing the engine. Soon tho.
And why didn't the RJ oil pan fit?
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 03-28-2011, 10:36 PM   #17
Flint70step
Flint70step's Avatar
Oh yeah.....that looks safe.......This is a perfect example of ask some one else before cutting!Is this a good idea?
Flint70step is offline   Reply With Quote
Old 03-28-2011, 11:00 PM   #18
Murphy IRE
OMG! I *****, barf and complain about stuff my PO did, but your PO takes the prize! Sorry!!!
Murphy IRE is offline   Reply With Quote
Old 03-29-2011, 12:20 AM   #19
72shortbed12
Talking Re: What was the Previous Owner Thinking?!?!?!
Thats ridiculous. They should have their business license revoked. I wouldn't be ashamed to be caught dumpster diving for the fuel injection stuff
1972 K10 4wd Swb 350, 4 speed, 205 t-case Sold
1971 Cheyenne 2wd Lwb 350 4 speed Sold
1972 K5 blazer 4WD auto A/C
72shortbed12 is offline   Reply With Quote
Old 03-29-2011, 12:27 AM   #20
feller
feller's Avatar
they screwed up a ram jet??? i wish i could afford one let alone afford one to throw away. why didnt they just get another oil pan?? and i have seen lots of people put the fuel fill in the bed floor but its always in the rear by the tail gate either center or to one side but not in the middle???
feller is offline   Reply With Quote
Old 03-29-2011, 12:29 AM   #21
Transformula
Transformula's Avatar
I've seen some crappy places at those shops at the Speedway complex. Some shady people up there!
Ya outta see my cobbled mess of a 4x4 conversion!
T.Y.N Custom Works..... Because "Stock" Sucks!
1971 K 10 GMC Long Bed
1977 Formula T/A Frame off Resto-Mod
1995 FXDL Harley Low Rider
1985 C10 ShortWide 91 Burb front.
Transformula is offline   Reply With Quote
Old 03-29-2011, 04:06 PM   #22
Cbrown67
I have a few for you this is how the add more length to the exhaust pipes
and this is the steering column a piece of wedged in pipe and an exhaust clamp keeping that in place
Cbrown67 is offline   Reply With Quote
Old 03-29-2011, 04:48 PM   #23
Stricklinator
Stricklinator's Avatar
That is bad! I cried when I priced the driver's side upper and lower trim the po of my truck threw away because "it was all dented anyway".
Stricklinator is offline   Reply With Quote
Old 03-29-2011, 05:05 PM   #24
RCbowtie69
RCbowtie69's Avatar
Somebody wasn't thinking that day,or any day,hope it can be fix. Keep on Truckin''
RCbowtie69 is offline   Reply With Quote
Old 03-29-2011, 07:15 PM   #25
1970C10truck
1970C10truck's Avatar
Looking at these pictures and reading what was done makes me feel like I my project is in pretty good shape.
1970 C10 swb 350 4spd under construction
1970C10truck is offline   Reply With Quote
