yes, i do
wiper arm removal?
so i tried getting the wiper arms to come off so i can remove the cowl panel and they didn't budge, so i stopped before fudging something up. can anyone tell me how these blasted things are supposed to come off?
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
Re: wiper arm removal?
lift your wiper up where it flex's and attaches to the truck. there is a little lever under the round area that you may need to push up with a small screw driver while you pull it towards you and away from the truck... they can be a pain thats for sure.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
The easiest way is to use the tool made for removing wiper arms. The tool is available at most parts stores and is not that expensive. The little tin clip that is under the arm will not stop the removal so you don't have to address it.
I can post a pic if you have trouble finding the tool. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
#4 | |
1. Get on the Google and type in "Snap-on A192". 2. The first hit is a Snap-on web page where you can order Snap-on tool number A192. 3. Click "Add To Cart". 4. Click "Checkout". 5. Wait for A192 in the mail. 6. Remove wiper arm the proper way with the proper tool and never scratch up your cowl again. Same tool works on 1971 and 1972 Chevelle wiper arms too. This tool belongs in EVERYBODY'S tool box next to the window crank/inside door handle five dollar horse shoe clip remover tool. Kinda like a distributor wrench. Yes there are other ways to get by but until you have the correct tool you don't know how easy it can be.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#5 | |
Between Trucks...
Beat it to fit, Paint it to match... ![]() |
I just used the claws on a hammer, worked good, but then I'm not worried about scratching paint.
'68 C10 LWB 6.2NA/NP833 3.73's |
#7 | |
Fuzzy |
Cops, ha, catch me if you can!
You can get said tool, or you can remove that tab with a small screw driver by pulling down on it. You don't need the tab to keep the wiper arms on. With the tabs removed you can then devote your anger towards removing the wipers, have fun, they can be a pain in the ***
72 C-10 Stepper 350/TH350 3.73 in the back Edelbrock intake and Carb Hooker Comp Headers 275/60R15 on Rallies ![]() ![]() |
I used a set of channel locks to GENTLY remove my arms after poping the release under the arm
a wise man once said "There are only two real rules to life... 1 - Don't sweat the small stuff 2 - Everything is small stuff |
In 15 years of owning these truck I've never used a special tool. The thought of a special tool never even crossed my mind and I've fought with many wipers. Damnit...why didn't I think of googling it?!?
#11 | |
I bought this thing many years ago (1988 or so). I recently found it still wrapped in its original sealed bag with some stuff I had stored. It took me a couple of tries, but once I figured it out, piece of cake. Better than anything else I ever used to get the bloody (#^!%@*@&^) arms off. I just looked at LICS http://www.parts123.com/parts123/yb.dll?parta~partsort it is still six bucks.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 Last edited by bollybib; 04-21-2011 at 10:34 PM. Reason: more info and booboos |
![]() Join Date: Sep 2001
I ordered this Snap-On wiper removal tool ($10) and the first time I used it I realized how ridiculous it is to use a screw driver and pry against the cowl. This should be in the FAQ.
Today I'll order a Snap On wiper removal tool. After pulling one tab out completely during a raging fit, mine still did not come off. The 4.5 inch cut off wheel easily removed the wiper arms. I'll have to pay for my fit when I buy new wiper arms. Thanks for the tip!
1968 Chevy C/10 LWB V8 ![]() 1983 K5 Blazer 1989 C1500 Stepside Reg. Cab V8 |
#15 |
needs more $$$
1970 2wd Blazer |
#16 |
An old rag works great for the crank/door handle. I think I learned that from one of fastwillie 696969's posts.
#17 |
![]() Join Date: Feb 2009
I just ordered the part. No clip? Sounds like the tension in the arm keeps it attached.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#18 | |
https://www.youtube.com/watch?featur...KvbtxGiI_w#t=0
#19 | |
All about them K’s
![]() Join Date: Jun 2014
That said thanks for the info on the snap on tool. I've fought these stupid things a few times and even come close to the cut off wheel myself!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#20 |
Whats the door compressor tool do. Work for a 71?
#21 |
All about them K’s
No the later hinges (73+) have a spring that stops the door in the different positions. In order to swap the pins and bushings the spring has to come out and it can be a real pita.
#22 |
I took mine off with a bottom keeper to a u bolt for exhaust lol believe it or not it worked.
#23 |
#24 |
![]() Join Date: Mar 2005
Great info! Just ordered one. $12.05 + Tax free shipping.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
#25 |
