04-20-2011, 10:40 PM | #1 |
Hot Rods For Life
Altenator mounting? Going from ramhorn to headers
I have brackets for ram horn mounting but have switched to headers. Can I some how use those to mount with headers? The lower bracket used to bolt to the Ram Horn but now those are gone. I am just trying to figure out what I need now to mount the altenator.
Anyone want to share and thoughts or photos of their setup on a 350 SBC? Thanks |
04-20-2011, 10:54 PM | #2 |
Grandpa in the rustmobile...
Re: Altenator mounting? Going from ramhorn to headers
Do you have holes in your heads? If yes, just use the 69-72 (I think) style mounts
....I wish it still looked this good..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
04-20-2011, 11:08 PM | #3 |
Are you wanting a stock or aftermarket look? Passenger or drivers side?
I picked up an inexpensive alternator bracket from Skip White
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb |
04-20-2011, 11:20 PM | #4 |
Eat, Sleep, Drive a Chevy
you may need one of these http://www.summitracing.com/parts/BIG-10031FLT/
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
04-20-2011, 11:41 PM | #5 |
Hot Rods For Life
Yeah that might work.
04-20-2011, 11:42 PM | #6 |
Hot Rods For Life
Pretty much going for the stock look, but this helps.
04-20-2011, 11:43 PM | #7 | |
Hot Rods For Life
I was looking at that. How does it mount though? I wonder if it bolts with the header?
04-21-2011, 12:01 AM | #8 |
I have that setup. Yes it bolts up with the header.
1971 C20 Longhorn Custom Camper |
04-22-2011, 10:34 PM | #9 |
Chemist under the hood...
Please post pics if possible-Looking for the same thing myself.
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
04-23-2011, 06:34 AM | #10 |
Are you using tall or short valve covers? The factory style wont fit with tall valve covers. The bracket that is posted in the pic needs another one to work properly. I think I should have a couple if you want one. They bolt to the header and have another bracket that adjusts to fit the alternator.
04-23-2011, 09:18 AM | #11 |
Here is a pic of the bracket. Yours if you want it Andy.
Posted via Mobile Device |
04-23-2011, 09:43 AM | #12 |
Oldblue68 I am in need of the bracket you are using for your power steering pump can you tell me if it is a stock or aftermarket and where I might get it? Thank you
04-23-2011, 10:00 AM | #13 |
Thanks Andy-I've seen this part on Jegs before but can't figure out how it would hook up. I don't have any holes in the head (other than my own!). Will it work with the Ramshorns?
04-23-2011, 10:49 AM | #14 |
i also am looking for PS brackets / pump stock if possible or where to go after maket
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
04-23-2011, 06:07 PM | #15 |
It sounds like you have the ramhorn manifold without a casting for the alt bracket? The bracket pictured above is designed to mount using the front 2 bolts on the header, the opening between the 2 bolts may be too small to clear the cast iron exhaust manifold however it may still work with some customization. You would need to take a die grinder and modify the bracket to get the clearance you need. hope this helps. good luck
04-23-2011, 06:32 PM | #16 |
Between Trucks...
I used an Alan Grove PS bracket for my smallblock. Works well.
Beat it to fit, Paint it to match... |
04-23-2011, 06:42 PM | #17 |
I bet if you looked on the parts board here you could find someone who has some original brackets, there are several guys that part out these trucks on a regular basis. good luck
04-23-2011, 08:27 PM | #18 |
PROJECT 7DEUCE
Nice job ratrod that right there is what makes this board so great.. If we still had rep points id send ya some.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-23-2011, 11:17 PM | #19 | |
Thanks for the reply.
