Old 04-24-2011, 01:55 PM   #1
emil77
Horn doesn't work, do I need to pull steering wheel?
Hi guys,
The steering wheel in the picture below was put on by the previous owner. The horn hasn't worked since then, I'm thinking he forgot to connect something. When I put power to the horns inside the engine bay, they work. So somethings wrong with the steering wheel part. Do I need to remove the steering wheel, in order to work on the horn?
If not, could you please tell me how to remove just the area I need to work on for the horn? Can I pop off that center piece and the horn contacts will be exposed? If I do need to remove the steering wheel, use a steering wheel puller correct? Are there screw/bolts I need to loosen/remove first before pulling the steering wheel?
Thanks,
Emil
1972 Chevy C20
emil77 is offline   Reply With Quote
Old 04-24-2011, 02:31 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Horn doesn't work, do I need to pull steering wheel?
Can't help you much with that wheel, sorry. But first, when you press the horn button, can you hear the horn relay click under the dash? If so, the steering wheel wiring is okay, and you're not getting -12vdc from the relay to the horns.
If the relay doesn't click, you'll probably need to remove at least the cap, if not the wheel. Grounding the wire (behind the wheel) will cause the horn relay to click.
Might be a good idea to remove the wire from your horns before pulling the wheel. That way when the relay operates, you'll just get a click instead of a blast from the horns.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 04-24-2011, 04:24 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would check to see if you are getting a ground to the relay sent from the horn button before pulling the wheel
Old 04-24-2011, 04:31 PM   #4
emil77
Hi guys,
When I put a wire from the battery to the horns, there are 2 horns, (is that standard?) I can make both horns turn on. So the wires to the horn in the engine bay are working, just from the steering wheel to the horn there seems to be a problem.
Thanks,
Emil
1972 Chevy C20
Old 04-24-2011, 04:56 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yes, two horns are standard.
Grounding a wire at the steering wheel operates the horn relay. The horn relay then sends battery to the horns.
Maybe it's as simple as a blown fuse for the horn relay.
- Mike -
RIP El Jay
Old 04-24-2011, 06:32 PM   #6
emil77
Hmmm, a blown fuse. Hadn't thought of that. Would it be one of the fuses in the cab? If so, which one?
Thanks,
Emil
1972 Chevy C20
Old 04-24-2011, 08:31 PM   #7
wwotr
wwotr's Avatar
watching...
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline   Reply With Quote
Old 04-24-2011, 09:48 PM   #8
72lb4x4
Chances are the person who installed the new wheel didn't understand how to make the horn button work and so its not hooked up.
Take off the inner part and post a pic...
The fuse panel doesn't seem to have a fuse for the horn: http://67-72chevytrucks.com/vboard/s...d.php?t=400597
72lb4x4 is offline   Reply With Quote
Old 04-24-2011, 11:43 PM   #9
emil77
How do I take off the inner part? Should I just use a thin flat head screw driver?
Thanks,
Emil
1972 Chevy C20
Old 04-26-2011, 02:43 PM   #10
emil77
Update: I took off the inner part of the wheel and exposed the nut. After I removed the nut in the middle, I was moving the steering wheel and the horn went off for a second. Also, when I took of the horn, it fell out and that's what you see in picture number 1. It wasn't even attached at all! So I'm thinking that's my problem? I removed the nut holding the steering wheel, but couldn't take the wheel off completely, this is where the steering wheel puller comes in correct? In picture number 4, what is the little nut thing with the red "collar" to the left of the steering wheel nut? Is that where the wires attach?
Picture number 1:
Picture number 4:
Thanks,
Emil
1972 Chevy C20
Old 04-26-2011, 03:05 PM   #11
dadsworktruck
can't help you on the first pic, that is not going to work at all, looks like you need to check out who made that wheel, but you can test the horn by grounding that springy pin thing to the center shaft, should blow, it's called horn contact.
dadsworktruck is offline   Reply With Quote
Old 04-26-2011, 03:30 PM   #12
emil77
Ok, so that test worked. When I grounded the "springy pin thing" on the left to the center shaft, the horn blows. So, now what?!
Thanks,
Emil
1972 Chevy C20
Old 04-26-2011, 03:41 PM   #13
JORGIE95961
are you in love with that sterring wheel???
JORGIE95961 is offline   Reply With Quote
Old 04-26-2011, 04:02 PM   #14
emil77
Not really, I don't like how it says "GMC Trucks" instead of Chevy.
Thanks,
Emil
1972 Chevy C20
Old 04-26-2011, 04:09 PM   #15
JORGIE95961
then get rid of it bud i got one from a cavalier i totaly dig on mine
and the horn works great
Old 04-26-2011, 04:20 PM   #16
emil77
Do you have a picture?
Thanks,
Emil
1972 Chevy C20
Old 04-26-2011, 04:26 PM   #17
JORGIE95961
no bud i dont
Old 04-26-2011, 05:12 PM   #18
dadsworktruck
This might shed some light to what you may have, now all you got to do is contact the company and ask about new horn cap, with either chevy on it or plain,,,,also might pay attention to wheel asembly i think it isnt correct, imo,,,also might need the part that has the wire that connectes to the horn cap......don
Old 04-26-2011, 10:00 PM   #19
emil77
Originally Posted by JORGIE95961 View Post
no bud i dont
Which year Cavalier wheel did you use?
Don, thanks for the info!
Thanks,
Emil
1972 Chevy C20
Old 04-27-2011, 09:05 PM   #20
emil77
My father and I fixed the steering wheel, good as new! There's a pic to show what we did.
Thanks,
Emil
1972 Chevy C20
