Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 06-27-2011, 01:12 AM   #1
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Post your best budget mods! ($50 or less)
Double the value of beater by making it a shop truck!
Cost of mod: around $20*
*Must already be skilled and cunning in the art of redneckery!
http://67-72chevytrucks.com/vboard/s...d.php?t=333485
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline
Old 06-27-2011, 01:18 AM   #2
67_C-30
67_C-30's Avatar
Got a hole in your truck in a place it doesn't belong? I show you how to fix it for less than $5!
My trucks
67_C-30 is offline
Old 06-27-2011, 01:25 AM   #3
67_C-30
67_C-30's Avatar
If somebody spray paints the door of your beater -don't let it get you down - I got you. I got you!
http://67-72chevytrucks.com/vboard/s...=288990&page=2
My trucks
67_C-30 is offline
Old 06-27-2011, 10:18 AM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I loved watcing you build that truck ^
John
1999 Toyota Tacoma 4x4
oldblue1968chevy is offline
Old 06-29-2011, 03:33 AM   #5
true74enduro
dunno if it quite qualifies scored this seat upholstery from this interior guy i live by for free. its blue sude and tanish vinyl.
true74enduro is offline
Old 06-29-2011, 09:30 PM   #6
oldblue1968chevy
Whats so much more special about the corvette vac can? jw not trying to be smart...
John
Old 06-29-2011, 09:37 PM   #7
70BLAZERX2
It had a totally different power curve in it..for the vette camshaft.
It dont hurt to ask..
It will wake up even a 86 stock 305 in a 4x4...make it pull like a 350...Yes it does work..and its cheap.
70BLAZERX2 is offline
Old 01-04-2012, 08:03 PM   #8
BIGKEV
This short read will shed a whole lot of light on the subject!
http://outintheshop.com/faq/Vac%20Adv%20Spec.pdf
BIGKEV is offline
Old 01-04-2012, 10:00 PM   #9
hugger6933
For those of you that kinda know me or of me would'nt be suprised to find out that this a bodyshop cheapee. Take an old coffee maker out to the shop plug it in fill'er up in about five min. you are ready to wetsand with warm water. It is very usefull in the winter months and I tryed it not long ago thinking why have I not done this sooner. Wetsanding is a miserable enough as it is without having to dip your hand in freezing water! cost on this tip $00 if you have an okd one but even if you don't and need to do this 20 bucks at a dollar store will put you in bussiness
hugger6933 is offline
Old 01-04-2012, 10:10 PM   #10
mrhino
Originally Posted by hugger6933 View Post
for those of you that kinda know me or of me would'nt be suprised to find out that this a bodyshop cheapee. Take an old coffee maker out to the shop plug it in fill'er up in about five min. You are ready to wetsand with warm water. It is very usefull in the winter months and i tryed it not long ago thinking why have i not done this sooner. Wetsanding is a miserable enough as it is without having to dip your hand in freezing water! Cost on this tip $00 if you have an okd one but even if you don't and need to do this 20 bucks at a dollar store will put you in bussiness
nice!
mrhino is offline
Old 08-14-2013, 03:12 PM   #11
twisty
twisty's Avatar
Get a HEI distributor advance curve kit...change it to the lightest springs in the kit and get a 1977 corvette vacuum advance unit.
These 2 will cost about $35 and will gain use about 15 horsepower out of your smallblock with about 30 minutes to put them in...and you will feel the difference it will make..Under $50
is there a diagram for the vacuum line set up for the 250 i6 motor? mine is all disconnected, id like to replace all the lines and stuff, may as well get the better can and stuff while im doing that.
twisty is offline
Old 06-29-2011, 09:32 PM   #12
capev86
i bought LED replacement bulbs for the dome lights in my 72 burb c20 ($10 each) but glad to hear LED's for the instrument cluster are available on ebay.
i went with CPP sway bars, but if you have a 2wd, the 1-1/4 sway bar from an 80's 1 ton or camper special chevy/gm 2wd is the perfect upgrade for the 1-1/8 bar available on our trucks (grab the frame brackets if you don't even have a front bar). should be able to get poly bushings pretty cheap too.
as for my burb, spent big money on a 4 core radiator and all new mounting hardware, but the 7 blade fan from my dad's 72 burb (w/ air) was free as he'd had it up in the attic for over 20 years and the radiator overflow bottle was a universal never-installed unit found in the attic as well. hung it on the driver side of the rad support with a stainless screw and put a tiny black bungee cord (big assorted bungee package from walmart) around it to keep it stationary. nice not to have to fill up the radiator every time i drive it.
capev86 is offline
Old 06-29-2011, 10:18 PM   #13
bosco200
bosco200's Avatar
KMACD71 I stole your idea THANKS!!!!!
bosco200 is offline
Old 06-30-2011, 08:12 AM   #14
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Some of mine:
$25 - pair of 4" 3-way cheapo speakers from Walmart, piece of 3/4" plywood scrap I had laying around = stereo speakers I can actually hear my radio now!
$35 - 7 blade clutch fan from a '94 Caprice 350 at the boneyard - makes the truck much quieter and moves a TON of air - I've towed another car in traffic on a 90 degree day and the needle never goes above 180*. Had to tweak the blade ends a little with an adjustable wrench to prevent rubbing on the shroud.
$15 for a reservoir at the junkyard, a little scrap metal I had laying arounf, and $10 for a new radiator cap - closed cooling system. No more catch can, no more spilled coolant, and no more topping it off once a week. Best idea I ever had.
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline
Old 06-30-2011, 06:40 PM   #15
FLDBRED
This is a great thread,I am already going to use some of the ideas!
FLDBRED is offline
Old 06-30-2011, 07:23 PM   #16
Southcity
Southcity's Avatar
Fabbed up a new shift lever from some scrap my buddy had laying around his welding shop. Started with a piece of 3/4 round, heated it up, made some bends, rattle canned it with primer and paint and then installed it, took just a few hours - total cost $12.00 for a six pack and two bags of chips.
AT THE SHOP
WHAT WE STARTED WITH
HEAT & BEND
BEFORE
AFTER
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline
Old 07-03-2011, 01:22 PM   #17
Heavy Evy
born to lose
Heavy Evy's Avatar
AT THE SHOP
Attachment 768053
Attachment 768055
HEAT & BEND
Attachment 768060
BEFORE
Attachment 768061
AFTER
Attachment 768062
pure awsome!
_____________________
'67 Chevy Belair Wagon 283 Powerglide
'68 Chevy II Nova 2 door 350 TH400 Sold!!
'71 Chevy C20 350 TH350
'71 Chevy C10 Burb 350 TH350 stolen totalled gone....
Burb Build
http://67-72chevytrucks.com/vboard/s...d.php?t=475155
Nova Build
http://67-72chevytrucks.com/vboard/s...d.php?t=498979
Wagon Build
http://67-72chevytrucks.com/vboard/s...d.php?t=543052
Not giving a truck.
Heavy Evy is offline
Old 07-20-2011, 09:37 PM   #18
swierker
swierker's Avatar
About to be another theft of ideas. I think I'm gonna do this.
1970 Chevy LWB - 305/350
In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's.
swierker is offline
Old 07-17-2011, 10:05 AM   #19
cjohnson6772
cjohnson6772's Avatar
Sunday morning bump!
cjohnson6772 is offline
Old 07-17-2011, 10:34 AM   #20
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I am amazed not only that this thread is still going (it died a horrible death on the other boards I posted it on) but also at some of the stuff posted.
Longhorn Man is offline
Old 07-17-2011, 05:47 PM   #21
oldblue1968chevy
I love it!
Heres one:
How to get your whitewalls clean and white again with stuff you (or your wife gf whoever) might have around the house.
Commet cleaner (I found it under the sink) on a scrub brush with a little water does wonders on the white letters on my tires and the whitewalls on the car!
John
Old 07-20-2011, 10:11 PM   #22
Mayo
Cool Truck
Mayo's Avatar
I love it!
Heres one:
I will have to try that, I just got some white letter tires for the first time.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline
Old 07-17-2011, 06:22 PM   #23
frednoah
86 Scottsdale
My new console:
I got tired of not having a place to sit a cold drink down while driving back and forth to physical therapy, so I began thinking about building myself a console. I took a bunch of measurements, made a pile of sketches, and finally settled on a design.
I've got about $35 in the whole thing, and about 2-3 hours of labor making it. Materials were:
2 pieces of 2ft square 1/2" pine (if memory serves...)
1 stick of 2"x2"x8' furring strip
3" hole saw
Package of small finishing nails
Some wood filler putty for the seams
Two plastic cup holder inserts like you'd see on boats
Free quart of black paint I got from a Glidden promo online
It is 12" wide, 14" long, and goes from 11"(at the seat) to 13" tall. Down the road I may pull it out and integrate a 10" subwoofer into the design, but just holding a drink and my phone will do for now.
frednoah is offline
Old 07-20-2011, 08:31 PM   #24
dukcaln
dukcaln's Avatar
Hmmm... now I know what I am going to do with this too... add a sub right behind the cup holders... been wondering about this and now I will surley use this... thanks frednoah
Originally Posted by frednoah View Post
My new console:
3" hole saw
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline
Old 07-17-2011, 10:06 PM   #25
texastruckjunky
texastruckjunky's Avatar
This is great. Some good ideas, i will be useing some of them for my truck. Keep them coming.
texastruckjunky is offline
