05-31-2011, 06:54 PM | #1 |
the boat guy
pulling my hair out. Front bumpstops!
67 crossmember 76 everything else front end. I'm spending more money on bumpstops than gas these things won't stay in. I've evn ruined 2 good tires. Only the drivers side falls out 5th one in 6 months I'm using energy suspension poly bumpstops I've tried glueing them in I've tried screwing them in. I'm about to run some steel through one and weld it in. It does touch the bumpstops at ride height. I love the way it rides and handles with this setup I just cant make it last. Do I need to bite the bullet and get nw springs shocks and some drop spindles.......
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
05-31-2011, 09:04 PM | #2 |
Happy to be here
Re: pulling my hair out. Front bumpstops!
I see in your sig you have a 4/6 drop. How was that acquired up front? You will probably need to remove the B/S mount and build a new one.
05-31-2011, 09:08 PM | #3 |
the boat guy
cut springs in front. Drop springs out back.
factory bumpstops didn't fall out, they rotted and split. |
05-31-2011, 11:12 PM | #4 |
Get more factory bumpstops. I picked up new ones @ my local dealership around 09.
06-01-2011, 07:12 AM | #5 |
Who Me?
Is your truck riding on the bump stops all the time?
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
06-01-2011, 08:18 AM | #6 |
Damn, 4" is a lot to cut out of a spring.
Doug Looking for a 67-72 short bed driver..... |
06-01-2011, 08:47 AM | #7 |
Happy to be here
That's why I asked. That's 2x to much drop from a front spring. Your pounding the snot of of the stops.
06-01-2011, 09:57 AM | #8 |
Junior Member
yup... need to be dropped like that with conjunction of spindle and spring. Dont need to ride on the bumpstop either. when you do that you are not getting enough suspension movement and the stops are taking the load.
06-01-2011, 10:36 AM | #9 |
HOLY smokes batman!!
4" cut off the front spring??? you need to buy a 2" drop spring along with a 2" spindle to remedy this. Good luck!! |
06-01-2011, 10:53 AM | #10 |
Each of my previous rides had 1-coil cut from original springs (2-3" drop). On the 68, I had about .500-.750" clearance between the bumpstop & x-member. On the 74, it was .500" max.
06-01-2011, 01:47 PM | #11 |
the boat guy
riding on them not so much but def no clearance.
even sitting on the bumpstops the trcck rides pretty nice. Way better than the wet sponge it was before. drill holes in the bumpstop to make it more pliable?
06-01-2011, 01:53 PM | #12 |
the boat guy
no luck w local dealer for original rubber bumpstops.
06-01-2011, 04:48 PM | #13 |
How much can you cut out of a 2 inch drop coil from early classic?
Posted via Mobile Device Last edited by Brandonc20; 06-01-2011 at 04:49 PM. |
06-01-2011, 05:57 PM | #14 |
That's a vague question. If it's a 2" drop, & you cut 1-coil, your @ approx 4-5" of drop which is too much 'spring only' drop. You would need to cut less but how much is dependant on age of springs & vehicle weight (there's no 1 right answer).
06-01-2011, 09:25 PM | #15 | |
Posted via Mobile Device |
06-01-2011, 09:32 PM | #16 | ||
06-01-2011, 10:38 PM | #17 |
Happy to be here
I disagree. You prove my point with your answer below.
06-01-2011, 10:42 PM | #18 | |
My comment.....
06-01-2011, 11:34 PM | #19 |
Don't I need disk brake if I want to use drop spindles
06-02-2011, 08:37 AM | #20 |
Happy to be here
Yes, you will need to convert to disc brakes to run dropped spindles.
06-02-2011, 09:42 AM | #21 |
... oh the joys of doing something half-a%%
06-02-2011, 01:34 PM | #22 |
the boat guy
half an butt is all I have left. Building a house, keeping the boat running and fed, plus a handful of other hobbies and a woman thats out of work doesn't leave me in a real good position to be buying a new suspension for my truck.....that I have to drive to work.
06-02-2011, 05:29 PM | #23 |
all I am saying is if you keep buying bump stops then eventually you will have spent what it would have cost to do it right the first time.
Buy once. Cry once. Go cheap. Forever weep. |
06-02-2011, 06:37 PM | #24 |
needs more $$$
I take it that you find out the bump stop is gone when you start feeling the metal-to-metal thud on the drivers side? Is cutting the bump stop mount all the way off and adding one directly on the control arm out of the question?
I don't know if this will allow too much travel in the suspension though in your situation...
1970 2wd Blazer |
06-02-2011, 07:45 PM | #25 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
