06-16-2011, 07:07 AM | #1 |
Dyno'ed 768hp 1305ftlbs & ran a 10.99@122
Took my truck to the dyno last week and it dyno'ed 768hp and 1305ftlbs @ the rear wheels. The truck has a stock bottom end Duramax diesel engine in it with twin turbos. After the dyno I took the truck to the track and it ran a 10.99 @ 122mph. I need to work on the suspension because the truck pulls hard to the right on take off. Not sure how you get the video's on here but this is the link to them
1969 C10, 2005 LLY Duramax, Wagler Competition built motor, Bullseye Power triple Turbo's, Rossler th400, Neal Chance Racing Converter, Danville Performance tunning. 8.3@168mph 1700+ HP |
06-16-2011, 09:13 AM | #2 |
meowMEOWmeowMEOW
Re: Dyno'ed 768hp 1305ftlbs & ran a 10.99@122
nice torque outta that Dmax!
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
06-16-2011, 11:59 AM | #3 |
On a budget like Fred Sanford
That is SICK truck sir. Well done!
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
06-16-2011, 12:06 PM | #4 |
BAD ASS
06-16-2011, 12:40 PM | #5 |
I love it!!
06-16-2011, 01:05 PM | #6 |
Always a work in progress
DAMN I wish I could go to youtube out here!!!
It sounds like an awesome truck!!!
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
06-16-2011, 01:08 PM | #7 |
love hearing all the boost whistle down the track
06-16-2011, 01:15 PM | #8 |
Any pictures of the install? How hard was it?
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
06-16-2011, 09:34 PM | #9 |
Awesome truck but the only late model bed I have ever liked is the one Mike Nutt did for his truck.
I would love to do a duramax 3/4 ton Suburban.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
06-16-2011, 11:05 PM | #10 |
60-66 Nut
That is very cool
Do you have any engine bay pics, or any build pics?
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 06-16-2011 at 11:06 PM. |
06-16-2011, 11:14 PM | #11 |
Very nice my friend! Alot of work and alotttttt of money spent on this rig~~~!
06-17-2011, 12:33 AM | #12 |
That is just sweet!!! I've always thought that the duramax should be installed in one of these pickups. Big enough engine bay to actually work in and one of the best body styles GM made.
Looks like you might be giving Orange Crush a run for its money soon!! And pretty much smoke free. Orange Crush is the only other Duramax swap I've seen. Again great work!! Thomas |
06-17-2011, 07:25 AM | #13 |
It took me 7 months and 1200hours to do the swap. That is fabing everything for the motor and trans mounts, all the frame work, the wiring, and installing a GM 14 bolt rearend with coilovers. I tryed loading pictures but it was taking way to long. I will try later.
06-17-2011, 07:29 AM | #14 |
I guess it worked. The first one is of the bus I bought to get the engine and trans and all the wiring. The secound one is of the fire wall. I had to push it back all the way to where the dash comes down. The next one is of some of the frame work, and finally the engine bay last year with out the secound turbo. I need to get some pictures of the engine this year with the secound turbo.
06-17-2011, 07:55 AM | #15 |
Holy cow nice fab work! That thing looks like it belongs in there...
06-17-2011, 02:46 PM | #16 |
How much does the duramax weigh?
06-17-2011, 04:18 PM | #17 |
60-66 Nut
Yes that does look nice under the hood, you did a very nice job
Did you use the 10.5 FF 14 bolt or the 9.5 SF 14 bolt?
06-17-2011, 09:33 PM | #18 |
nice.... that firebird prob. was a bit suprised.. lol
06-17-2011, 11:19 PM | #19 |
Nice Job!! What are you using the air compressor for? Its in the way if you put a second CP3 high pressure pump on
06-17-2011, 11:54 PM | #20 |
VA72C10
great work and nice et!!! Now you have a truck that runs 10's
Looking for a 67-72 swb or blazer project in or around VA. |
06-18-2011, 08:11 PM | #21 |
The duramax weighs the same as a big block. The Allison trans is whats heavy, it weighs 360lbs. The whole truck weighs 5300lbs.
06-18-2011, 08:16 PM | #22 |
I used the 10.5 FF axle but I had the ends cut off and Ford big bearing ends welded on to it. Moiser makes custom axles and a spool for it.
06-21-2011, 05:12 PM | #23 |
06-21-2011, 11:33 PM | #24 |
made in america
that is awesome. runs tens and probably gets 30 mpg. two thumbs up for sure
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes. sounds good 1964 c10-283 powerpack, 3 on the tree 2004 corvette- lowered, borla, tuned. slow my old girl 1966 c10- 305v8, t-5 sold |
06-22-2011, 10:25 AM | #25 |
Very nice again! Since it was mentioned, I'm curious now. What kind of mpg's have you seen or is this strictly a track only toy?
