Old 06-16-2011, 02:44 PM   #1
67chevyc10719
67chevyc10719's Avatar
Question new to the site.. new to the 67 chevy world! CHECK OUT MY 67!
SO I PAID 1600 BUCKS FOR IT.. NO CLUE WHAT ITS WORTH..! I NEED YALL HELP.. I WAS TOLD MOTOR IS REBUILD AND THE TRUCK RUN GREAT! SUOER STRONG AND IT SHIFT AWSOME.. (HAS SHIFT KIT I WAS TOLD)WE THE MOTOR IS CLEAN AFTERMARKET INTAKE MANIFOLR K&N FILTER ANDCROME VALVE COVERS.. AND A EDELBROCK CARB CODE 3867 NOT SURE ON CFM.. STOCK RAM HEADERS.. LIKE I SAID IT RUN STRONG AND ALL IT REALLY NEED IS TO SERVICE OR FIX BRAKE.. THOSE DRUM BRAMES CANT STOP THAT 350.. SO DID I DO GOOD AT 1600.00?
67chevyc10719 is offline   Reply With Quote
Old 06-16-2011, 02:59 PM   #2
67chevyc10719
Re: new to the site.. new to the 67 chevy world! CHECK OUT MY 67!
the engine bay..
Old 06-16-2011, 04:46 PM   #3
lowdown72
lowdown72's Avatar
nice truck great deal looks like a really clean start welcome to the board
72 c-10 67 clipped 327 th400
lowdown72 is offline   Reply With Quote
Old 06-16-2011, 05:42 PM   #4
67chevy1series
67chevy1series's Avatar
i need to see the interior before i can judge and the bed and passenger side... it has a 68 front clip on it..
67chevy1series is offline   Reply With Quote
Old 06-16-2011, 06:04 PM   #5
David67
David67's Avatar
Welcome to the board! 67 small window stepsides are the best
'67 C10
David67 is offline   Reply With Quote
Old 06-16-2011, 10:13 PM   #6
Hduramax
Hduramax's Avatar
welcome
2008 HD
2010 Camaro 2ss (The Wife's Ride)
2005 Suzuki GSX-R 1300 "Busa"
1969 C-10 (under Construction)
2013 Sonic LT
"LIVE LIFE,TASTE DEATH"
Hduramax is offline   Reply With Quote
Old 06-17-2011, 01:55 AM   #7
67chevyc10719
thanks guys.. the interior need work for sure..ill post pics..
Old 06-17-2011, 02:27 AM   #8
67chevy1series
well no matter what it looks like we like it and want to see it
Old 06-19-2011, 12:19 PM   #9
smoke1991
Welcome to the board another Colorado truck I was going to buy that truck but found a 71 cheyenne nice looking truck
smoke1991 is offline   Reply With Quote
Old 06-21-2011, 12:33 PM   #10
Matt67C10
Matt67C10's Avatar
Welcome to the board and congrats on the great find! I think you did very well...
67 C10 LWB Stepside- 250cid 6, 3speed
Matt67C10 is offline   Reply With Quote
Old 06-21-2011, 12:38 PM   #11
LockDoc
The Older Generation
LockDoc's Avatar
Great find. That is a nice looking truck. If you would put a power brake booster on it I'm sure that would help the braking part. Pretty easy to do.
LockDoc
Leon
Old 06-21-2011, 11:06 PM   #12
67chevyc10719
well i hit the brake and it goes to the left.. the harder i press the brakes the more it turn left.. would that brake booster or one of the brake cylinder..? and i found out it has an aftermarket light cam.. and its a th400 that is shiftling kinda low.. my buddy says to swap govern spring inside the transmission..
Old 06-22-2011, 06:10 AM   #13
Nice truck,good deal. Just fix the brakes and they'll stop the truck. Power brakes work even better. Drum brakes aren't as bad as some believe. That semi on your tail is running them
Old 06-22-2011, 08:43 AM   #14
1972RedNeck
1972RedNeck's Avatar
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 06-22-2011, 11:31 AM   #15
67chevyc10719
rear shot..
interioris where most of work needed.
mug shot:
my old project:
Old 06-22-2011, 11:34 AM   #16
67chevyc10719
where is the bestplace to star orderin parts for this thing.. i would like to work on the brakes and on the interior first.. i dont want to make this into a lowrider nor a all out track rce car.. its just going to be a nice weekend cruser to take the wife out to a movie or dinner kinda thing.. but where is the best place or ordering parts..?
Old 06-22-2011, 11:37 AM   #17
67chevyc10719
also my blinker dont work.. they switch to position of them workin but te light stay on while they are suppose to b blinking is it the swich?
Old 06-22-2011, 11:41 AM   #18
JORGIE95961
Bulbs, and groundstarps
JORGIE95961 is offline   Reply With Quote
Old 06-22-2011, 11:44 AM   #19
JORGIE95961
FOR THE BRAKES YOU CAN PROBABLY JUST GO TO YOUR LOCAL AUTO PARTS STORE. If you have drums up front its pretty common to swap to disk.. Folks say theyre better stoppin.. but either way.. for th e bullin part. just redo the brakes and blush out your lines.
Old 06-23-2011, 10:31 PM   #20
Average Joe
Average Joe's Avatar
1600 bucks ya done good. I just added a power booster to my 67 burb with factory drums. The difference is night and day from manual. You can use a later model booster ie 73-87 if you want a more compact unit than factory. Just lenghthen the pushrod by about an inch. Try adjusting the brakes if one side is pulling. If all else fails you might consider a full brake job on the front and back with new wheel cylinders and turn the drums if needed.
Average Joe is offline   Reply With Quote
Old 06-23-2011, 11:14 PM   #21
o6r1man
o6r1man's Avatar
Nice find!!!
1970 SWB "old flame"
1967 SWB c10 sold
1972 Elcamino 496
2012 Denali HD dmax
o6r1man is offline   Reply With Quote
Old 06-23-2011, 11:37 PM   #22
jbclassix
Junk Yartist
jbclassix's Avatar
I saw that truck on CL! Good score! JORGIE95961 is right about your blinkers. You need the bulbs and ground straps for the blinkers to work right. There are a few guys on this board that live out in falcon, they may be very helpful for the parts that you cant get at the parts store, like the interior...
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 06-24-2011, 12:42 AM   #23
heeroyue2002
fat old dude
heeroyue2002's Avatar
nice truck. im having the sme issues with the blinkers i believe. Rick is right about the 68 front clip.
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 06-24-2011, 12:52 AM   #24
BlackTopMotors
Welcome. Looks like a good deal.
One step/issue at a time and you'll be good to go.
I'd solve the safety issues first like braking, lighting...
This is a great place to find answers/help.
BlackTopMotors is offline   Reply With Quote
Old 06-24-2011, 02:01 AM   #25
67chevy1series
well the interior looks virtually untouched so you should be good... watch out buddy 67s ahave a lot of one year only stuff for more details you may pm me
