Old 10-08-2012, 01:08 PM   #1
Low Elco
Re: My '67 Fleetside C10 renew
Oh yeah, git to the pawn shop! How the hell ya gonna paint without ZZtop and Foghat blasting? That just ain't American!
Low Elco is offline   Reply With Quote
Old 10-08-2012, 01:15 PM   #2
jlsanborn
jlsanborn's Avatar
Originally Posted by Low Elco View Post
Laid down good! BTDT= Been there, Done That. I always go bc/cc because something ALWAYS goes bad. Easy fix, a little sandy sandy, it's all good! Like I say, I'm a so so painter, but a HELL of a polisher. Long as I can halfway get it on right, it's all good! Like I said, just relax. Know things are gonna go in the crapper, and be calm when they do. It'll all be good, in the end. You've made the first jump off the cliff, it's all downhill from here!
Thanks for more good advice! I'll get a few better pics today after work. Wifey and I always go down to the tav for Monday Night Football, so prolly no truck time today. I work down here in the hood, so there's about ten pawn shops within five blocks! I'm going to look on my lunch hour.
If I put expoxy down, let it flash then hit it with hi-build, think I can let that sit for a while before I sand it and topcoat it or should I do the BC/CC right away?
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 10-08-2012, 04:35 PM   #3
jlsanborn
jlsanborn's Avatar
Them buggers are PROUD of the junk they've got laying around!!! Too rich for my blood. Couple decent Yamaha's, but $100 and its missing the volume knob!? Found a craigslist jewel and am waiting for a call-back.
Old 10-08-2012, 07:31 PM   #4
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
Hey Johnny ! I think everything is lookin Good !! you will like bc/cc much better. easier to work with. Listen to Low elco, you can fix whatever might go wrong.
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
Old 10-08-2012, 07:59 PM   #5
jlsanborn
jlsanborn's Avatar
Thanks again guys! I'm convinced - BC/CC it is. Now, what product specifically???? The Boy gets a decent student discount through NAPA so I'm thinking that. What would you pay for a gallon of color (with the stuff) and a gallon of clear (with the stuff). They have all sorts of different products! What to get!? Plan is to epoxy everything. I'll paint right on that in places that I ain't gonna block, but I'll let it cure first then scuff it with the pad. As for body panels and such, don't you think a hi-build and more sanding will be worth the time??? I know you can't see my handy work, but it's pretty damn smooth (P180).
Got home today and pulled the wheels outta the fun-dome. They look pretty damn sweet to me! Tiny bit of orange peel, but nothing I'm gonna squirm over. The Boy will mount and balance on Wednesday! The first few parts I sprayed look like a$$. Underside of one inner is gonna have to be what it is, cuz I don't really give a rat's arse about under there. Front side of the rad support is also kinda crappy, but same deal. One topside of an innner is probably too ugly for me to swallow tho. I'll sand that sucker and re-coat.
Thanks again for the help and encouragement!!!
Old 10-08-2012, 10:14 PM   #6
Bomp
Bomp's Avatar
Things look great and your gettin it on. Great Plastic House !
On my make shift booth I have an air inlet with a furnace filter vent. Basically a square hole to allow clean air in while dirty air gets sucked out. I use a squirrel cage with the motor on the outside. The squirrel fan is away from the booth and connected to 2 10' pieces of 4" plastic pipe(Home depot garden center). Try to keep the fumes away from any ignition source(electric motor). Maybe a bit overkill but I ain't never been blowed up.
Keep on Sprayin,,,,,,Looks Good!
Bomp is offline   Reply With Quote
Old 10-08-2012, 01:10 PM   #7
FrankieD
FrankieD's Avatar
I think your problem with the orange peel is either too low of air pressure or the paint is to thick. I know we all want it to cover in 1 coat but 2 or 3 thin coats work better and wait for the paint to flash or it will run from the wet build up. I went to this site and they will answer your painting questions. http://www.autobody101.com/content/
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 10-08-2012, 04:27 PM   #8
jlsanborn
jlsanborn's Avatar
I think you're right there FrankieD. After I bumped the pressure up a little things went a lot better, but WAY too fast! I wanted to thin the paint some but wasn't sure if I could reduce it with laquer thinner??? The good news is that it layed down pretty good and I'm done with that color (well, almost). I think I'm going to follow Elco's advice and use a BC/CC for the pretty stuff. Thanks for chiming in!!
Old 10-08-2012, 01:22 PM   #9
Low Elco
Nope, let the epoxy dry good. Scuff with red scotchbrite and shoot paint. Scuff with 150 of going to slick sand. It needs tooth like Bondo does.
Old 10-09-2012, 08:20 AM   #10
Low Elco
For temps, I generally crank a propane heater (Mr. Heater) while I prep and get it as hot as possible, then blow the doors 1/2 way and hit the fans while I base, all the way while I clear, keep 'em open while I clean guns, then close up and flip the heat back on. I'm kinda paranoid of the sparky. On Yeller, I used Nason epoxy primer ($80 1/2 gal) Slick Sand Primer ($75 gal.) Dupont Chromabase (around $300/gal, but mixes 1/1, so 1 gal of color + 1 gal of reducer will almost do a whole truck) and Nason Clear ($140/gal.) I like Bomp's plan for venting. BTW, Bomp, you are KILLING me with your name! I had to blast Pantera all the way to work and I STILL have that damn doo-wop song in my head, and I HATE doo-wop! Well played, sir! Go to Napa and see what they carry. Lotta times they can get stuff they don't show. If your're just gonna paint bare metal parts with no sanding, you can hit it with Nason etch prime ($40/half gal.) let it dry a bit and scuff with scotchbrite and base/clear or whatever straight over it. Works great. Just get the gun in your hand and remember what Mike Lavallee (the originator and King of Truefire and a damn nice guy) says, "It's just paint. If it goes bad, I can sand it off and do it over. It's just paint."
Old 10-09-2012, 12:11 PM   #11
jlsanborn
jlsanborn's Avatar
c'mon, let's go to the hop, oh baby!
Been thinking about a better ventilation system. I'll have to go see what Pa has in his shed for squirrel cage fans. I've got a bunch of 4" flexy tubing left over from my retaining wall project. I'll also run down to the Napa paint store today at chow (if I can get away) and see what they recommend. Last time I was in there it seemed that they didn't have much patience for the amature painter.
Old 10-09-2012, 11:09 PM   #12
Bomp
Bomp's Avatar
Your gettin it. I try to stay around 70* when I spray. My paint guy said that if I heat up the area with the paint and stuff(parts) in the same room. That way if I do have a drop in temp the part is still warm and so is the products inwhich I am using. The parts and paint are working with you (warm) and not against you(cold). An obvious thing but I would have never thought of it.
Thanks but...ah...I know who Pantera is but just can't place the song. My daughter was listening to KidRock and the Bomp-diddy-bomp song and....well........rest is history.
Later Dudes......You all Rock!!!!!
Old 10-09-2012, 11:33 PM   #13
jlsanborn
jlsanborn's Avatar
Thanks Bomp! Any progress on the stretch?
Got home today and knocked down all the crappy parts. Mixed up the last of my black and re-sprayed. MUCH better results, but still the paint is too thick and nuthin to reduce it with. I'll have to get a little more of that to do the underside of one inner and my vent window frames (thanks for reminding me John!!!). I'll prolly put one more coat on the topside of the inners while I'm at it. I followed some advice and left the shop vac off while I was spraying. I just left the fun-dome door cracked until it went dust free then opened her up with the roll up doors open. Let it clear out then lit a fire. One thing I still need to learn is the SLOW PART. I think half my battle is having too much $hit going on in there at once and I'm getting overspray on my nice stuff. How long will a mixed batch of urethane last? Seems like a waste to mix up small portions.
The Boy has my wheels and rubber loaded into the S10 and will get those mounted and balanced tomorrow. Pics to follow!!!!
Big Brown Santa showed today with the first load!!! This is the LMC stuff I ordered. The bulk of my stuff is coming from GMC Paul and should be here on Thursday. One of the outside handles has a big-o flaw so I'll be sending that sucker back to Taiwan.
The carpet kit is sweet and so are the '67 arm rests. Also got pretty much all new screws and washers to assemble the doors but they're hard to see in the photos.
Oh, and the craigslist deal on the tuner/amp fell thru. Still no damn tunes!!! Might just have to go take my phukin on that Yamaha tomorrow.
Catch you all later!
Old 10-10-2012, 07:15 AM   #14
XxCHEVYMANxX
Ahhhh ! new parts. Johnny most paint I use whether ss or b/c has a pot life @ 4hrs. house of kolor says indefinite if I remember right. anyway happy painting !
John
Facebook LoL
Old 10-09-2012, 12:17 PM   #15
67cheby
67cheby
67cheby's Avatar
i dig the wheels
67cheby is offline   Reply With Quote
Old 10-09-2012, 02:35 PM   #16
jlsanborn
jlsanborn's Avatar
Thanks Mike! One buddy says pinstripe another thinks trim rings, but I really like the plain-jane, poverty caps and a nice shiny balancing weight! With a little luck I'll be putting some color down on the cab this weekend!! So stoked! It's super motivating to see your bad ride come together. Man I wish I was big window - jealous!!!!
Old 10-10-2012, 01:11 PM   #17
jlsanborn
jlsanborn's Avatar
LMC customer service is stellar! Called about the blem in my door handle and in about 2 seconds they're sending me a new one. No questions asked and they don't even want me to send the old one back. They'll get my recommendation just for that! Thanks LMC!
Old 10-10-2012, 01:56 PM   #18
XxCHEVYMANxX
Right on Johnny ! I called 'em last week about my mirrors that I ordered over a year ago. I had only checked everything for damage, and to make sure it was all there. got my mirrors out last week, and it sounded like there was loose bits rolling around between the mirror/chrome back. they looked up my order #, and sent a pair of new ones. no charge ! they didnt want the other ones back either.
John
Facebook LoL
Old 10-10-2012, 02:04 PM   #19
jlsanborn
jlsanborn's Avatar
Just went and met the Boy and got my wheels and tires from him! They look sweet!!!!
After work I'll scrub all that blue soapy crap off the letters and throw them on for a look. Picutres of this thing OUTSIDE for ya'll by 6:00!
Old 10-10-2012, 09:37 PM   #20
jlsanborn
jlsanborn's Avatar
Got some awesome photos but the kids are lined up at the computer and Wifey has chow just about ready. Stay tuned!!!!
Old 10-10-2012, 09:46 PM   #21
Bomp
Bomp's Avatar
And Waiting......
Can't get to the shop til Saturday. Swapmeet is a no go for me.
Old 10-10-2012, 11:03 PM   #22
jlsanborn
jlsanborn's Avatar
Kay, just a few things then the pictures!!!!
We now have a hubcap model looking for a job. Anyone hiring? He'll paint his fingernails if needed. He's hard up. That blue $hit they spray on the white letters ain't like it used to be! I scrubbed with hot, soapy water and a brush for EVER and it would NOT come off. I ended up using that kick-a$$ degreaser on a scotch-brite to get the crap off. It's still on the sidewalls. The big-boys didn't even have that crap on them. I also noticed that the "finish" on the letters wasn't as good. They must be making the 295s offshore these days
Got another load dropped off today from GMC Pauls. KILLER STUFF!!! GM certified restoration emblems, their polished stainless threshold plates, killer repro mirror, Precision cab rubber, full dome light kit and some other stuff. Still waiting on my polished stainless outside mirrors, headlight bezels and grille trim. Still have to order my rear cab moulding / paint divider. The truck looks BAD A$$ and the parts I just got are BAD A$$. It's going to look exactly what I wanted it to. 60's muscle!! I'm sooooo stoked to paint this thing and build a nasty little THEE-TWO-SEVEN to bolt that Muncie onto!!!! Historical day today at the house!! It's a roller!
PS. I hadn't gotten around to painting and installing the new tie rods. That sucker was NOT going to just roll out of the shop for photos that way so I had to finger-tight the old greasy $hit on there to get it out. Just pushing it forward ten feet was like SQUEEEEEEEEEEECH! We'll need an alignment
Old 10-10-2012, 11:58 PM   #23
y5mgisi
Second Chance Program
y5mgisi's Avatar
Damn thats a clean chassis!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 10-11-2012, 01:05 AM   #24
67chevy1series
67chevy1series's Avatar
the rims tires caps and stance is just beautiful!
67chevy1series is offline   Reply With Quote
Old 10-11-2012, 08:41 AM   #25
Low Elco
Yaaay, a roller! Wheels look cool!
295/50-15, 327, butternut yellow, dog dish, muncie m20
