Old 07-06-2011, 10:01 PM   #1
Jamie McDavid
Jamie McDavid's Avatar
366 Big Block
Any of ou guys ever messed around with one of these before? I stumbled across one today and saved it from the crusher. I seam to be a sucker, I just cant stand seeing stuff get crushed... I know these motors were torque power houses but not so much on horse power. I think I'm going to clean it up and maybe drop it in one of my street toys to play around with and burn some rubber. Sounds pretty mean atleast...
White Lightning
Jamie McDavid is offline   Reply With Quote
Old 07-06-2011, 10:02 PM   #2
Stepper562
Stepper562's Avatar
Re: 366 Big Block
366 BB??? Never heard of it.
Stepper562 is offline   Reply With Quote
Old 07-06-2011, 10:10 PM   #3
S10Fan
Old Heap Driver
Re: 366 Big Block
Big trucks and school buses, I'd let it go.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 07-06-2011, 10:12 PM   #4
Jamie McDavid
Re: 366 Big Block
They were only used in big trucks and buses. I'm just wondering how it will do. I know there not a "performance" motor but in something much lighter than it was intended for it would have to shoot a little bit = )
White Lightning
Old 07-06-2011, 11:04 PM   #5
rwhit57
rwhit57's Avatar
Re: 366 Big Block
I remember some guys messing with one of those back in the 70's. Those motors are built for low end torque, and only rated at about 250hp. There are no performance parts avail for it, so you're stuck with a 250hp motor. Just about any stock 350sb puts out 250hp and will rev a lot faster and farther, and out run it all day. I wouldn't waste any time or $ on it.
rwhit57 is offline   Reply With Quote
Old 07-06-2011, 11:31 PM   #6
BigRed76
BigRed76's Avatar
Re: 366 Big Block
So it doesn't make a lot of power, but if you think its cool, then go for it. Thats what matters right? My dad put a 305 v6 in a '41 chevy, simply because it was different...
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 07-06-2011, 11:44 PM   #7
Warrens69GMC
Warrens69GMC's Avatar
Re: 366 Big Block
Grab the crank out of it, its forged steel and a 396 (3.76)stroke. Find a standard deck 454 and build a 427!!
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 07-06-2011, 11:52 PM   #8
Pyrotechnic
Pyrotechnic's Avatar
Re: 366 Big Block
They were basically designed to run at WOT all day in a dump truck. If anything, it's a work horse that will last a long time. I bet you could put a lot of miles on one before it would need a rebuild.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 07-07-2011, 06:34 AM   #9
BigBlocksRule
Re: 366 Big Block
Tiny bore for a big block - 3.935" - makes it hard to breathe!!! They were for economy on trucks and busses that didn't need to rev over about 4 grand, they're a LOT tougher than any smallblock. If you want a comparison, it's like a 350 vs a 305, it can be made to work but doesn't have nearly the potential of a 4.25" bore block. You'd have to bore this thing .065 just to get to the same bore size as a 350!!!
Snag the steel crank, truck rods and 4-bolt caps, scrap the rest.
Best part is you can push the pistons out the bottom of the block, bores are so small that the pistons won't even hit the main webs.
BigBlocksRule is offline   Reply With Quote
Old 07-07-2011, 07:51 AM   #10
Stepper562
Stepper562's Avatar
Re: 366 Big Block
Thx for the info guys. I never knew a 366 bb existed, I blame my dad and my age hehe.
Old 07-07-2011, 08:44 AM   #11
Dave
DND Trucks
Smile Re: 366 Big Block
This is absolutely true. Back in the day, if you wanted to build a bullet proof bottom end on the cheap for a 396 or 402, the 366 truck crank, rods and 4 bolt mains were the donor items to get. The 366 short block would fetch around 150.00 to 200.00 at the salvage yard.
Dave is offline   Reply With Quote
Old 07-07-2011, 09:16 AM   #12
100%Chevy
Re: 366 Big Block
It's a tall deck.
Built strictly for torque and heavy duty use.
Designed to last.
I've a 427 t.d.-Often used to build up to a 496,but expensive!
They're not for high revving.Most have governors mounted under the carb.
4 rings per piston for longevity.
You could use it and tell everyone it's a 454.Be hard to hide the huge intake manifold.Normal big block intakes won't fit because the .4" higher deck changes the intake to head angle and height.
Special intakes can be had,but cost $$$.
And there's spacer sets to mount stock intakes as is.
I also have a GMC,351 V/6.It's a great engine for hauling,pulling heavy trailers,etc.
I would keep it as is and stick in a corner,you might use it later!
Mike.
100%Chevy is offline   Reply With Quote
Old 07-07-2011, 01:59 PM   #13
S10Fan
Old Heap Driver
Re: 366 Big Block
Originally Posted by Stepper562 View Post
I blame my dad
He was just protecting you from headaches.
Bryan
Old 07-07-2011, 02:52 PM   #14
Stepper562
Stepper562's Avatar
Re: 366 Big Block
Haha I love these kind of headaches.
Old 07-07-2011, 11:46 PM   #15
Your41Plague12
Your41Plague12's Avatar
Re: 366 Big Block
I was just building one of these that I got for cheap when I made a rookie mistake and re-used the head bolts. Broke off flush in the block. Anywho, I'm basically posting in this thread to say that parts are just about impossible to find. If you have one that's complete, you should be ok though. They'll last just about forever, but you won't be getting anywhere fast.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 07-08-2011, 08:28 AM   #16
Pop's C-10
Pop's C-10's Avatar
Re: 366 Big Block
If you like & wanna save it...clean & paint it up real good & make it garage art...i've always wanted to do a motor like that
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 07-08-2011, 06:08 PM   #17
ECU PIRATE
ECU PIRATE's Avatar
Re: 366 Big Block
You can always throw the internals in your ride and bring them up to me in northern Virginia. I have a place for them
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 07-08-2011, 06:11 PM   #18
ECU PIRATE
ECU PIRATE's Avatar
Re: 366 Big Block
You can always bring the internals up to me in nova. I have a place for them..................
The Fleet........
Old 07-08-2011, 09:06 PM   #19
Desert1957
Desert1957's Avatar
Re: 366 Big Block
looks like a 454 , Runs like a high mileage 283....Junk
Desert
Desert1957 is offline   Reply With Quote
Old 07-08-2011, 09:17 PM   #20
S10Fan
Old Heap Driver
Re: 366 Big Block
Desert
I have a high mileage 283, slower than a coal train on a mountain.
Bryan
Old 07-08-2011, 11:02 PM   #21
rjn72
rjn72's Avatar
Re: 366 Big Block
you guys sure know how to make a guy feel good about something he already bought. I think along the same lines, I have stuff laying around that no one else wants now, but one day when I die and my great grandchildren find it it will be worth some jack. By the way I am 28 and my daughter is almost 2 just for perspective. But I hate to see things crushed when there is nothing wrong with it, just not desireable.
JESUS IS LORD
87 crew cab V30 454/400
rjn72 is offline   Reply With Quote
Old 07-09-2011, 07:31 AM   #22
Jamie McDavid
Re: 366 Big Block
Thanks rjn72!!! Haha
White Lightning
Old 07-09-2011, 08:25 AM   #23
BigBlocksRule
Re: 366 Big Block
Don't look at it as something being crushed...look at it as an obsoltete engine being recycled into a 6.0L LS engine!
Old 07-09-2011, 09:00 AM   #24
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 366 Big Block
try to sell it,heck if it's that rare they must be worth something to the "right" person
people convert busses to campers all the time
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 07-09-2011, 09:35 AM   #25
BigBlocksRule
Re: 366 Big Block
^ problem is they don't make good power for their size. A 427 tall deck would be a much better choice for that app.
I heard of a guy that used a 454 crank in one once, said it didn't pick up nearly as much power as he'd expected, the small bore really restricts airflow.
