Old 07-16-2011, 06:05 PM   #1
dropped71
cab
im going to buy a new cab today however it is a 69 and my truck is a 71. would everything fit correctly after the swap and would it bolt up to my frame the same way as the 71 cab?
dropped71 is offline   Reply With Quote
Old 07-16-2011, 08:06 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: cab
WELCOME! yes, everything should bolt up just the same. The cabs are identical. rad support is different but no change in the cabs....just make sure you're okay with swapping cabs in california.....they MAY be issues with putting it on the road with a cab with a changed out vin plate. The factory rivets were rosette style and can't legally be sold....
Old 07-16-2011, 08:09 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: cab
Thought the rad supports were the same from 69-72.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 07-16-2011, 09:29 PM   #4
69heavychevy
69heavychevy's Avatar
Re: cab
I believe its not an issue in CA, either way a quick google search will get you what you need...
69heavychevy is offline   Reply With Quote
Old 07-17-2011, 09:13 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: cab
the throttle linkage in 69 is a solid rod push throttle, and the 71 is a pull cable type.
The easy way would be to convert to the rod, but the cable is a better/safer set up. The firewalls aren't the same as far as throttle assembly provisions.
Old 07-17-2011, 09:16 AM   #6
1972RedNeck
1972RedNeck's Avatar
Re: cab
Don't '71's and '72's have a vent in the door jam?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 07-17-2011, 10:39 AM   #7
Longhorn Man
Re: cab
yeah, but it won't matter as far as making the cab work. 71 has a raised mounting pad for the rear view mirror (no other year had it) but again, it doesn't matter.
