72 2wd frame with junk body
Factory 2wd Blazer with no title, no interior, no top, no engine, no tranny. I'm selling the frame and the buyer takes the body. $800 I will sell parts off of what is there with the exception of the frame until someone buys the frame. let me know what you are interested in. I will cut patches. Windshield frame is good in some areas. 72BlckButy is first in line on the frame.
1972 K5 Auto 4x4 factory air 2007 Silverado extended cab Z71 |
Re: 72 2wd frame with junk body
more pics.
67-72 parts collector,…
![]() Join Date: Nov 2002
How nice is the fender in the floor of the blazer tub?
Can you post some better pics of it?
sorry the blue doors laying in the bed are not included.
I'm talking about the fender. Is it for sale?
#6 | |
there is a little surface rust on the fender and the front lower has a dent in it, not to bad. It looks as if the front of the fender next to the grill has some bondo in it from it being pushed in a little bit. someone tried to recreate the shape, pictures won't show it but and see where holes were drilled to pull it out and bondo pushed through holes on back.
here's where I cut the bed. the other side will be cut in the same place.
Tot Roddin'
Ridnhi... were you able to pull any additional pics of the frame?
Thanks! Nate
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
If you make the deal with Nate on the frame,... I'll take the fender for $20.
Tot Roddin'
Ridnhi.... it was good talking with you earlier.
I will call you once you have time to acquire the pictures as discussed. Also, if you could... could you get a shot of the frame body mounts? Thanks again! Nate Also... I just saw the 2x4 between the frame and the body; is this replacing a failed bushing?
#11 | |
pics of frame
#15 |
more pics
#16 |
last one!
#17 |
Do you have any underhood pics?
#18 |
It was brought to my attention that this may be a 71 frame. I'm not sure of the differences between the 71 and 72. It doesn't have a title and was told it was a 72. The frame is not cut off. Maybe someone could educate me.
#19 | |
The 69-71 blazer frames used a "bolt-on" inner bracket like the truck frames. This is a '72 frame. See the way the rear frame rails have tabs for the inner bumper bolts?
#20 |
I guess that this is not a 72 frame then. here are some underhood pics
#21 |
her battery trap is in good shape and so is the rad. support. the two inner fenders are not rusted out but they are bent in a couple of places.
#22 |
Looks like it was a 6-cylinder blazer also.
#23 |
Sold!!
#24 | |
dave
WOULD U BE WILLING TO CUT OUT THE TAILLIGHT POCKETS....I NEED THE BODY CUT AROUND THE TAIL LIGHT HOLE ABOUT AN INCH....LET ME KNOW IF U WILL AND HOW MUCH PLEASE FOR BOTH SIDES...do not need the lens dave thx
check out my build "DIRTY BURB" ![]() |
#25 |
1sik7t2- 72blkbuty bought it so I won't be cutting anything off, sorry. The taillight pockets were not in very good shape.
