Old 08-20-2011, 05:25 PM   #1
dropped81
dropped81's Avatar
coil spring compressing...
Hey guys i am needing to change out my control arms on both passanger and driver side of my 81 but the spring compressors from o'reillys, advanced, etc.. will not work does anybody have any other ideas besides the floor jack method...which i would rather not unless i have to... thanks for any ideas guys...Mike!
dropped81 is offline   Reply With Quote
Old 08-20-2011, 05:36 PM   #2
Goldfinger
Goldfinger's Avatar
Re: coil spring compressing...
have a welder? If so get 4 strips of steel with each pair weld a cross clamp them together and drill a hole. then use a bolt and tighten them up slightly in a clockwise order
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 08-20-2011, 05:41 PM   #3
dropped81
dropped81's Avatar
Thats kinda what i just thought of like 5 min after i posted this...i have a welder at my dads shop so i might go use it....im thinking 1/2 steel strips? im not sure if 1/4 inch would hold it..what do you think?
Old 08-20-2011, 05:45 PM   #4
Goldfinger
Goldfinger's Avatar
the 1/4th could work if it was case hardened. i would go with the largest you can fit in between.
Old 08-20-2011, 05:51 PM   #5
dropped81
dropped81's Avatar
see thats my problem i cant even fit the hooks on a normal spring compressor between the coils so i dont know if i could even fit half inch between them ill go get a picture of them and post it on here.
Old 08-20-2011, 05:53 PM   #6
Goldfinger
Goldfinger's Avatar
Well if you have access to an oxyfuel torch and old oil you can make case hardened steel.
Old 08-20-2011, 06:09 PM   #7
dropped81
dropped81's Avatar
okay i got a few pics of them
Old 08-20-2011, 06:11 PM   #8
Goldfinger
Goldfinger's Avatar
1/2 inch but you would have to use 1 solid piece and cut the other in half and weld a piece to either side
Old 08-20-2011, 06:14 PM   #9
dropped81
dropped81's Avatar
ill talk to my dad about making some for me so they can be ready and i wont have to waste the time making them especially in this 100+ degree weather!
Old 08-20-2011, 06:18 PM   #10
Goldfinger
Goldfinger's Avatar
i hear you there.
Old 08-20-2011, 06:19 PM   #11
dropped81
dropped81's Avatar
Thanks for the help man!
Old 08-20-2011, 06:20 PM   #12
Goldfinger
Goldfinger's Avatar
your welcome, good luck with it
Old 08-20-2011, 06:21 PM   #13
dropped81
dropped81's Avatar
Thanks!
Old 08-20-2011, 11:11 PM   #14
lilpoindexter
lilpoindexter's Avatar
there is a mercedes benz specific coil spring compressor available on amazon, but it will work here...
What's wrong with using a floor jack? If you're afraid the spring will come flying out, run a chain through the spring, and frame
lilpoindexter is offline   Reply With Quote
Old 08-21-2011, 12:47 AM   #15
dropped81
dropped81's Avatar
Well i am having a part fabed up at my dads shop tomorrow specifically for my truck the idea mentioned above with the two strips of metal welded together in a cross pattern and same for the bottom them a nut welded to the bottom of each side with all-thread through the middle....I have never done the floor jack method and my dad and his girlfriends brother have both had bad experienced with the floor jack method so they dont want to do it.
Old 08-21-2011, 03:17 AM   #16
67_SS396
What's the issue with putting the truck on jack stands and a floor jack under the control arm? The spring isn't going to go anywhere.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 08-21-2011, 08:48 AM   #17
Boog
laying low
Boog's Avatar
I would be more afraid of the allthread than the floor jack. That spring has a lot of stored energy in it's compressed state.
Your families prior bad experiences with the floor jack tells me they weren't doing something right.
Hopefully someone can post up some pics of a coil spring removal by floor jack method. May be of some help to ya.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-21-2011, 09:20 AM   #18
ont_guy_38
ont_guy_38's Avatar
Drop coils are going to fall out on the ground before you even lower the control arm all the way. Like was said chain it in in if you are not comfortable
ont_guy_38 is offline   Reply With Quote
Old 08-21-2011, 09:45 AM   #19
LONGHAIR
Those look to be lowered coils, and if so, the floor jack method is just fine. The shorter length means that the load is gone by the time you get the jack lowered. It is far less intense than with stock coils.
As ont_guy_38 said, they will just fall/roll right out.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-21-2011, 10:06 AM   #20
Mike Bradbury
Mike Bradbury's Avatar
The rotation of the Lower Control Arm is a known arc. As long as the jack is perpendicular to the truck (coming in from the side) so that the rotation of the LCA pulls the jack in towards the truck, all should be fine. Do not place the jack in such a way that the rotation of the LCA pulls the jack sideways and tips it, this is where bad things happen.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 08-21-2011, 12:33 PM   #21
N2TRUX
Happy to be here
N2TRUX's Avatar
The blue color tells us those are lowered springs. Use the floor jack and you will be fine.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-21-2011, 01:44 PM   #22
dropped81
dropped81's Avatar
Thanks for all the replies guys i guess ill try the floor jack method on my next day off lol...the bad expierences didnt happen to them they just happened while they were present. Im pretty new to all of this so i have tons to learn thanks again for all the replies guys! any pics or videos of the floor jack method would be greatly appreciated!
Old 08-21-2011, 03:20 PM   #23
Hertzdaddy
Lots of posts on this subject in the SUspension forum. Here's one
http://67-72chevytrucks.com/vboard/s...l+joint&page=2
FWIW, I did it on a burb in a pick-n-pay yard with a bottle jack. Once the pressure was released I actually had to push the LCA down with my foot in order to pull the spring out. I also put a chain on the spring and around the crossmember just to be safe. I wouldn't hesitate to do it again.
Hertzdaddy is offline   Reply With Quote
Old 08-21-2011, 11:27 PM   #24
dropped81
dropped81's Avatar
well thanks for the link hertzdaddy i guess ill try it tomorrow it doesn't seem too dangerous especially since i have lowering coils on it the tension should be little to none one its jacked up am i correct?
Old 08-22-2011, 10:56 AM   #25
rdscott3
I Got the coil spring compressor from autozone.. its the OEM brand, got a threaded rod, 2 hooks and a plate.. it works the best of all the compressors i've used. reasonable at 50bux...
rdscott3 is offline   Reply With Quote
