Old 09-18-2011, 05:06 PM   #1
Wheelie
Rear custom four link pics!
I wanna see what some of yall have done/seen. Lets see em!
Wheelie is offline   Reply With Quote
Old 09-18-2011, 06:52 PM   #2
parkwood
parkwood's Avatar
Re: Rear custom four link pics!
Don't know how custom it is but this is one i put under the '51 suburban. It's from TCI
parkwood is offline   Reply With Quote
Old 09-18-2011, 07:04 PM   #3
blitz'd
vintage car junkie
blitz'd's Avatar
Heres a picture of the rear setup on my 50.
1950 chevy truck, s10 swap, bagged, v8, 18s
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761
blitz'd is offline   Reply With Quote
Old 09-18-2011, 07:44 PM   #4
solidaxel
solidaxel's Avatar
I would like to see a close up of the front arm bracket and length of the arm, Thanks
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-18-2011, 08:58 PM   #5
rawraw67
rawraw67's Avatar
I just pulled the TCI four liunk out of my 57 and fab up new front mounts.I think that the front mount hang way to low. will try to get some pic
rawraw67 is offline   Reply With Quote
Old 09-18-2011, 09:02 PM   #6
mknittle
mknittle's Avatar
Is that a watt's linkage in the rear? it looks like there is something between the shocks
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-18-2011, 09:08 PM   #7
Wheelie
Those are sick guys!
Old 09-18-2011, 09:12 PM   #8
mknittle
mknittle's Avatar
LOL, Is that good?
Mark
My GMC build.
Old 09-19-2011, 12:12 AM   #9
Kim57
Kim57's Avatar
Not the best pics but here are a few of mine.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-19-2011, 12:34 AM   #10
Daze57
Daze57's Avatar
great work guys - kim your truck rocks!
Daze57 is offline   Reply With Quote
Old 09-19-2011, 02:08 AM   #11
hotrodrookie
hotrodrookie's Avatar
Here's what my unfinished parallel 4 link/ watt's link looks like.
hotrodrookie is offline   Reply With Quote
Old 09-19-2011, 05:37 AM   #12
BigDan3131
BigDan3131's Avatar
HRRookie why exactly are you mounting the 4-link outside the frame rails? Are you not planning to mount a wide set of tires out back? Only you and Kim57 have real 4-links of the street variety.
BigDan3131 is offline   Reply With Quote
Old 09-19-2011, 10:07 AM   #13
mknittle
mknittle's Avatar
i like the watts linkage. looks nice.
Mark
My GMC build.
Old 09-19-2011, 10:20 AM   #14
Kim57
Kim57's Avatar
Thanks.
Kim
My build thread
Old 09-19-2011, 11:26 AM   #15
StudioJAK
StudioJAK's Avatar
Here is what we have concocted, tell me what you think, if yall see strength's or weakness's in doing it this way.
'51 Chevy 3100 longbed pickup - bagged/MII/4link/bravada 3:73 posi rear.
StudioJAK is offline   Reply With Quote
Old 09-19-2011, 11:32 AM   #16
hotrodrookie
You got it. I considered running a huge tire but I won't be making enough power to justify it. On top of that, I didn;t have to take out the crossmember where thr front brackets mount.
Old 09-19-2011, 04:54 PM   #17
mknittle
mknittle's Avatar
nice welding.
Mark
My GMC build.
Old 09-19-2011, 07:40 PM   #18
blitz'd
vintage car junkie
blitz'd's Avatar
The upper or lowers? The lower is the stock S10 leaf spring perch, don't remember how long the lowers I wanna say around 35". I am 1500 miles from the truck right now or I would go measure.
Nope just a fancy shock mount.
Old 09-19-2011, 08:07 PM   #19
Daze57
Daze57's Avatar
again let me say you guys do great work !
Old 09-19-2011, 10:21 PM   #20
Coupeguy2001
Coupeguy2001's Avatar
Studio Jak,
I see a problem with the panhard rod being on top of the axle. The panhard rod needs to be in the middle of the arc that the axle panhard rod mount will scribe in motion. In other words, at the top of the arc, the panhard rod will be centered, at the bottom of th arc it will pull the axle to the right.
If the panhard rod was mounted on the axle centerline, it would have maybe 6-7 inches of up and down movement without appreciably pulling the axle to one side.
Coupeguy2001 is offline   Reply With Quote
Old 09-19-2011, 10:56 PM   #21
parkwood
parkwood's Avatar
Originally Posted by Coupeguy2001 View Post
Studio Jak,
I agree with this..
Old 09-20-2011, 08:09 PM   #22
rawraw67
rawraw67's Avatar
here is a few pictures of my 4 bar setup.with the new c-notch had to make new front mount because the old mount were to low.and now with the rearend in have to make up new mounts for the coil overs and the panhard bar.
Old 09-20-2011, 09:24 PM   #23
rollinrooster
rollinrooster's Avatar
Here's what i came up with.
rollinrooster is offline   Reply With Quote
Old 09-21-2011, 04:29 PM   #24
StudioJAK
StudioJAK's Avatar
Coupeguy2001, Parkwood,
I was wondering if it was going to give me trouble. thank you for the response.
Parkwood, I like your panhard being diagonal across the fourlink. Who makes that??
Is is as sturdy as it seams?? Thats a real clean setup you have going
Old 09-21-2011, 07:41 PM   #25
parkwood
parkwood's Avatar
It's made by TCI. you're over 90% there with the set up you have now.. just get rid of the pan hard bar over the top like you have and install the bar across the bottom like i have.. Give TCI a call and you might be able to buy just the bar with the bolts and joints you need to make it fit your set up.. measure across from back to front just in case their bar is longer and they can make it to fit..
It is sturdy and easy to adjust and stays out of the way of the exhaust too.. you need the phone number let me know..wayne
