09-23-2011, 08:35 PM | #1 |
need some wisdom, shes not running right.
I have got some problems. My daily driver is giving me some fits. I pulled the w/c belt off the pump to try to gain some h.p. and no she seems to run crappy when I get on her above 3ooo rpm. It's almost like its a lake of fuel. Ive never had this problem before, and just recently I installed a carb slavery. Would this be causing a lack of power?
Thanks for any help! Tony. Posted via Mobile Device Last edited by 70cst; 09-26-2011 at 11:29 AM. |
09-23-2011, 09:46 PM | #2 |
I am a Referee of life.
Re: need some wisdom, shes not running right.
What's a w/c belt?
And a carb slavery?
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
09-23-2011, 11:50 PM | #3 |
its all about the +6 inches
A/C belt maybe?
09-24-2011, 02:28 AM | #4 |
And a carb slavery?[/QUOTE]
X2
72 C20 Longbed 05 1500 Z71 |
09-24-2011, 06:33 AM | #5 |
My guess is your secondaries aren't kicking in.
09-25-2011, 09:08 AM | #6 |
What carb do you have? Is it vacuum secondary.
09-25-2011, 09:32 AM | #7 |
laying low
I'm sorry but this sounds "foreign" to me...
09-25-2011, 10:57 AM | #8 |
My guess is a typo w instead of a on the keyboard. No idea about the slavery thing. Maybe adjust your timing.
project: "my happy mess" |
09-25-2011, 12:15 PM | #9 |
Lake=lack
If he pulled the water pump belt, its probably detonating due to the lack of cooling the combustion chambers. Heat will build up there ungodly fast. Don't worry though, if he does this too much longer, his problem will become extreemly obvious, then he can replace the engine. Does slavery=spacer? He probably means A\C belt. The A is close to W on keyboard, and he was using a cell phone. Check timing, read plugs to see if Air fuel ratio is correct. Also look for vacume leaks. Pulling an A\C belt shouldn't cause engine problems. Last edited by biggestjohn; 09-25-2011 at 12:42 PM. Reason: ac |
09-25-2011, 12:46 PM | #10 |
English Chevy Owner
My translation from the predictive text nonsense (he posted from a mobile device and I have the same problem with my HTC, its turns even the simplest message into gibberish sometime) Lake is lack, w/c should be A/C god alone knows what a slavery is but I guarantee its nothing like the word he typed.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
09-25-2011, 01:02 PM | #11 |
slavery=spacer L is next to p on keyboard, v next to c, y is because he was boared
Simple english |
09-25-2011, 06:29 PM | #12 |
Anyway,despite the obvious typos,I still seemed to gather what his problem was and gave my guess to what the problem was. Before the poor feller runs off from the criticism,does anyone else have a suggestion for him? If you have vacuum secondaries,such as with the Quadrajet that comes on these trucks,you may simply have a vacuum leak. Check that white canister on the passenger side of the carb to see if it's broken.
09-26-2011, 01:39 AM | #13 | |
BTW: Board=bored oops |
09-26-2011, 11:31 AM | #14 |
ihatericeburners posted on a mobile device...when I am on the run and I try posting on my cell...my text looks the same. Interesting issue. I'm signed on
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
09-26-2011, 12:14 PM | #15 |
On now to
1969 Chevy c20(Miss Hackjob) |
09-26-2011, 12:18 PM | #16 |
whats the story, get it running,, I would suggest the belt go back on and check for vacuum leaks....
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
09-26-2011, 04:03 PM | #17 |
Just wrote to "ihatericeburners" on his profile page, and said there was about ten guys willing to help out, but we need more info. Hopefully we get him back on the thread.
09-26-2011, 04:07 PM | #18 |
me too........ hope he comes back for an update
09-26-2011, 06:23 PM | #19 |
I'b wumbering toob.
posted via mobile device
09-27-2011, 01:29 AM | #20 |
09-27-2011, 02:10 AM | #21 | |
extreemly: to be even more extreeme than "extremely" ?....maybeey biggestjohn : I shouldnt talk because............if it went fur spael chec id miissspel evary othar werd ...........Rush |
09-27-2011, 02:42 AM | #22 |
Where is the op? I want to see who is right!
09-27-2011, 11:06 AM | #23 |
come on guys we've got some truck geniuses on here we should have this licked by now.
I have auto correct on my phone so there's times I've cussed at this thing quite a bit. Posted via Mobile Device
09-27-2011, 11:16 AM | #24 | |
OK, so I'm not buying that excuse either. I claim extreeeeeeeeeme confusion. Come on Ihatericeburners, the suspense is killing us. Last edited by biggestjohn; 09-27-2011 at 11:21 AM. Reason: c |
10-09-2011, 12:16 PM | #25 |
Sorry for the confusion. I did post from my HTC phone. It's nice being able to wrench around a lil bit in the garage and have the internet as close to you as a wrench! soooo, I have the goodwrench Crate 350 with edelbrock carb. I had a carb spacer and removed it. Now its not running like it used to 6 months ago before the spacer at higher rpms. I haves adjusted the timming, jetting, and I went ahead and left the water pump belt on for now.
Sorry about the late response, ts been busy at work. And now I have some time to play around. Thanks for the replies! Posted via Mobile Device |
