09-26-2011, 08:32 PM | #1 |
72 gauge cluster light ?'s
so I notice that at night the dash lights are pretty dim...... even when adjusted all the way....... what should I look for or do to get the gauges brighter at night
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
09-26-2011, 08:40 PM | #2 |
Re: 72 gauge cluster light ?'s
Replace the stock bulbs with led's.
09-26-2011, 09:05 PM | #3 |
If the bulbs you have in there now are size 194, you could try upgrading them to 168's. They're the same size but 50% brighter, and they're only like $1.70 for a pack of 2 at Walmart.
I upgraded to 168s and it made a world of difference.
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
09-26-2011, 09:18 PM | #4 |
its all about the +6 inches
I have found personally, that taking the cluster apart and painting the green parts white, and then installing the 168 bulbs, is more than enough. I did that, and then put the white face guage overlays in my burb, and they are simply too bright now.
09-26-2011, 10:28 PM | #5 |
how many bulbs are there.... I am goint to buy the 168's
09-26-2011, 10:55 PM | #6 |
If your dash has the gauge package, it will have 9 bulbs
09-27-2011, 12:51 AM | #7 |
and do I get to the lights by under the dash or taking the face off the front
09-27-2011, 01:19 AM | #8 |
The Older Generation
You can remove them from the back. They twist 1/4 turn to remove. If I remember right it is counter clockwise to remove and clockwise to install. They should turn pretty easy. Don't force them. Then the bulbs just pull out of the sockets... LockDoc
09-27-2011, 01:23 AM | #9 |
great thanks
09-27-2011, 02:55 AM | #10 |
The bulb holders are about 3/4" round, black, and have a raised rectangle in the center to grab onto. There are no wires going to them (make connection through the circuit board).
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
09-27-2011, 08:14 AM | #11 |
Good info ...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
09-27-2011, 10:22 AM | #12 |
very good info thank you all
09-27-2011, 12:10 PM | #13 |
there's only 4 that light up the guages... the other 5 are turn signals and stuff.
09-27-2011, 07:18 PM | #14 |
needs more $$$
Not trying to jack the thread, but how do you paint this part? Aren't the letters/numbers green and the rest clear?
1970 2wd Blazer |
09-27-2011, 08:44 PM | #15 |
if you take it apart, you'll see the inside pieces that the light reflects off of is all a funky aqua green color. White reflects more light than green, and it reflects white light.
The numbers on the lens are white with just a tick of green. |
09-28-2011, 01:39 AM | #16 |
Go LED's!
You'll NEVER regret it!!!
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
09-28-2011, 07:20 AM | #17 |
I know this maybe overly simple but sometimes that is where the problems lie. Look to see if the hazard button has been pushed in. If it has and the hazard flasher is missing or bad that would do it
09-28-2011, 09:07 AM | #18 |
hazzard button being pressed in would have no effect on the brightness of the insterment lights.
09-28-2011, 09:28 AM | #19 |
cleaning up 40 year old electrical contacts has a noticable effect
09-28-2011, 11:44 AM | #20 |
Vendor and part number for LEDs please.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
09-28-2011, 12:26 PM | #21 |
needs more $$$
superbrightleds.com is where I got mine. For the 4 that illuminate the gauges, you'll want the 360 degree ones (3rd section of linked page). If you are replacing the others, the regular 1 directions (1st section of linked page) will be fine.
I got the "cool white" color. It's sort of a bluish tint...I like it, but just need it to be brighter since I goofed and didn't get the 360 degree ones for the gauges.
1970 2wd Blazer |
09-28-2011, 12:29 PM | #22 | |
09-28-2011, 12:39 PM | #23 |
If I use the LEDs will I still be able to dim them via headlight switch?
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
09-28-2011, 07:40 PM | #24 | |
10-28-2011, 11:12 PM | #25 |
Cool Truck
do you have to remove the cluster to change out the bulbs?
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
