Intake Manifold Removal & Install
I was going to remove my intake manifold this weekend so that I could clean it up and paint it. I've never done it before, but it seems pretty straight forward. Are there any foreseen problems that anyone can advise me of? Ive got a new gasket, silicone and a torque wrench. The manifold is on the original 350. Thanks in advance.
USCG "Support Search & Rescue, Get Lost" Last edited by Ryan5O; 10-07-2011 at 06:52 PM. Reason: typo |
Active Member
![]() Join Date: Jul 2007
Re: Intake Manifold Removal & Install
About the only thing I can think of at the moment is the distributor removal and replacement. Read up on the how to's first if you're not familiar with doing it.
I always take the cap off, set my engine at TDC with the #1 piston on the compression stroke and then mark the location of the rotor. Note how the rotor will turn slightly when you remove the dis. You will have to rotate it the exact amount when reinserting it so that it will rotate back to the original position. Be sure and not move the crank otherwise you will lose the positioning. |
I am a Referee of life.
^ what he said^ plus make sure the dist goes all the way back to the bottom on the flange.It drives the oil pump.Put rags in the intake ports to keep "junk"(old gaskets and such) out while cleaning mounting surfaces.Don't use the end gaskets,run a good bead of sealer on the surface of the block and use the gaskets between the mani and heads,I have never been able to get the end gaskets to seal.There are some threads and better discriptions on here but I don't have links.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
You can use your digital camera to take a photo of the rotor position before you pull the distributor.
I know it might sound silly but, remember to drain the Anti-freeze. I have seen people skip this and make a mess!!!
Sean "If your gonna be dumb, you gotta be tough" 1960 Chevy Impala Sedan - my 25 year search is over!! 1969 C-10 longbed - Nice day DD ![]() 1970 Chevy Nova - Street and Strip Project ![]() 2002 Acura MDX my DD 2007 Honda Odssey - My Wife's "Mommy Van" |
Ive never understood the importance of setting the engine TDC in ref to removing and installing the original distributor. Shouldnt I just be able to mark the location of the distributor housing and the rotor, remove it, then install it in the same position assuming the motor hasnt been cranked over?
USCG "Support Search & Rescue, Get Lost" |
Yes you can. You obviously know to mark the rotor position since you specifically referred to that and therefore have wrenched pretty deep on motors before. When I removed my first intake, I failed to buy valve cover gaskets not realizing that there was a lip on the valve covers preventing the intake from coming off. Lessons learned.........and I always seem to get the timing 180 degrees off on a new build. You should have no issues but do drain the antifreeze and plug the intake ports. As for the end gaskets, if you have a block with locator holes for them, I would use them with a very small amount of gasket sealer. I've never had issues with that kind. Also be sure to follow the torque specs and the correct tightening pattern for the intake bolts. One final thing. Be sure to remember any brackets or wire hold downs that go on the intake bolts. I've tightened many an intake only to loosen it again to put some bracket back on the bolts I forgot.
#8 | |
Active Member
It's not an "importance" issue but a habit with me. You can mark it anyway you want as long as you remember the position before and after. I've done it both ways but usually when I taken the intake off, it's because I'm doing some other major work on the engine like valve job or engine rebuild. Marks tend to disappear. ![]() |
Throw away the end gasket and run silicone. The first time I did an intake manifold gasket (many years ago) I didn't do that......and got to re-do the gasket a second time.
I get to replace the intake manifold gasket today on my 91 TBI donor engine too...fun times! |
Just a car guy
Only put enough silicone on the gaskets to hold them in place.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
ALL of the above. I have allways started with a brush and a shop vac held close, make that engine spotless before yanking that intake. Great time to clean out the carbon build up in the crossover port also. Also put some silicone on the shanks of the center intake bolts, to stop that peskey oil seepage.
Cool guys. Thanks again for the input.
#13 | |
![]() Join Date: Feb 2011
![]() ![]() ![]() ![]() ![]() ![]() Posted via Mobile Device Posted via Mobile Device
1969 C/20, 307, 4-speed, rusty with manual steering and brakes! |
Moderator
![]() Join Date: May 2007
X 3 on that.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#15 |
Junior Member
Careful not to overtighten the intake bolts. You may tend to want to but the way the geometry all works one side pulls against the other and they want to pull the intake apart as much as pull the intake down tighter.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
#16 |
When using silicone sealant in place of a gasket - as on the ends of the intake manifold - be sure to follow the instructions. You want to lay down a small bead (not smear it all over), and then let that bead set up for a few minutes before setting the manifold on it.
1971 GMC C2500 Custom Camper - Second Owner. 350/TH350, Dana 60 Rear. |
#17 |
English Chevy Owner
I did my first one this year with help from the guys on here and it went spot on thanks to the helpful hints and tips. Hardest part for me has been getting it timed right afterwards but thats probably more down to me than the engine!
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
#18 |
One of the First
![]() Join Date: Jan 2000
Intresting, this my project for the day. I used the wrong gasket on the intake manifold. I grabbed a generic one out of a old engine gasket set that I had laying around. Wrong! It leaks! So I had to reserch and found that a FEL-PRO 1256 is the right one - ie: port size dimensions and recommended by World products and Wieand for my heads/manifold.
So the process: ** Disconnect Battery** 1. Drain Antifreeze/ remove manifold heater hose / top radiator hose 2. Clean motor - top 3. remove plugs (tag wires) / distrib cap (tag wires) / valve covers - set to TDC (tag your wires!). Use timing tab and balancer mark. Distributor rotor should point to #2 or #4 plug. 4. Remove carb / coil / brackets / distributor / wiring 5. Unbolt intake / remove 6. Stuff clean rags in all openings that leads to the bottom of motor 7. Clean/scrape all gasket material off heads and manifold / lifter valley / intake ports (shop vac - good tool) 8. Match gaskets with heads and intake to ensure correct fitment. 9. Use skim coat of silicone (RTV - Blue) around ports - intake and heads and BOLTS. 10. Install intake manifold / install bolts / tighten in sequence / then tourqe in sequence. 11. Install carb / coil / brackets / distributor - distributor rotor should point to #2 or #4 plug. If it will not seat correctly you might have to slightly turn the oil pump shaft CW or CCW. PIA - use large screw driver, flashlight and small mirror. When reinstalling your plug wires you should have marked them to the corresponding cylinders. No problems then. Wiring: ensure pos wire is on positive side of coil post and negative wire is on neg side. Do not over tighten little nuts. 12. Reinstall valve covers - these will leak sometimes / you will need new gaskets or ensure they are solid. Do not over tighten the screws. 13. Look everything over one time - have a adult beverage - get your timing light out / Set it up. 14. Account for all your tools 15. Refill Radiator / Reconnect the battery / timing light / turn the motor over / might have to play with distrbutor - turn CCW a little. Should fire up! 16. Set timing to 8 to 12 dergree BTC. 17. Test drive.... ![]() Have fun! ![]()
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) Last edited by D.PASSMORE; 10-09-2011 at 05:54 PM. |
#19 |
When I pulled my distributor, I noticed that it didnt have a seal. Are they necessary?
#20 |
One of the First
Yeah or you will get a small oil leak there. Can't really use RTV, as the distributer will have to rotate.
#21 |
All the above. Make sure you clean the bolts properly to ensure proper torque, I also use a little non hardening thread sealer to ensure no leaks! I hate leaks an any bolt hole that had no bottom to it got thread sealer an haven't had a leak yet
1969 Chevy c20(Miss Hackjob) |
#22 |
#23 |
Well, Ive done it now. Got everything back together, but cant get it to run
#24 |
By the way, Ive got a friend cover over with a timing light this evening. Im hoping thats all it is.
#25 |
Check for vaccum leaks, firing order & timing.
