10-13-2011, 06:54 PM | #1 |
C/10 junkie
CST door emblem mounting hole location
Hello. I am looking to install a couple "custom" emblems on my 1968 doors and was wondering where to drill the holes. What size are the holes and how do they mount into the doors?
Here is one example
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
10-13-2011, 07:24 PM | #2 |
Re: CST door emblem mounting hole location
They mount with speed nuts just like the chrome piece that goes over the tailgate handle.. If nobody posts before tomorrow or Saturday morning i will post pics of the hardware and measurements . Rod.
10-13-2011, 07:38 PM | #3 |
C/10 junkie
Ok Rod. Thank you. I kinda figured that they mounted the same way as the tailgate trim piece that goes over the handle. I just haven't been able to find the little hardware piece that pushes into the door.
10-13-2011, 08:20 PM | #4 |
rod is half correct...... 68s use the same little nuts that you screw emblems on and in 67 they use the speed nuts that you just push in.... the cool thing is you can get 67 emblems take the speed nuts off and use the same nuts for emblems, and screw them on the back... it will be like brand new and very tight. and not loose from the wear of the pot metal. on my 67 the bottom of the emblem rides very close to the body line under the emblem, and has a taller gap from the top of them emblem to the body line above it.... it is also 14 inches from the back of the door to the front of the emblem. hope this helps.
10-13-2011, 11:50 PM | #5 |
C/10 junkie
Well the emblems I am expecting in the mail are off of a 68 so I guess I will need to fit my fingers or a wrench inside the door to install the speed nuts? Any tips to make it any easier? Thank you so much Rick for the measurements.
10-14-2011, 12:06 AM | #6 |
i wish i could have helped more.... well i just installed these in my dads doors yesterday! lol what i did was carefully put the nut on the 3/8s wrench and pushed the nuts on the studs really hard so they didnt fall off the i turned them righty tighty... remmember one at a time and do it very very delicatly..... also i did this by going in between the outer door skina dn the inner doors skin at the window sill.
10-14-2011, 12:16 AM | #7 |
C/10 junkie
That was my plan to go through the top and not remove the door panel. Sounds easy enough. I'll let you know the results.
10-14-2011, 01:22 AM | #8 |
ok let me know! get some pics to!
10-14-2011, 09:20 PM | #9 |
Roadtrip!
Should just be barrel clips for those emblems. (push ins) I don't think i have seen nuts on any of those emblems even through 72 on the blazers.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
10-14-2011, 09:29 PM | #10 |
Eric, I think you are right, just like the custom camper emblems by the way,thats my door you are using as sample LOL
10-14-2011, 09:33 PM | #11 |
Roadtrip!
Actually, the upper door scrpits for "custom" and "camper" i have seen with barrel clips or smaller speed nuts.
10-14-2011, 10:22 PM | #12 |
C/10 junkie
Ok. I got my custom emblems in the mail today and sure enough there was one barrel clip on one of the studs. So next question where can I get four of those barrel clips at? I'm at lowes right now and no luck. Also is there anyone who can give me the measurements of where to drill the holes? I guess I can eyeball it if I have to but would rather it be exact. Thanks guys.
10-14-2011, 10:53 PM | #13 | |
C/10 junkie
10-15-2011, 09:59 AM | #14 |
C/10 junkie
Ttt
10-15-2011, 10:14 AM | #15 |
holing tape measure at style line (see pics) upside down pic is holding tape measre from other side of door, hope this helps
10-15-2011, 10:46 AM | #16 | |
C/10 junkie
10-15-2011, 11:31 AM | #17 |
C/10 junkie
ttt
10-15-2011, 02:21 PM | #18 |
C/10 junkie
Ok so I found the clips at a place called Auto Industrial Paint right here in Lodi. Only $3 for a bag of six. Ready to drill just as soon as I can get the location of the holes.
10-15-2011, 04:44 PM | #19 |
C/10 junkie
Anyone have the hole measurements yet?? dying to install these. lol
10-15-2011, 06:40 PM | #20 |
Roadtrip!
I checked 5 doors i have here and they vary from 13 1/4" to 14 1/4" from the back of the door like in post 4 or the first pic from ernesto. Just decide on your measurement, hold the emblem up and figure your hole location.
10-15-2011, 06:44 PM | #21 | |
People know me
Take the cardboard with the holes in it, measure on the door like the pictures above. Take a sharpie and press it against the holes in the cardboard, then drill out the sharpie marks on the door.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
10-15-2011, 06:50 PM | #22 | |
C/10 junkie
10-15-2011, 07:26 PM | #23 |
This is in the assembly manual but not real helpful.
10-15-2011, 08:34 PM | #24 |
C/10 junkie
Success!!
Before with holes drilled. And after with emblem installed. Thank you guys for all your help.
10-15-2011, 10:18 PM | #25 |
that looks really good! now wheres the pics of the rest of the truck????
