06-07-2010, 07:42 PM | #26 |
Re: Bedwood/bed floor ideas ond pictures
here is the bed in my 57.
1 coat of dark walnut stain and 5 coats of helmans spar varnish. one day i need to sand it and add a few more coats of the clear. the heavy grains soaked up a lot of the clear. leonard
http://s251.photobucket.com/albums/g...G/1957%203100/ |
06-12-2010, 09:30 AM | #27 |
Still going to do something in the floor, just havent decided on what yet. Maybe ruff cedar
1955 First Series Thriftmaster Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s, |
06-25-2010, 12:55 AM | #28 |
Luv the Crewcabs
Here is a Wood Bed i like ..................
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
06-25-2010, 07:19 AM | #29 |
Yellow truck club
Nice licence plate .....
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
06-25-2010, 11:47 AM | #30 |
If it's for show and not hauling I'd be thinking some sort or graphic, pinstripping, etc.
06-25-2010, 05:44 PM | #31 |
06-25-2010, 10:39 PM | #32 |
Luv the Crewcabs
Here is one i saw at a Show last Week.............
06-28-2010, 02:01 PM | #33 |
Ok...Mine isn't an older truck like yours but still has wood so I thought I would throw it out at you all. I used oak with automotive black thinned down and then shot 10 coats of clear over it. Tons of sanding in between each layer. This was more work than the body work! lol
1984 Chevy Stepside, 4spd granny, 4 1/2 front/6 inch rear drop. |
06-28-2010, 02:03 PM | #34 | |
Kim |
06-28-2010, 06:08 PM | #35 |
Thanks Kim!
12-22-2010, 08:18 PM | #36 |
I really like the s10 floor in that 52! Ive gota s10 bed i belive thats what ill do too!
01-11-2011, 07:12 AM | #37 |
I used oak plywood, cabinet grade, stained and completely sealed with epoxy and varnish. Got to install SS edge strips yet! Heck of alot cheaper than oak boards!
10-17-2011, 12:10 PM | #38 |
Here's a pic of a diamond plate bed floor I saw at a show this weekend. Thinking of tearing out whats left of my rotted out wood bed and following suit.
10-23-2011, 09:01 PM | #39 |
i used pecky cypress in mine as soon as i get a pic ill put it on here
10-23-2011, 09:20 PM | #40 |
thats pecky cypress with the worm holes painted black an then planed
10-23-2011, 10:04 PM | #41 |
GMC's n H.D.'s too!
The cypress looks very good!
I like the diamond plate idea too. That is what I have been thinking about doing for a while. |
10-24-2011, 05:47 AM | #42 |
Old Heap Driver
Here's my later model truck, sorry it's the only picture I can get my mouse on right now. I used a 4X8 sheet of oak plywood from Lowes, had them cut it into 12" wide sections, the length was cut at home. Used Minwax clear after a coat of Thompson's water seal on the bottom and edges. The polished stainless strips are from Classic Parts. Considering the truck lives outside with a tonneau cover that is usually removed, the wood has held up pretty good. I'll probably replace it next spring (last time I checked the sheets were about $40.00) and use the old ones for garage shelves.
Oh, if anyone is wondering.....The tool box is a "trailer tongue box" from Harbor Freight. Bolts through the floor and plenty big for roadside tools, jack, etc, and fits under the bed cover.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '30 Model A Pickup, suicide front end, 350, 350, traditional style hot rod. |
10-24-2011, 07:06 AM | #43 | |
Chevy Lover Till The End.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
08-14-2012, 11:23 PM | #44 |
But Found Her 25yrs Later!
Added this thread to the FAQ's
http://67-72chevytrucks.com/vboard/s...20#post5516720
08-14-2012, 11:26 PM | #45 |
I do like this:
08-14-2012, 11:31 PM | #46 |
did tounge and groove 3/4 inch flooring,under 70 bucks from lumber liquidators
08-15-2012, 10:14 AM | #47 |
trex plastic ''wood''
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
08-15-2012, 02:36 PM | #48 |
11 ga steel sheet and bed liner, cuz I still haul stuff in mine.
Retired and too busy to work. |
08-15-2012, 06:28 PM | #49 |
Carefully cut and pasted the floor out of a dakota. It's the right length and the wheel wells lined up. Most S10 floors are too short and have to be extended.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
08-15-2012, 10:01 PM | #50 |
Wow! The Dakota floor and wheel wells is impressive. Nice job!
