10-18-2011, 10:14 AM | #1 |
Just a Member
Complete BIG BLOCK rolling body and frame 71 Custom Deluxe Part out
This truck was the RARE 402 BIG BLOCK setupWood Longbed. I will have any detailed pics and prices you need but here come many...This has all the added suspension options I believe.. it had the bb 402 in it!!! Someone got to it before I did...Thanks...Duane. I am goig out to start pulling parts... be back after a while...Stay tuned
bed-SOLD LOCAL pend. payment 4 core Rad support with AC-$150 Solid 2 piece shaft with carrier bearing-$50 Mirrors Nice-$50 shipped TH400 crossmember-$50 Front Sway-$60 with frame brackets Fenders-$75 driver $100 pass pass sold to 72KSzl1 BB Heat shield and engine stands-$175 shipped Engine Stands $100 ship... heat shield $100 ship Set spoke rims-$200 set $300 with tires Goodyear Wranglers with 1/8" tread until wear indicator Disk Brake Booster- 80 shipped sold to zombiefied Hood-$150 Completely Solid SOLD LOCAL Rear Bumper with Hitch option and brackets-$225... Rear Bumper- $125... Rear Bumper Brkts-$70... Factory Hitch-$70 All sold pending local payment Front Disk Entire Setup- $300 Outer AC box-$50 Inner Ac/Heat Duct and Heat Core housing-$60 Rear Slider- $40 Bench Seat nice springs-$50 Cab Mounts-$75 set...$20 a piece Inside Bed Rails Sides- NOT ONE DING- $200/pc $350/both Front Gate- NOT ONE DING-$150 Driver inner fender-$50 Pass Inner Fender-Junk Rear End Dana 60 Open-$200 Rear Suspension Leaf and Spring Heavy Duty RPO-$150 Rear Drums and Brake Setup-$75 Cowl Panel Outer $40 shipped CONUS sold to jessewebb when picked up Complete Wiring Harness with ignition and key $150 shipped CONUS tested and worked (fuse box,volt reg, front pigtails for markers and all lights,alt, EVERYHING!!!) sold to zombiefied
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog Last edited by HeavyMetalChevy; 11-04-2011 at 01:46 AM. Reason: prices and sale updates |
10-18-2011, 10:17 AM | #2 |
Just a Member
Re: Complete rolling body and frame 71 Custom Deluxe Part out
More
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
10-18-2011, 10:18 AM | #3 |
Just a Member
more... 2nd picture here features FAACTORY OE HITCH!!!! BAD MOTHA'
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog Last edited by HeavyMetalChevy; 10-18-2011 at 09:49 PM. |
10-18-2011, 10:19 AM | #4 |
What kind of shape is the lower trim molding in on the driver's side? And how much for all?
10-18-2011, 10:21 AM | #5 |
Just a Member
going to get pics now Levi...gimme a sec
10-18-2011, 10:28 AM | #6 |
How much for the a/c switch and cabled, and the complete horn parts in/under the steering wheel?
Tony
05 QSM GTO - M6, Corsa, King Springs 70 SWB CST - 350/Auto, Foose 18/17 I upset whiners too.... |
10-18-2011, 10:35 AM | #7 |
Just a Member
pics for Levi...
10-18-2011, 10:36 AM | #8 |
Just a Member
last driver side trim pics
10-18-2011, 11:02 AM | #9 |
any pics of inside dog house or core support. Thanks
10-18-2011, 11:05 AM | #10 |
Just a Member
Coming right up....Finally got her here!!!!! YEahh buddy!
10-18-2011, 12:10 PM | #11 |
Just a Member
daddymoo...core support pics and doghouse....
10-18-2011, 12:12 PM | #12 |
Just a Member
more
10-18-2011, 12:14 PM | #13 | |
Just a Member
Thanks, Duane
10-18-2011, 12:17 PM | #14 |
How much for power steering pump assy. Thanks Daddymoo2
10-18-2011, 12:25 PM | #15 |
Roadtrip!
How much on the engine stands and heat shield on pass firewall?
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
10-18-2011, 01:33 PM | #16 |
The horn pieces under the horn button and under the actual steering wheel. Little plastic parts, springs, flat metal disc and things...
10-18-2011, 01:58 PM | #17 |
Trim is rough, but still interested depending on price (for both sides).
Thanks, Levi |
10-18-2011, 01:58 PM | #18 |
How much for the.custom delux embpems shipped to 26431?
10-18-2011, 02:22 PM | #19 |
How much for the lighter element only (no socket or bezel needed) and the wire that runs off the back to the fuse box? 97838
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
10-18-2011, 03:03 PM | #20 |
how much for the outer grill shipped to 73018, Thanks Coop
1971 K20, Coop's beast (project) 1972 C30 wrecker, "Big Ernest" (SOLD) 1975 K5 Blazer (wife's toy) she got it in the divorce 2014 Street Glide Special 1983 K20 Big Block, auto (work horse) |
10-18-2011, 03:45 PM | #21 | |
Just a Member
Let me know, Much Appreciated
10-18-2011, 03:47 PM | #22 |
Just a Member
Coop...I really dont want to separate the grille but if need be I will... There is a small ding on the pass side if you did not notice...Also I want to have it repaired first or is that what you plan on doing??? Let me know and I will give price.. Like I said though...Would rather sell whole...
10-18-2011, 03:49 PM | #23 |
Just a Member
The pass side deluxe part of emblem has one post missing... Other than that the Custom emblems are both excellent... The Deluxe shows some pitting but still all chrome... 50 bucks shipped???
10-18-2011, 03:52 PM | #24 |
Just a Member
The pass. side is ALOT better shape.. pics coming...
10-18-2011, 04:22 PM | #25 |
Ok how much for the whole thing Ill do the repair shipped to 73018
