#1 | |
Re: 1967 Chevy CST aka "the loud truck"
Hahaha! And to think my 10,000 post is on my own build thread! That's scary... There 10,000 times you can find a post from me! I wouldn't rather hav posted on any other site 10,000 times more then here!
All I need for the the 700r/posi/3.73 install is: I need a tilt shift indcator lense for a 700r and a shorter drive line As for the posi/3.73 install I need the correct crush sleeve, posi additive and 80w90 diff lube as well as guidance from a well expeienced individual lol I'm not scared to install the pinnion I'm just worried about how well it's going to be installed or last lol |
Well I messed with the fuel guage situation a little today... When I disconnect the brown wire at the tank it goes all the way to full and then when I reconnect it it just goes to empty.
Well I have bought a new sending unit and now when I disconnect the brown wire my guage reads full and when I reconnect it goes to empty... Took the sending unit out and grounded it, connected the brown wire and moved the floater and the fuel guage would move
I picked up a drive line today that will work with my 700r swap so now I'm down to:
11 quarts of ATF And I need to figure out how the 700r overdrive cable connects to my 1406 eddy since it doesn't use the same cable as the 350 |
Junk Yartist
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
Junk Yartist
Nice! Ok ill but the one you recommend. And I need to get the right bolt for the cable it needs the one with the ball end I don't think I have that bolt.
C/10 junkie
The bowtie overdrives tv cable is the kit I used and it was nice.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
Thanks For the input Shawn I noticed that it has a carb spacer is that needed?
And as for an update I went down to see the general today and you wouldn't believe it... He actually still had 1 last blower motor relay for a 67! So I snatched that up ad also got some diff lube and posi additive, an I have the crush sleeve and shims coming on there way
alright i finally have a computer at my disposal lol. I'm gonna take you guys wayy back to when i stopped posting pics and build up to current day. i have done a bunch of things like replacing the "s" plenum box under the dash and putting metal AC ball vents from a 65 wildcat in then the drop coils in the rear and the rear disc, the posi (currently still trying to make happen), I've installed an even better passenger fender I've installed a new hood since the last one got hit in the hit and run, I've been sanding off all the old nasty paint of the door and shooting them with a coat of primer and paint which made them look soo much better then before, I've had a flat and ended up turning the white lines inside and I've even replaced the thermostat and water pump recently, as well as getting parts together for the 7004r swap i hop you enjoy all the pics of those upgrades and installs as well as the random pics taken around town or at my college.
more
even sandblasted,primed and painted the vacuum pod and linkage for the passenger kick-panel vent
took the hood off na dwas getting ready to install the hood from the 67 i found at pick' n pull ill post a picture of it
#15 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
I think I know those people behind your truck in the pic from Rene's.....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#16 |
you should know best out of anyone!
#17 |
Looking good Rick, keep up the nice work.
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
#18 |
thanks Nate! I'm gathering parts and cleaning things up and making the truck how I've expected it to perform and drive. having the 3.07 gears would certainly explain why my truck has always felt "heavy" to me it feels like I'm driving a giant wall when I'm driving down the freeway, feels like the wind is fighting hard against my truck, but the 3.73 should take care of that and my wallet no problem! lol
#19 |
alright finally brought the truck up to La Grange where im gonna be until the 10th and now i can put some work in to the truck i brought it home and for the night i took the original 67 shifter knob off and put on the 67 GM car shifter knob in.. i must say I'm pleased with it looks right at home in the truck! tomorrow I'm going to install that door jamb vent into the passenger door jamb i thought about doing it in the driver side but with the vin there it would look to busy so since the passenger side only has the door striker it should look better on that side. an also here is a before and after of the shifter knob.
#20 |
That looks familiar lol. I like it much better as well.
#21 |
today i went to go drive it and its actually a very comfortable knob! it fits the curves and how you grab the shifter perfectly, and what can i say you know some pretty cool things that i don't know about all of GM from 60's vs. just the trucks which allows for many "stock custom" parts which is what i like best... its all about trying to "keep your GM truck all GM"
today i went and got some work done on the 67. installed the vent in the passenger door jamb and it came out pretty good I'm pleased with it. and i also got around to painting the master cylinder so i sanded the rust off and the shot it with some silver hammered paint and i think it looks better. here are some pics. |
#22 |
worked on the doors and adjusting the doors and fenders as well as the cowl. im pretty happy for now. need to undo the driver rocker and find a way to bring it out more so its flush with the cab corner. and i think im going to have to weld a bead along the bottom of the passenger door so the gap is a little smaller for the rocker to door since the door is actually on correctly. other then that its as good as its going to get. however i cannot seem to correct the driver bottom right portion of the door I've tried to adjust the door accordingly and it just isnt working it sticks out like maybe 1/4 or 3/8's out from the cab corner you guys have any ideas? heres some pictures of the gaps
#23 |
and here is the driver door gaps
#24 |
alright so i'm thinking about going to get new shocks and then i realized that i don't know what shock to get since i have the 4'' lowering coils in the back so my question to you guys is if you go to O 'Reilly's auto parts store what vehicle do i use to get the correct length shock for my 4'' rear drop?
and there's a little something going on in the garage today... |
#25 |
Looking good, waiting to see a pic with two marks on the ground. ...
