Re: 1967 Chevy CST aka "the loud truck"
More like oh... No.. No no no! *pulled the bolt out to find threads at the bottom* F.... I think you guys no the rest lol. Actually it was a lot like Michael from the show "the office"
Well I have good news. Finally fired up the motor! I made a gravity feed fuel "system" for the carburetor so I could start it up and hear it run for about 20ish seconds and it ran good! Was smooth and ran consistent. So next up im going to start getting everything I need for the new fuel system and finish the last bits for the cooling system and get the motor side of the swap finished. Hoping the Trans is as good as the motor.. No matter what you do to check stuff before buying it's always a gamble in the end.
#3 | |
Still Learning
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
In the video I've got a ghetto gravity feed for the fuel system and the vacuum lines are a mess so just Nevermind those lol
#9 | |
Sounds great Rick.
#11 | |
Thank you, I can't wait to get the exhaust done and hear what it sounds like then. Need to order a PB trailing arm crossmember and install it before it goes to the exhaust shop though |
Alright my PB trailling arm crossmember, fuel pump, fuel regulator, power steering reservoir(and the hose to connect it to the reservoir) are all on there way in the mail. I bought a new 16" fan and I'm going to wire it up to a thermostat if I can and I have a fuel pressure gauge waiting for the rest of the fuel system parts to show up. Today I planned out how im going to make my fuel system run. I decided to have the fuel line come out of the cab as the factory did only instead have the fuel line go into a 100 micron fuel filter, then over the frame to the outside and into the fuel pump which will be mounted about 5" forward of the rear passenger cab support bracket that's riveted to the frame and then from there it will go through the frame (with a grommet of course) and then it will travel up like the factort ran it to the front passenger side of the motor. How's that sound to you guys? I wanted to also build a cover that encases the pump so water and dirt have a hard time getting as well as nothing can hit the pump directly
Thanks for the video, good job so far Rick.
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
Still Learning
Engine sounds good Rick! I dig the gravity feed
#15 |
You'll be driving it soon, great job.
#16 |
Thanks, trying to do this right and make it a fairly nice swap. The LS has already been installed and done up everyway you can think of so nothing new or special going on with my swap but ibe always wanted a retro style LS if I ever went that route.
The gravity feed is pretty backyard but I've seen a guy start his carburated LS on an engine stand like that before and figured I would give it a try lol I really hope so, I'm getting really excited about driving the truck again... Miss the 67 I can't remember ever having it down for this long since I've got it on the road. Also really hoping the transmission is going to be just as good as the motor. A buddy of mine has a plasma cutter so pretty soon I'll be trailering the 67 to his house so I can remove all the rivers and the OE trailling arm crossmember easier and since his house is close by the exhaust shop, I'll trailer the truck there after installing the PB crossmember. I'm planing on doing 3" exhaust. I was going to do 2.5 but my dad talked me into 3". also I've decided to put a flange by the trailling arm crossmember on both LH and RH side so I can un-bolt the exhaust to take it out, instead of having to cut it out since it will go through the crossmember. Last edited by 67chevy1series; 05-11-2016 at 12:45 AM. |
#17 |
Got my PB crossmember in today.. So beautiful and nicely powder coated black! Now to attack the rivets with full force and no mercy... Not looking forward to that lol
#18 |
Very nice!
#19 |
Well today I got the 67 loaded up, and I also received my PS reservoir and aeromotive fuel regulator. Just waiting on a 100micron and a 40 micron fufle filters to come in the mail and the to install the PB crossmember and I can install the fuel system in the truck. Here's a shot of the 14' silverado pulling the 67 for the first time.
#20 |
![]() Join Date: Jan 2007
dude did you just drive over don pedro dam?
I live in California, but identify as a Texan ![]() "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#21 |
Yes sir about that time I was definitely on the dam by don Pedro!
#22 |
Today I loaded up and pressure washed the rear suspension and frame a bit and then picked up all the necessary hardware to install the PB trailling arm crossmember, and then I headed home and proceeded to swap in the crossmember. The fitment between the 3 piece crossmember and of the crossmember to the frame is spot on and very nice, however I really think the crossmember is something that should be done when your entire rear suspension is loose and the body is off the frame.. So since that was entirely not the case with the 67, it took me longer then it should have. With that said I would still buy another crossmember in the future if I had any other rear soil sprung c10's. Maybe Sunday or Monday I can get all the fuel system in. Waiting on some 6an fittings for the aeromotive fuel regulator and a 100 micron filter to come in the mail and then I can begin.
PS: any of you guys have an aeromotive fuel regulator, and if so where did you mount it? (Especially if your engine is carbureted) having trouble deciding where to mount it where I can also monitor the fuel PSI gauge that's on the front of it. |
#23 |
Well I got the power steering lines all done and the power steering works! Also got the TPS sorted out and in place, just need the stud to connect it to the throttle lever on the carb. Throttle linkage is done as well. There's a performance/economy mode wire that either grounds out or not for the Trans... I think I finally figured out how to incorporate that with the dash and still look like sown thing stock... More on that later.
#24 |
It sounds like it will be drivable reay soon. Great work..
#25 |
Calibrated the TCU today since the TPS and throttle linkage are officially done. Also mounted the fuel regulator... Don't think I'll keep it where it's at for very long... However between wanting to hide it and having to keep in plain sight because the PSI gauge that screwed into it makes it difficult for me to find a spot to put it. Couple more odds n' ends and I can finish the fuel system. Still need to wire the engine cooling fan/fuel pump, get a driveshaft and new U-joints, get exhaust done, trans coolant lines/hoses, machine temp sender(I've seen people do it on here, however im having trouble finding a shop locally that can do the job), and then I still need to get Dakota digitalis VSS to mechanical speedometer converter. after that it's down to just coolant and ATF... And hoping the Trans is good! Lol
