Old 10-26-2011, 10:18 AM   #1
67cheby
67cheby
67cheby's Avatar
copper lines with accuair setup ??
i have seen a couple different pics of copper lines running into what looks like the factory plastic airline inserts on the accuair valve setup ? am i seeing this right or is there special fittings on the copper to replace the plastic air line fittings ?? my thoughts is i want the look of the hardlines with of course the least amount of money , so i was thinking run the copper tubing and paint it black or charcoal grey ? any input anyone ??
67cheby is offline   Reply With Quote
Old 10-26-2011, 11:40 AM   #2
67cheby
67cheby
67cheby's Avatar
Re: copper lines with accuair setup ??
this is the setup that had me thinking about doing this, it looks like it just pushed in to the same fittings ? i sent a message out to the shop that did it but havent heard back from them yet
Old 10-26-2011, 01:07 PM   #3
edflores
interesting. They got rid of the leader hose
edflores is offline   Reply With Quote
Old 10-26-2011, 01:09 PM   #4
67cheby
67cheby
67cheby's Avatar
yes and they put check valves right at the tank inlet
Old 10-26-2011, 03:13 PM   #5
67cheby
67cheby
67cheby's Avatar
accuair just got back with me and said they will work , they just push in and lock in just like the plastic lines, they said the copper is soft enough for the fitting to bite into in but stainless would just slide out !! i am pumped now i can do my hardlines without costing a fortune !!
Old 10-26-2011, 03:28 PM   #6
6772owner
Gearhead
6772owner's Avatar
Thanks for the research and for posting buddy, that is awesome information to know!
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 10-27-2011, 09:48 AM   #7
texastrendz
you can also use aluminum. after you get it all bent up you can even polish it....
texastrendz is offline   Reply With Quote
Old 10-27-2011, 10:00 AM   #8
67cheby
67cheby
67cheby's Avatar
WOW....i like that thought even better !!
Old 10-27-2011, 10:02 AM   #9
67cheby
67cheby
67cheby's Avatar
where can you get the aluminum line ? ..i checked at the local hardware stores for the copper it looks like it is about $1.25 a foot
Old 10-27-2011, 10:14 AM   #10
Ackattack
Ackattack's Avatar
Could you use aluminum fuel line? Summit sells that pretty reasonably priced.
Ackattack is offline   Reply With Quote
Old 10-27-2011, 10:35 AM   #11
67cheby
67cheby
67cheby's Avatar
hmmm good question, any input Texastrendz ?
Old 10-27-2011, 10:44 AM   #12
gringoloco
A guy with a truck
gringoloco's Avatar
Assuming it's the same OD, aluminum should work just fine- MUCH cheaper, too...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-27-2011, 10:55 AM   #13
texastrendz
yes, use aluminum fuel line. i got it from summit racing, made by moroso. i use the thin wall line on my projects, you can also get it in heavier wall. The stuff bends nice and does not work harden like the copper over time. Once you use it you will not use anything else. And yes, it will hold the pressure just fine..... I know this will come up.
Old 10-27-2011, 11:09 AM   #14
6772owner
Gearhead
6772owner's Avatar
That is even better, I love working with the aluminum line, I have used quite a bit on my build. I need to look into doing this the next time I upgrade my air ride. (again!)
Old 10-27-2011, 11:27 AM   #15
67cheby
67cheby
67cheby's Avatar
SWEET, man now i am even more excited !!
Old 10-27-2011, 11:29 AM   #16
67cheby
67cheby
67cheby's Avatar
Summit , 25 ft for $18.95....i like it !!
Old 10-27-2011, 07:47 PM   #17
chapster
chapster's Avatar
Where was this thread a few months ago...lol
I am into my S.S lines and Swagelok fittings for $450 and I still need a couple of flex braided lines.
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler
1968 Chevy c10 shorty Stepper (Patina LS project)
1967 gmc custom Long Box (Farm Truck Project)
chapster is offline   Reply With Quote
Old 10-27-2011, 08:07 PM   #18
67cheby
67cheby
67cheby's Avatar
Ouch !!
Old 10-27-2011, 08:49 PM   #19
Notch1988
Notch1988's Avatar
How did you go from the valve block to your stainless lines?
Notch1988 is offline   Reply With Quote
Old 10-27-2011, 09:30 PM   #20
texastrendz
I always keep a box of this stuff around
Old 10-27-2011, 09:57 PM   #21
68steppsidee
im very interested in runnning aluminum lines like this... would you need a bender for it and other tools for connectors or anything....
68steppsidee is offline   Reply With Quote
Old 10-27-2011, 10:15 PM   #22
67cheby
67cheby
67cheby's Avatar
man i cant wait for my Accuair to get here ....i want to build some aluminum lines !!
Old 10-31-2011, 01:46 PM   #23
smbrouss70
smbrouss70's Avatar
This is GREAT! I really didn't want to run the DOT plastic tubing for my setup. It looks like I'll be ordering some aluminum line too! Thanks Guys!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 10-31-2011, 01:52 PM   #24
67cheby
67cheby
67cheby's Avatar
cool , maybe this thread will help several people !!
Old 10-31-2011, 06:55 PM   #25
68steppsidee
when you switch to aluminum what kind of fittings and connectors do you have to use...
