10-26-2011, 10:58 PM | #1 |
First Truck
Hello all,
My first swb and first post. I hope to find lots of info and want to say thank you in advance. Traded a 1998 jeep cherokee for a 1982 swb that is in need of some work. Couple questions, first is if this truck came with a 10 bolt 8.5" posi rear from the factory and I'm having a knock around cylinder 6 that i can feel in the valve cover. It is only when idling and doesnt affect driving but it is very noticeable. I had a misfire so i replaced plugs and wires which solved the problem of misfire only to have a knock the following day. I drain the oil which has no metal in it and removed valve cover, had my wife tap the ignition and everything seems to be moving freely. I'm just wondering if something could have been stuck or needs adjusting. I have searched and searched the internet and forum. I dont even know if it is stock because it has aftermarket intake manifold, carburetor, and has a nice lope when idling. Sorry if it's too in depth or repeated. |
10-27-2011, 12:53 AM | #2 |
Re: First Truck
you can run the motor for a short time without the valve cover on it, it will make a mess but that way you can tell if you have a sticking valve or rocker arm messed up, also did you do a comp check on that cylinder?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-27-2011, 07:45 AM | #3 |
Re: First Truck
Yes, the truck came with a 8.5" ring gear 10 bolt, but a Posi was optional so you may or may not have it.
You can check your SPID label, in the glove box (?), and look for RPO "G80", which was the option for the "non open" rear diff. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
