repairing rust with fiberglass
I just picked up a 1960 panel truck and love the thing to death already, but its got some rust issues. I dont' have a welder or know how to weld, so I was wondering if I could fix the holes in the floor with some fiberglass cloth or do I need to buy the patch panels and do it "right" I have a good amount of experience with fiberglass repair on boats already. The truck is pretty beat up and has lots of bondo, that is the only reason why I would consider fixing it with fiberglass. Do you think would that be a good option?
Re: repairing rust with fiberglass
I would say no, mainly because it is not a permanent repair, nor is it remotely structural. If all you have is pin holes, or maybe a little larger in the pans, I would say go for it as long as your floor is solid around seat, and seatbelt mounts. Just know it will not last long at all, it's just a band aid fix.
Slowly but surely getting it done. |
well i've got a gaping hole at the floor to rocker transition and where the floor angles up under the pedals so it sounds like a little to much to try and fix, the rest of the floor is pretty good though. I am kind of confused about what patch panels I would need to buy. Is there a good thread about the basics of patch panels specific to these trucks?
Happy to be here
![]() Join Date: Mar 2000
Fiberglass and metal patches will eventually fail. The two materials are not compatible so eventually they will separate. If you can't weld, get a buddy that can to do it for you. If thats not an option, your better off cutting the old out and using pop rivits and 3M panel adhesive to bond them together.
#5 | |
60-66 Nut
I agree....I would recommend installing the patch panels with pop rivets or screws, and or the 3M panel adhesive. If you use the panel adhesive, be sure to clean the metal down to clean bare steel for the best adhesion.
Yeah don't do that. As said above, it's not a matter of if, but when it will fail.
If you can't weld and don't really care alot about looks, it panel bond some patches in and cover the whole thing with fiberglass to seal all the water out. I did this (but welded the steel) on my 65 mustang. Posted via Mobile Device |
I like the idea of bonding the patch panels in. Would bonded seams hold well if i did the prep correctly? and how do I figure out what patch panels I need?
No, bondo won't hold them. Maybe for awhile, but as soon as you put some weight on the floor, and then remove, and then weight again, etc. the bondo would crack and break apart. Not to mention, bondo will absorb water and create more rust.
You want to make sure the patch holds well. Use panel bond. Or weld, or rivet for that matter. The panel bond will probably be the easiest. It's like super industrial superglue. I have an uncle who owns a paint supply shop, and there was a panel bond demo there. They glued to pieces of flat metal together, then tried to break the bond. The steel ripped first. The idea of putting fiberglass over it is just a way of water proofing. A good coat of POR15 would do the same thing. NO BONDO Posted via Mobile Device |
okay I think I will go ahead and rivet and use some panel bond. thanks everyone
#10 | |
There's lots of great support and help in these forums. I know I appreciate the info I've gotten. Great bunch of people here and all willing to help ![]() |
#11 | |
I was reading BONDO insteaded of BONDING.... Yes, BONDING is good. BONDO is bad. If you do the panel bond, no need for pop rivets. Sorry for the confusion. I suck. |
If you could post some pics of your repair,progress.
Mine?
Sure. I'll have to wait till I get home this evening. Mine's a little different.... It's a quarterpanel on a 65 Mustang, adn welded, not bonded. But same principal.... |
Actualy I was referring to FAC for pics, as I'm try to see the steps, as I have pinholes and holes about the size of nail heads in my floor. Also no access to a welder. But please post your pics, I'll take all the help I can get.
#15 |
I can post some pics when I do it, it wont be for a while though. thanks again
