09-29-2011, 12:15 PM | #1 |
70 1 ton axles
HI all
Im fixing my old workhorse. I have access to two 1 ton axles and I am writing to ask your opinions on them. The first is from a 70 c30, the second is from a 70 chevy motorhome its a small motorhome, has smallblock and th400. My question is did they change the distance on leaf spring pads between 3/4 and 1 tons, for example could I take the 70 1 ton rear and put it in my 79 3/4. One more thing what rears come in those trucks, the front wheels have the big 5, or 6 bolt pattern i cant really remember, like a truck tho. the rear is a 8 hole. Ok and how about that motorhome will that be a usable axle or is that a diffrent setup all together. |
09-29-2011, 03:41 PM | #2 |
Re: 70 1 ton axles
You can take the center section from them & put in yours but I dought the houseing will interchange without modification. That motor home might have a 4:11 in it. Very rare.
09-29-2011, 04:20 PM | #3 |
Re: 70 1 ton axles
you think even the one from the 70 pickup will be diffrent also? maybe you already said that and I didnt catch it.
09-29-2011, 06:16 PM | #4 |
Re: 70 1 ton axles
Yes. I believe the 1 ton axle is not a direct bolt in for the 3/4 ton. I have been known to be wrong once before. The best way would be crawl under them with a tape & see.
12-02-2011, 10:12 PM | #5 |
Re: 70 1 ton axles
I came up with a 2" difference in the overall leaf spring widths, when comparing my 72 Chevy C30 Dually and my 72 GMC 3/4 ton.
Surprisingly, it was the dually that had the narrower spring spacing. I have yet to verify if the frames are narrower in the rear or if this is done with the spring mounts. |
12-02-2011, 10:31 PM | #6 |
Re: 70 1 ton axles
this is suprizing to me cause i didnt think the frames were diffrent, other than the wheel base?? i could understand the motor home frame being diffrent
