#26 | |
Re: The "bad" repro parts list. (buy at your own risk)
#27 |
I'm not sure that calling things "re-pop" here will help anybody avoid poorly made products as it's ALL repop parts; some companies make nice stuff, others, not so much.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
#28 |
even the best company has batches of defective parts...
#29 |
Florida Edition
![]() ![]() Join Date: Oct 2010
The Deluxe windshield trim I bought from LMC is pretty weak...and expensive!
Doesn't appear to fit worth a hoot either.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#30 |
Dash gauge bezel woodgrain decal. I bought one and test fit it on the original gauge bezel in the 72 Cheyenne i had. It didn't fit worth a crap around the bottom gauge holes, so the decal went back in the package, and the cluster went back in the truck [minus decal]! Joseph
1970 Chevelle Nomad station wagon 1966 C-10 lwb,250-six,granny 4speed ![]() ![]() 1966 C-10 lwb,factory A/C,Custom Cab ![]() 1954 Delray 2-door sedan [rat rod project]
#31 |
I just bought an ignition switch. The company is BWD and it was made in mexico. The switch would not fit into the spacer at all. I had to file all 3 of the alignment bars to get it to fit. I wish I would have returned it and order an AC Delco part.
I will say this about having reproduction parts available. If we had no parts available, good or bad, there would be a lot less of these truck on the road. Do you ever see any old Internationals or Studebaker trucks? No you don't. It's not because people don't like the trucks, it's because there are no parts. We should be happy that we have parts being reproduced and should let the vendors know when the parts aren't of good quality. Hopefully as time goes on all parts will become better so these trucks can be enjoyed by future generations.
68 4wd Stepside 69 2wd Stepside Project 71 2wd Blazer Project 72 2wd 3/4 Ton Project or Parts? 73 4wd Blazer |
#32 | |
![]() Join Date: May 2011
Good point. If we didnt have bad repop's than there would be no basis to start inproving on! That being said I though the plate on the new repo door handles gets riveted on? Did that no solve that problem? I try and buy GM replacement if I can, Than ADelco if available, Than USA made, than whatevers left. Just get stuck with some taiwan parts. just the way it is I guess. |
#33 | ||||
VA72C10
![]() Join Date: Mar 2008
![]() Quote:
repop brand is the closest but still not a perfect fit...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#34 | |
![]() When restoring my gas tank I had to replace the sender. First time I fueled up it still didn't register. I checked the new part first and found that the solder on the float was cracked and absorbed fuel. I called LMC and the operator didn't question it at all. He found my info and had a new float shipped to my door several days later...haven't had a problem since.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
Tags |
bad repro parts, junk repro parts list |
