Re: 48 panel truck
Atommik, I am going to try tonight to show you how I did the lower fender. I was busy with taking down all the Christmas stuff.
mud.man.rj, Thank you .You do not see too many. reaper71, Yes anybody that does metal work needs one of them. It has saved me a bunch of time. Shannon |
![]() Join Date: Jun 2009
Hey xpickup,
Awesome build, can't wait till I have time to read through it all... Subscribed...
1991 Chevy K10, 4x4 ______ Past Rides 1971 Chevy C20 Longhorn (6.6L, 402c.i.); 1973 Chevy K20, 4x4, std. cab, longbed (5.7L); 1979 Chevy Corvette (5.7L); 2001 Chevy Xtreme S-10, ex-cab, 5spd. (4.3L); 2001 Chevy Silverado 2500HD, 4x4, ex-cab, (6.0L); 2002 Chevy Silverado 1500, ex-cab, 4-6drop (4.8L); 2003 Chevy Silverado 1500, 4x4, std. cab, 5spd. (4.8L); 2004 Chevy Colorado Z71, 4x4, crew cab, (3.5L); 2006 HUMMER H3, 4x4, 5spd., (3.5L). |
Re: 48 panel truck
Very nice work on your panel....Read your complete write up this morning. Nothing better then using the bosses tools like your own, I sure miss that....once you retire that priviledge seems to disaper…..
http://67-72chevytrucks.com/vboard/s...82#post8619382 |
Re: 48 panel truck
Hey Shannon i have tryed to post some pics of the firebird i painted the other day but it comes back saying i have a code missing??? IDK what that's about i loaded them the same ...
Mark
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
Re: 48 panel truck
reaper71, If I try to load 5 pictures at a time it will not let me. Try loading 2 at a time. That seems to work for me. I hate computers!
Shannon |
Re: 48 panel truck
Thank's man ill try that..
Mark
Re: 48 panel truck
Here ya go my man enjoy...
Mark
Re: 48 panel truck
reaper71, That looks great. I love the color. It looks close to my sons 1948 truck bed that he sleeps in. I guess only putting a couple pictures up must have worked.
Atommik. Here is how I made the panel. First I took a piece of metal to make the profile of the shape. Then marked (every 1/4 of a inch) the sheet metal so I could brake form it on the brake( small bends to make a radius). Once that was done I put it on the fender to see where I would slice it. Once I sliced it I overlapped the slices. I then marked it so I could cut the overlaps. Cut the overlaps and pushed them together to check the fit. Once I was happy with the fit I tacked the slits together and then ground them flush on both sides. I then took it over to the air planishing hammer and used it to form the radius so the was no flat spots. After that I would weld up all the seams I grind both side again that way it does not mess up the dies on the air planishing hammer. Then run it on the hammer again. Take the disc sander to it and it is ready to weld in. The last picture is one of the pieces I am making for britnjc. It is the piece for around the windshield for his 1955 chevy truck(AD). I have both sides to do but that is the passenger side. I still have to form it to the profile of the cab, The inner piece is also stretched and shrank to the profile of the inner lip. It is good a have a cab so I can check everything. Then I can weld them together. Then I will make a section of the belt line for under the corner. They do not make any of those pieces for the 54-55 cabs. I already made a rear belt line for him too. Shannon |
Re: 48 panel truck
the rest
Shannon |
![]() Join Date: Mar 2011
Re: 48 panel truck
Shannon, that's some damn nice metal work, just great.....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
Re: 48 panel truck
oldman3, Thank you. Your son did a great job on the firebird. I love the color. He needs to post pictures once it is all together.
Shannon |
Re: 48 panel truck
Thank you, yes the car looks good. Now it's sanding and buffing time, I'm sure he will post pics once it back together.....Jim
Re: 48 panel truck
AUSSIE54, Thank you. That has crossed my mind a few times. I really do love sheet metal work. There never seems to be any stress when I am doing it.
oldman3, now all the fun stuff, wet sanding and buffing. It looks great. Shannon |
Re: 48 panel truck
Shannon, thanks for the extra pics of the patch forming. That is was I thought you were doing, but it helps to see it! I hope to get going with my cab corners in the spring! I would rather spend the time building them than spend the money buying them!! I don't have much extra time, but I've got NO extra money!!
My build http://67-72chevytrucks.com/vboard/s...d.php?t=495795 |
#15 |
Re: 48 panel truck
Atommik, No problem on showing you how I did it. Glad to help. I know how it is on the time and money thing. Never enough time or money.
Shannon |
#16 |
Re: 48 panel truck
Amen to that brother!!
or you have all the time and no money/all the money and no time...
#17 |
Re: 48 panel truck
great work !! it takes sone time to do that kind of work! nice panel truck too
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
#18 |
Re: 48 panel truck
reaper71, It does seem that way. But is alway seems to no money and no time.
67swb72klb, Thank you. Yes, it is time consuming. That is all I got done last week while I was off. I worked on it somewhere between 30 and 40 hrs. I was happy with what I got done. I have to get back to my 1948 truck next week so I can buy my rear disc brake kit. I should have it in epoxy primer this weekend and get back to working on it by the end of the month. Shannon |
#19 |
Re: 48 panel truck
shannon, love the work as usual. Really wanna see this on the road. But Im sure we all appreciate seeing this thing under the knife too. I love threads that have tons of metal work, it is so interesting to see.
I'm actually getting a 49' panel off a guy this spring. It is really bad, but I didn't want it to go to the scrap. So I might just put some white walls on it, and paint a logo on the side and leave it in the yard. I can use some other stuff off it and who knows maybe someday I will work on it. Def love the panels and burbs.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#20 |
Re: 48 panel truck
99 to Life, Thank you. I too love seeing all the metal work and am glad to post it all. I know alot of people like to see how it is done. You can never learn enough on the internet and is good to see different ways of doing it. That is cool you are getting a panel. To bad it is in bad shape. You will have to post some pictures when you get it. Maybe you can fix it sometime. Mine was in sad shape when I got it. That would be cool seeeing it with your logo sitting in your yard, anything is better than the crusher.
Shannon |
#21 |
Re: 48 panel truck
shannon,
yeah here is a pic, I'm def one to think stuff isn't bad for being in PA but this is bad. I have extra grilles and fenders that I could put on her, I was gonna take the engine out and keep it for parts. I could use the dash out of it if I really needed to. I gotta fab up some rear fenders for it. throw some white walls on her and put her in the yard. Good news is it comes with a title and all for a fair price. I just got to go get it, but I have no trailer at the moment and the weather is trife. So it may have to wait till spring.
#22 |
Re: 48 panel truck
that is a really nice panel you have made .
#23 |
Re: 48 panel truck
love the stance also
#24 |
Re: 48 panel truck
Shannon, looks damn good buddy.....Jim
#25 |
Re: 48 panel truck
Daze57, oldman3, Thank you. It is finally get closer to getting on the road. I just need time.
Shannon |
