Old 08-26-2003, 01:15 PM   #1
ronniej
Will 78' suspension bolt to 71" frame?
have a chance to get a 78' Chevy truck and want to know if the 1/2 ton cross memeber and suspension will bolt up to the frame on my 71' gmc 3/4 ton. i want to keep disk brakes but would like to have 6 bolt wheels instead of the 8's on my 71'.
thanks
ronniej
ronniej is offline   Reply With Quote
Old 08-26-2003, 01:18 PM   #2
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
yes, with a little redrilling of 2 holes
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 08-26-2003, 05:03 PM   #3
tom hand
CCRider
tom hand's Avatar
Re: Will 78' suspension bolt to 71" frame?
thanks
ronniej
If it is a 78 2wd it will have 5 bolt wheels
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 08-26-2003, 06:49 PM   #4
crazy longhorn
Fabricate till you "puke"
Re: Re: Will 78' suspension bolt to 71" frame?
Yup.....you can however get 6 lug rotors aftermarket. talk with GMC Paul. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-26-2003, 09:33 PM   #5
Cap'n Hook
Workin to live...
Cap'n Hook's Avatar
I was real good in math in my day, and know for sure that a 78 foot suspension will NOT work with 71 inches of frame!!
Jason
Cap'n Hook is offline   Reply With Quote
Old 08-26-2003, 09:43 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
78 foot LOL Ya it will bolt up with little work..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-27-2003, 09:54 AM   #7
ronniej
my fault. it is a 79' chevy.
Old 08-27-2003, 12:02 PM   #8
Randy70C-10
Randy70C-10's Avatar
lol........welcome to the board from Virginia! BTW, a 79 feet doesn't work either. hehe (j/k)....78, 79.....they're the same. You'd be surprized at how many years/parts are interchangable.
Randy70C-10 is offline   Reply With Quote
Old 08-27-2003, 12:33 PM   #9
70c10
67-72 Addict!
70c10's Avatar
So the 78' front end will work and then you just add 6 lug rotors to it?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-28-2003, 07:33 PM   #10
67gmcss
Interested in doing this conversion for disc as well as power on the brakes....anyone have any pics of these two bolt holes that have to be changed? Thanks.
67gmcss is offline   Reply With Quote
Old 08-31-2003, 01:43 PM   #11
gmtrucksaddict
it is not hard swap, you will see the two holes you will needto egg out, its easy
control arm bushings on 1/2 tons changed to rubberin 73, 72 and older 1/2tons were still solid ones, 3/4 ton all years still steel, also 1 tons too
you will need the 79 balljoints and can uset he 79 hoses too, re route your steellines, 73-up hoses are longer and cheaper
gmtrucksaddict is offline   Reply With Quote
