Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 01-13-2012, 02:44 PM   #1
American Pastimes
American Pastimes's Avatar
Lizard Skin Spray on Insulation Special
We have seen that some of you where interested in the Spray on Insulation and Spray on Sound Control. So we have decided why not run a special....
Lizard skin products are sold individually or in kits
2 Gal. Sound Control $140.00
2 Gal. Ceramic Insulation $155.00
Superpro Spray Application kit $78.00
Never cut & paste again--NO GAPS, NO SEAMS, NO SCISSORS, NO SWEAT! Easy spray-on application, environmentally safe, cleans up with soap & water and can be sanded and painted body color if desired.
If you have any questions feel free to ask!
American Pastimes is offline
Old 01-13-2012, 03:03 PM   #2
themb2g
Re: Lizard Skin Spray on Insulation Special
How heavy is this stuff? I am thinking the inside of a Blazer top, would it weigh too much?
themb2g is offline
Old 01-13-2012, 03:11 PM   #3
American Pastimes
Not at all we have a local customer that has applied it to his blazer body and top
Old 01-13-2012, 04:31 PM   #4
68 short step
how much for the gun/ lizard skin coating ( the one that you think would be best for BOTH climate control, and road noise) WITH shipping to 74011
thanks
68 short step is offline
Old 01-13-2012, 04:38 PM   #5
American Pastimes
thanks
We can do a 1 gallon of each and the gun for $215.00
Old 01-13-2012, 05:52 PM   #6
Clyde65
Clyde65's Avatar
So you spray one then the other? correct?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline
Old 01-13-2012, 05:55 PM   #7
American Pastimes
Correct you would spray the insulation first, then the sound
Old 01-13-2012, 10:02 PM   #8
themb2g
How much would one gallon cover?
themb2g is offline
Old 01-14-2012, 02:40 PM   #9
American Pastimes
20-25 sqft
Old 01-15-2012, 03:15 PM   #10
Liddy71
Liddy71's Avatar
any orther way to spray this.mabe a like under coating gun
Liddy71 is offline
Old 01-16-2012, 12:23 PM   #11
Custom 68
Custom 68's Avatar
What type of prep work should be done? Is it better to use this on the inside or bottom side of cab?
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline
Old 01-16-2012, 01:38 PM   #12
Mike Bradbury
Mike Bradbury's Avatar
When I was at one of the shows the guy at the Lizard Skin booth said you can roll it on if you want. Of course it is much easier to spray I would imagine. But this stuff is really cool he had half of a frying pan coated and an ice cube on either side of the pan. The one on the bare frying pan boiled in not too much time at all and the one on the coated side remained frozen for the ten minutes we were talking.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline
Old 01-16-2012, 01:51 PM   #13
American Pastimes
if the area is sanitary " rust free" a little scotch bright and spray, if there is some surface rust remove scotch bright and spray.... this product is designed to be used on the inside of the cab but we have had a customer spray the enite outside portion of his van LOL
Old 01-16-2012, 03:43 PM   #14
themb2g
Originally Posted by American Pastimes View Post
20-25 sqft
Sounds like one gallon would not cover the inside of a Blazer, I would assume you would need about 2 gallons of each?
themb2g is offline
Old 01-16-2012, 05:09 PM   #15
American Pastimes
Blazer definitely 2 gallons
Old 02-13-2012, 02:19 AM   #16
Tmwoodall
Curious if a gallon would do floor, firewall, rear, and misc in a truck cab? Also, unclear if the texture spray gun I already have will lay this stuff down?
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline
Old 02-13-2012, 07:34 AM   #17
darkhorse970
darkhorse970's Avatar
^^^I am wondering the same thing^^^
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline
Old 02-13-2012, 04:40 PM   #18
American Pastimes
yes it will do 25 sqft.... if it is an undercoating gun you should be fine... Let us know if there are any other questions
Old 02-13-2012, 04:49 PM   #19
Tmwoodall
Thanks Ise not so good with the maff stuff.
Old 02-13-2012, 04:54 PM   #20
Tmwoodall
Also, I'll be calling in a month or so. Hoping to get my cab blasted, and the underside and firewall painted by end of this month. This stuff will be going in soon after.
Old 02-25-2012, 11:15 AM   #21
themb2g
Any deal on 2 gallons of Ceramic insulation and the gun shipped 97221?
themb2g is offline
Old 02-27-2012, 02:35 PM   #22
American Pastimes
Hi, that will be $322.00 all together.
Old 03-01-2012, 01:58 AM   #23
late68
late68's Avatar
How much for 1 gallon of each shipped to 77373? Dont need the gun.
1968 C10 SWB Dropped 5 in tha back 3 in tha front
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902
late68 is offline
Old 03-01-2012, 02:24 PM   #24
American Pastimes
Hi, the shipping would be $24.00 to 77373.
Thank you
Old 03-26-2012, 12:53 PM   #25
American Pastimes
We still have Lizard Skin on Sale! Please send a PM if you have more questions.
Closed Thread
