Old 02-01-2012, 09:36 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Camshafts..
Okay
Bought 5 qts 30wt VR1
5 Qts penzoil 10-30wt to break in the engine (WITH LUCAS ZINC ADDITIVE) Then I will change to the VR1.
Whatchall think?
Im still deciding on the camshaft Like said earlier, I wanted the xe268 but now everyone (COMP INCLUDED) Said the XE line is hard on valvetrain and is noisy. Lunati recommended the voodoo 262. I dont have any voodoo stickers yet so Ill probably order one of their cam/lifter sets from summit.
Will I be FINE using the penzoil with the breakin/zinc addtive??
Using AC delco filters
John
1999 Toyota Tacoma 4x4
Old 02-01-2012, 10:34 PM   #2
79shortbed
79shortbed's Avatar
Re: Camshafts..
Call Howards Cams... Supposedly, the ramps on their cams are far more forgiving (i.e. lazier). Tell them what your looking for, they'll hook you up! I've been contemplating going with one of their cams over the comp XE line.
1979 Custom Deluxe C10 SWB Fleetside
Help encourage me in my build.
LS 5.3 swap in progress!
79shortbed is offline   Reply With Quote
Old 02-02-2012, 12:22 AM   #3
oldblue1968chevy
Re: Camshafts..
I know I know I know.
I bought ms 9800 T felpro intake gaskets today. Is that good stuff (SURE PAID FOR IT! LOL)
Whats needed for a roller conversion (obviously cam/lifter$$)
John
Old 02-02-2012, 11:48 AM   #4
redsled87
redsled87's Avatar
Re: Camshafts..
I've had an XE256 in a 327 in my '66 Caprice for 9 yrs so far. I've got about 15,000 miles on it so far and no problems. Here is the link to the additive that I run that, I talked about yesterday. http://www.cam-shield.com/index.html You will be fine with the oils that you picked for break in and running after the break in. Comp recommened to me when I swapped cams the other year in my step side to run the VR1 after the break in. I also used the Lucas stuff to break it in before I knew about Cam Shield. I've seen alot of people talk s%$# on the Thumprs on here. The truth is, mine ran faster with one. Anyway, pick your cam and have fun with your truck.
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 02-02-2012, 01:33 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Camshafts..
The only thing I would do different, is break in with a single weight oil... like straight 30wt.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 02-02-2012, 07:14 PM   #6
oldblue1968chevy
Re: Camshafts..
Im going to see if dad will order my cam this evening for me (still not sure lol) I'll do a last minute decision (xe 268 or voodoo 60102)
I dont want to get too small of a cam
John
Old 02-02-2012, 07:42 PM   #7
GASoline71
GASoline71's Avatar
Re: Camshafts..
Those are just fine... they aren't "small". But they're not "huge" either. Clear as mud?
Flip a coin and order one already...
Gary
Old 02-02-2012, 07:45 PM   #8
oldblue1968chevy
Re: Camshafts..
Still deciding. I'll see if dad will order it for me (dont have cc/paypal of my own).
What would you pick if you had my setup gary
John
Old 02-02-2012, 07:47 PM   #9
GASoline71
GASoline71's Avatar
Re: Camshafts..
Lunati... hands down.
Gary
Old 02-02-2012, 11:40 PM   #10
oldblue1968chevy
Re: Camshafts..
Well Im calling summit soon as he gets here. (I think they close @ 10PM)...
voodoo60102 taking your word for it gary
And if that doesnt work out I'll try a comp I suppose
John
Old 02-03-2012, 08:18 AM   #11
68Stepbed
68Stepbed's Avatar
Re: Camshafts..
I'm pretty sure you won't be disappointed.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-03-2012, 12:08 PM   #12
chevyrestoguy
chevyrestoguy's Avatar
Re: Camshafts..
Here's some info for you:
The Xtreme Energy and Voodoo cam lines were designed by the same guy, Harold Brookshire. Harold is a legend in the cam business, and has been used as a "hired gun" by many cam companies to design new cam profiles. He is probably one of the sharpest minds ever when it comes to camshafts. He designed the Xtreme Energy line first, then moved over to Lunati and designed the Voodoo line. In a nutshell, the Voodoo line is essentially a much improved Xtreme cam. Yes, the Xtreme grinds have a tendency to be a little noisy due to the faster ramps and the fact that it hangs the exhaust valve open a little longer than normal. The Voodoo cams I have come in contact with are quieter than the Xtreme cams. Both Xtreme and Voodoo cams are excellent products, and you wouldn't go wrong by picking either one. My nod is to the Voodoo because it is a design based on information learned from the Xtreme series. If I had to pick a specific cam for you, I would choose the 60102. My buddy has the 60103 is his 350, and it's definitely a little rowdy cam that likes to come on at about 3000 rpm. With the 60102, you'll have the best of both worlds. It'll work with a stock converter, pull nicely from idle to 5800, it'll have a nice little lope, and should return decent mileage if you're not romping on it all the time.
I used to call Harold on occasion and pick his brain about cams. It was like going to cam class. That guy is the Einstein of cams, and he has literally tested every type, style, and fad of cams out there. His health has been declining the last few years, but I always enjoyed talking to him.
The guys on this thread nailed the cam choices. Bigger is not always better, and there's some smart guys on here who haven't fallen for that BS.
Another thing........Don't turn your idle way down just to get the "sound". Low idle speed is a sure way to kill a flat tappet hydraulic cam. Plus, it makes the engine sound lazy, in my opinion.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 02-03-2012, 08:03 PM   #13
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Camshafts..
A.K.A. UD Harold!
prostreetC-10 is offline   Reply With Quote
Old 02-03-2012, 12:20 PM   #14
FrankieD
FrankieD's Avatar
Re: Camshafts..
This is the one I bought for mine it is pretty close to the 350hp 327 that was in the 66 - 67 Nova's has a nice lumpy sound and won't kill your vacuum. it is only $86 + the price of he lifters
http://www.summitracing.com/parts/SUM-1788/
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 02-03-2012, 07:56 PM   #15
mud.man.rj
mud.man.rj's Avatar
Re: Camshafts..
Good info chevyrestguy, thanks for the school on cams, real interesting to learn more in the cam world, may try a voodoo out next time if I can find a supplier up here in The great white North, the comps are defititly a bit noisy on the ramp up, even though you get uesd to it, why have too.
mud.man.rj is offline   Reply With Quote
Old 02-04-2012, 12:38 AM   #16
oldblue1968chevy
Re: Camshafts..
OK. Waiting for paypal to clear. Hopefully saturday or sunday it should be in. Then an order off to summit
John
Old 02-04-2012, 12:39 AM   #17
oldblue1968chevy
Re: Camshafts..
Might get a summit brand oil pan too. (Need one mine leaks and is bent up.
There only like $35 bucks. My buddy ran one for abit and was happy.
John
Old 02-04-2012, 12:41 AM   #18
prostreetC-10
My Carbon Footprint
Re: Camshafts..
If you don't mind me asking......how old are you?
Old 02-04-2012, 01:13 AM   #19
oldblue1968chevy
Re: Camshafts..
19 graduated in 11 leaving for the air force in march yeah im playing with trucks excessively this month haha
John
Old 02-04-2012, 01:15 AM   #20
oldblue1968chevy
Re: Camshafts..
and why?
John
Old 02-04-2012, 01:31 AM   #21
prostreetC-10
My Carbon Footprint
Re: Camshafts..
Because for about 3/4s of this thread I had you mistaken for another member on here. It was when you said you were going to have your dad pay for something because you didn't have a CC or paypal.....it made me go "now wait a minute". That's when I put it all together and realized you were a different member! lol
Very cool to be doing this at 19 young man. Also, thanks for having the balls to serve your country!!! Keep your spirits high and your head low....
Old 02-04-2012, 01:49 AM   #22
oldblue1968chevy
Re: Camshafts..
Haha thanks. I'll keep you guys posted. I have everything together (I think) to make the swap. Just gotta get the summit order placed.
Yeah, that was me that said I have to have dad do the order stuff because I dont have my own paypal acct or anything setup for it and MO is super slow lol. Hope to have the swap done before I leave but we will see.
John
Old 02-05-2012, 07:32 PM   #23
oldblue1968chevy
Re: Camshafts..
Voodoo 60102 cam/lifters and used my $20 off summit bucks
Hope I get it in soon! I dont THINK it comes with assy lube. What can I get from autozone/etc thats the same thing/or better?
Thanks guys
Run me thru a checklist of stuff I will need
WHAT I HAVE ALREADY:
Timing chain gasket
intake manifold gasket
valve cover gaskets
fuel pump gaskets
waterpump gaskets
distributor gaskets
5 qts oil for break in
2 oil filters
5 qts oil after break in (vr1)
1 bottle of lucas zinc additive break in
WHAT I STILL NEED TO GET/WAITING ON:
?assy lube?
cam/lifters
?antifreeze?
ANYTHING ELSE? This is my DD and I cant be missing/needing something LOL
Timing set/pushrods etc are less than 10,000 miles old (Probably closer to 5k)
Thanks keep replies comming
John
Old 02-06-2012, 10:40 PM   #24
oldblue1968chevy
Re: Camshafts..
Okay,
Whats the BEST way to set valves
While running tighten till quiet lol
TDC zero lash plus 1/2 turn
and then theres something about turn motor over till X cyl pushrods start to move then do XXXXXXXXX
And how do I get engine to fire immediately?
Planning on using the 10-30 penzoil and lucas for break in? General consensus says that should be OK right? Then VR1?
John
Old 02-06-2012, 11:15 PM   #25
GASoline71
GASoline71's Avatar
Re: Camshafts..
You're gonna need to do all that before it's runnin'. The setting the valves has been beat to death... Search and you'll find it.
Gary
