01-26-2012, 02:29 AM | #1 |
Give me some help
Ok guys I fought with myself and others over and over so now it can be your turn. I'm in need of some help AND opinions. Don't hold back...really.
This is my '67. I pretty much bought it like you see apperance wise. Entire powertrain was redone by me. Everything else body and chassis was done by previous owner. It's static dropped....low.....5"front 7"rear maybe.?. It's low. Tire sizes 235 60 15 front and 275 60 15 rear. Disc brakes in front. 5 lug all around. Has a cnotch. Everything seems to be done correctly. So....should, if, or when I decide to change anything...could I? I have searched many builds on here and love the work you guys put into your trucks. I just am limited with the experience I have on wheels with backspacing and static drops and air ride. One thing I do know is that I will not cut the truck any more than the cnotch that it already has. -Can I fit 20"s on it....if so tire size? -Do I have to bag it to do anything else other than what it is? I can barely get a beer can underneath the front bumper so ya it's kind of a ***** to drive, but the stance is killer to me so I put up with it. Let me know what you all think. I tried to let ya know all I can think of but I'm sure I left some info out. Thanks |
01-26-2012, 03:16 AM | #2 |
Re: Give me some help
I think some 17 or 18 inch torq thrust IIs or similar wheel would look awesome and still have some sidewall to ride decent. I agree, the stance looks amazing!
1979 Custom Deluxe C10 SWB Fleetside Help encourage me in my build. LS 5.3 swap in progress! |
01-26-2012, 09:27 AM | #3 |
235-60-15 = 26" tall tires. The closest thing in a 20" would be 245-35-20's @ 26.75". Things to consider:
Wheel width... the 245's on a 20 would likely be an 8" wide wheel & with that drop prob require about 5.25" back spacing. This needs to be considered (is there enough room in the wheel well @ your current drop??). Tire section height... that's the height of the tires sidewall. The 245-35 series tire is short (<3.5" tall) so it will detract from the current ride quality (if it's bad now, it will only get worse). Pot holes start to become a concern for many wheels as damage could occur.
01-26-2012, 11:47 AM | #4 |
Happy to be here
It looks b!tchen right now. If you feel the need to change it, I would consider bags. Cruise low and ride high so you can bolt on those 20's you really want.
01-26-2012, 11:57 AM | #5 |
needs more $$$
X2!!! I don't see a need to change it. You said it's a pain to drive, but swapping to bags may not be the best thing if you still want to continue to ride that low...that'd be a low pressure and not the best ride. My only concern with that ride height is how low the front crossmember/lower control arms are to the ground...do you scrap them a lot?
1970 2wd Blazer |
01-26-2012, 12:08 PM | #6 |
79shortbed......thanks for your input. I've thought about this setup aswell.
01-26-2012, 12:15 PM | #7 | |
01-26-2012, 12:17 PM | #8 |
N2TRUX......Thanks. Ya it's easy to say to go to bags...another to figure out what'll fit properly and look the best at the same time. That's where my problem lies if I intend on changing anything.
01-26-2012, 12:26 PM | #9 | |
01-26-2012, 12:31 PM | #10 |
Keep it coming. Remember this....I live in NE Ohio and my truck gets to sit for 5 months a year so stuff starts building in my head. Pity me. HA!
01-26-2012, 12:31 PM | #11 |
yes but each truck you have to measure to make sure.. -Do I have to bag it to do anything else other than what it is? I would bag it as it makes life alot easier since you can adjust height I can barely get a beer can underneath the front bumper so ya it's kind of a ***** to drive, but the stance is killer to me so I put up with it. You can achive even a lower stance with bags and when driving it will ride 100% better than it does now.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
01-26-2012, 12:32 PM | #12 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=486039
01-26-2012, 12:44 PM | #13 |
Ah ha...big al....I knew you'd be chiming in. If there ever was a truck to model after in my opinion it would be yours. Your build is well thought out and just matches up perfectly.
01-26-2012, 12:47 PM | #14 | |
01-26-2012, 01:05 PM | #15 |
Something else I guess I should have considered was a staggered wheel combo also. Example: 18s and 20s
01-26-2012, 02:59 PM | #16 | |
The front inner wells will get buzzed by the tops of the tires unless they're removed or raised (when super low). Your current drop amount is prob right on the bubble & my guess is they would rub w/the 245/40-20 combo in front. For the rears, a 295-40-20 on 9.5-10" wheels would match well (like 'big-als-71).
01-26-2012, 03:28 PM | #17 | |
I truly appreciate it!!!!
01-26-2012, 04:46 PM | #18 | |
Posted via Mobile Device |
01-26-2012, 07:04 PM | #19 |
20" in the front pretty much gives you two options. Raise it or bag it. You don't want 35 series sidewalls where you live. Staggered 17 & 18 or 18 & 20 look killer on these trucks and would probably work with your suspension as is. Just have to get your b.s. right and you can have some sidewall.
. Posted via Mobile Device |
01-26-2012, 07:52 PM | #20 |
No inner fender mods here & it's running 255-40-20's....
01-26-2012, 08:02 PM | #21 |
SCOTI.....I assume that's on bags.?!
01-27-2012, 01:58 AM | #22 |
Yes it was. When air'd up to ride height, it was about where your truck appears to sit but it would buzz the tops of the wells on moderate road stuff from what I remember. Of course w/bags, it could go higher as well....
01-27-2012, 09:53 AM | #23 |
A guy with a truck
~5.5-6" static drop up front. 255/40-20 on 8.5 wheel w/ 5.25 backspacing. Rubs only on big dips...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-27-2012, 01:48 PM | #24 |
Thanks for the pic gringoloco. It just looks like mine is lower and that won't work.?.?
I'd like to get a 295/40-20 on a 10" wide wheel underneath the rear. I'm sure with the proper backspacing that won't be a problem since my ralleys backspacing pushs the tire way out to the bedside lip leaving much room there behind in empty wheel tub land. The front continues to be a major jerk off. I know it would be easy if I knew the exact drop or had put this stuff on myself. I'd love to get a 20" in there, but if it don't fit it don't fit. If I have no other option then 18" it is. Is there any way to measure for clearance or should I find a real nice local tire shop guy that might by the grace of god let me test fit different things?<----Ya right!!! I would really hate to buy two sets of front tires and wheels if I don't have to. |
01-27-2012, 02:00 PM | #25 |
A guy with a truck
It will end up higher due to the overall tire diameter. You could always swap in a known quantity drop spring...
