09-05-2003, 10:23 AM | #1 |
Life is Good !
help with wireing mess.
Ok i am haveing a great time trying to get the wiring in our burb fixed and looking pritty under the hood. I have a couple of questions for you guys that know this kind of stuff.
the first pic is of a plug that was hanging down next to the transmisson. I belive it is the reverse lights, but need some reasureance. (sp)
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" |
09-05-2003, 10:28 AM | #2 |
Life is Good !
This pic shows the wire hanging down next to the block.
The next question I have is in this pic ther is a yellow wire that is not attached to anything. It is running with the purple wire that goed to the starter. Could some one tell me what it is for? I looked at the wire diagram last night and for the life of me I can not figure out what it is for !
09-05-2003, 10:31 AM | #3 |
Resident Curmudgeon
1st pic is reverse wiring, connects to switch on 4 speed tranny.
Yellow wire goes to starter solenoid terminal, opposite of the purple wire
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
09-05-2003, 10:33 AM | #4 |
Life is Good !
Ok one more I belive ! What is this for ? Is this a stock thing that I have never seen before ? Is it something that I can take out of the truck ? I am having a hell of a time trying to get this wireing in this burban figured out. Any help would be great !
09-05-2003, 10:36 AM | #5 |
Life is Good !
CPNE, thanks for the faster than he!! reply ! I though that the yellow one went to the starter, but what is it for? please !
09-05-2003, 10:42 AM | #6 |
Life is Good !
One more just for the he!! of it. This is some of the things that I have to deal with ! Everyday I find something new that is totally wrong with this burb. Like last night the carb is spray'n fuel all over the place, tranny line to cooler is cut and bursted, spray'n fluid everywere under the hood. Oh what fun it is. Two week and all the little bugs shoud be gone !!
09-05-2003, 10:46 AM | #7 | |
Resident Curmudgeon
That other thing is not stock, where do the wires lead? It may have been some type of dual battery hookup?
09-05-2003, 11:15 AM | #8 |
Mike
If the wires are going to your starter, the p.o. added a solenoid to cure a hot start problem.It looks the same as older ford solenoids.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
09-05-2003, 11:19 AM | #9 | |
Life is Good !
09-05-2003, 11:21 AM | #10 |
On the picture of the solenoid, my guess is that it is tied into the starter solenoid to help solve a "hot start" problem based on its location.
On your factory starter solenoid, the purple wire goes on the inside and the yellow wire goes on the outside post. The yellow wire is not needed if your vehicle has an HEI distributor. Godd luck, it looks like you are trying to straighten out a plate of spaggetti! Jim |
09-05-2003, 11:30 AM | #11 |
the yellow wire went to the small outside terminal of the starter it was there to provide a full 12 volts to the points-type distributor coilif it has been changed to a hei type of distributor it's not needed, and if you have a hei type distrib you have to make sure that you have a new feed goig to it because the original feed for the distrib is a resistance wire that only feeds 7-8 volts to the coil
09-05-2003, 11:30 AM | #12 |
The first wire is for the reverse light . The switch should be located on upper driver side of your tranny . Assuming it hasn't been converted to automatic
09-05-2003, 12:14 PM | #13 | |
Life is Good !
WOW all this info that i should have put in to begin with. Now lets start with the wireing to the started just to get eveything rite.
purple = starter yellow = starter if i have the coil set up. It is HEI set now. so the yellow wire is no longer needed !! CORRECT As for the solenoid it is not connected to the starter at all as far as I can tell. The person before me of even before him has put the seats out of a 1996 chevy truck all electric, plus the electric fan, and the rear A/C ( that is not stock). Quote:
09-05-2003, 12:25 PM | #14 |
Half a bubble off!
Correct, the yellow wire in no longer used with HEI.
That sure looks like a remote solenoid setup to me.
Just call me LB. '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
09-05-2003, 12:33 PM | #15 | |
Resident Curmudgeon
09-05-2003, 12:54 PM | #16 | ||
Life is Good !
09-05-2003, 01:01 PM | #17 |
Resident Curmudgeon
09-05-2003, 01:15 PM | #18 |
sent ya a pm with all the info I know about it.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " |
09-05-2003, 01:20 PM | #19 |
do what i did but with only one harness at a time, take the harness completly out of the truck, then find a spot like your living room floor so you can see the tv, get your wiring diagram, lots of extra wire, and all your crimping supplies, and tape, at the place where it plugs to the fuse block cut about 6-10 inches off splice in a new peice of wire and then run it along the original until you get the length that you need and then splice the new piece and voila, a like new wireing harness
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
09-05-2003, 01:54 PM | #20 |
Guys,
With reference to the multi-wire plug in the first pic, it sure looks like there are four wires and four terminals there. It looks like the tail light harness--firewall connector to me. Of course, I wear thick glasses. . . .
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
09-05-2003, 02:16 PM | #21 |
ok ok
1st pic, reverse lights, from a np435. Has been converted to a 700r4 3rd and 4th pic, relay added by PO for the rear ac to be turned on by a switch under the dash. It is now "tempprally" hooked up to run the electric fan.
09-05-2003, 02:26 PM | #22 |
Life is Good !
thanks for the PM Jason, sent you one back.
everyone thanks for the input !! I will keep eveyone updated, with my progress on the burb !
09-05-2003, 04:43 PM | #23 |
Try going here. It might help to solve your problems? It's sure helped me rewire my engine and front lights.
http://www.geocities.com/chevroletc1070/wiringdias.html Hope this helps to clear up any problems?
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
09-08-2003, 11:51 PM | #24 |
Life is Good !
ok guys thanks for all the help but i got a few more little questions for you !! here goes
The solenoid has been removed ! Now how do I hook up the hot wire to the new fuse block added for the power seats? can I add it to the + battercable it's self? Or should I add it to the little block thing on the fire wall? I'll get a pic ! In the pic with the solenoid above it is next to the relay. In the next pic there is a yellow (spliced) to a red wire that one runs down to the starter ! Also the back up light plug thing. now ther is this one here on the right, it goes from green (spliced) to red, that was pluged into the temp gauge, on the block. Is the green the correct color for the temp wire? Thanks
09-08-2003, 11:57 PM | #25 |
Life is Good !
This is what I get to do next ! So next my question is anyone want to help ? J/K Dose anyone elses look like that under ther dash ? just wondering !
