01-29-2012, 02:02 PM | #1 |
305 v6 power steering question
I was tryn to figure out if the 305 v6 ever had any power steering do they make any aftermarket power steering whole assmeblys for these engine or would I just have look out for a good assembly if i ever find one
Thanks,marco Posted via Mobile Device |
01-29-2012, 02:54 PM | #2 |
Registered Loser
Re: 305 v6 power steering question
Yes, they did. I bought a used stock PS pump and bracket off ebay a couple of years ago. To my knowledge nobody makes any aftermarket parts for these motors except tranny adapter plates and those are really expensive.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
01-29-2012, 07:18 PM | #3 |
Willi be looking at spendin high dollers just for the whole assembly even though its a used item I'm really thinking of adding this power steerin i f ever get my hands on one sence the steering is nerve racking espacilly when I have the 4 speed manuel tranny
01-29-2012, 07:27 PM | #4 |
Do a search on here there a lot of good threads upgrading to a power steering box. You can get the double grove pulleys off of a big truck. You can use the power steering brackets off of a 67-69 pick up also. they would be easier to find. A T rockdriller made his own brackets for his power steering.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
01-29-2012, 07:43 PM | #5 |
Can someone write awhole list of parts needed to properly install the the power steering even pics would be a real help well not just me but others that would like to know the same question
01-29-2012, 08:42 PM | #6 |
http://s1299.photobucket.com/user/jb...23904108567829 |
01-29-2012, 10:04 PM | #7 |
Really nice albume with all the info thanks jbgroby so the only thing I was wondering now was the bracket dose it have to be from 305 v6 engine.
01-29-2012, 10:30 PM | #8 |
Yes it does. I'm seriously thinking that IF we pitch together, one of us could take one of the OEM brackets and have it remade at a good shop. YOU out there Capt. Fab?
01-29-2012, 10:33 PM | #9 |
That would really be nice to see one fab for the 305 v6 engine
Posted via Mobile Device Last edited by Old_1965_Gmc; 01-30-2012 at 12:53 AM. |
01-30-2012, 12:58 AM | #10 |
Hey captainfab ever though of fabbing a power steering bracket for the 305 v6 engines
Posted via Mobile Device Posted via Mobile Device |
01-30-2012, 11:00 PM | #11 |
Jbgroby the pic #2 on ur albume do I have to have one like that from the same year make and model or can I use a diffrent later model cyclinder ram
01-30-2012, 11:32 PM | #12 |
I'm not sure if you can use a different ram set up. I would suspect that you could but you will need to check with one of the guru's.
01-30-2012, 11:42 PM | #13 |
Well I recently upgrade my 8 lug to a later c10 disk brake that's y I asked if I can just use a later model type
01-31-2012, 09:06 AM | #14 |
Check out rock tonka pic it has a factory power steering pump
http://67-72chevytrucks.com/vboard/s...d.php?t=505836
02-01-2012, 09:59 PM | #15 |
That would be suthing nice to have and origanl even better but the I know when it come n lookin for sunthin like that its like findn a needle in the hey sack just lookin for simple build if I can ever find the nessary part and stuff
02-02-2012, 02:10 AM | #16 |
60-66 Nut
If I had the original brackets to go off of, no problem fabricating new brackets. I would have to see if I could find a V6 around here to check fitment on though.
02-02-2012, 08:44 AM | #17 |
I have both sets of V6 power steering brackets (no they are not for sale ) 60-66 and the later version 67-69 for pickups as big truck brackets are different.
The later version will work on the early trucks. Capt if you want I could mount it up on my V6 take some pics and send you the brackets so you can copy them.
02-02-2012, 09:07 AM | #18 | |
02-02-2012, 11:16 PM | #19 |
Yea if u commit in makeing the bracket let us know when its done ill have payment ready for u captainfab
02-03-2012, 01:39 AM | #20 | ||
60-66 Nut
Is there an advantage to either the early set or the later set of brackets. I wonder which ones would be easier to reproduce. Maybe if I could see some pics of both sets.
I'll send you an email Jake. Quote:
02-03-2012, 09:16 AM | #21 |
I'll get pics up Saturday.
02-04-2012, 07:41 PM | #22 |
The brackets are relatively straight forward...
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
02-05-2012, 12:23 AM | #23 |
60-66 Nut
THanks for posting the pics RockTonka. Yes those look fairly easy to reproduce. These are a little different than the one jgroby sent pics of.
Are these power steering pumps hard to get, or expensive? If so, I'm thinking it may be better to design new brackets to accomodate a newer, easily obtainable, less costly, pump
02-05-2012, 09:48 AM | #24 |
Those brackets in RockTonka pics would be easy to reproduce but I have only seen that pump on the GMC I don't know if it came on any other GM product. Here is the bracket for the later model pump it sit in a cradle.
If you could make the early bracket work on the later model pump that would be the best option IMO
02-05-2012, 10:16 AM | #25 |
