Old 01-31-2012, 05:53 PM   #1
purebred
John Deere Blitz Black paint?
Anybody ever use Blitz black paint on their trucks? I have been reading its pretty good stuff.
purebred is offline   Reply With Quote
Old 01-31-2012, 05:54 PM   #2
1963c-10
1963c-10's Avatar
Re: John Deere Blitz Black paint?
No, but have used John Deere corn head grease for a long time. Great in steering boxes.
1964 Short bed trailer
Old 01-31-2012, 06:11 PM   #3
jimmydean
jimmydean's Avatar
That is the "go-to" paint for hot rods. Durable, cheap, looks good.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-31-2012, 06:37 PM   #4
96duck
96duck's Avatar
I know ive seen post on this before. does anybody have the correct mix ratio for it?
96duck is offline   Reply With Quote
Old 01-31-2012, 06:41 PM   #5
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Here is the paint that would be better to use. Price wise I have no idea what a tractor paint cost. But there products work and hold up. To paint a fleet side 8 foot truck in side and out 2 gallons will get you there.
You need UV protection. Paint for farm implements do not have that I am aware of. If I am wrong , ok I would still not use it
http://www.tcpglobal.com/kustomshop/ksflatz.aspx
GMR-PERFORMANCE is offline   Reply With Quote
Old 01-31-2012, 06:44 PM   #6
raven316
I painted my 66 Fleetside with it 5 years ago. I wanted the look it gave and I never wanted to baby the truck, I use it to cruise and haul garden stuff. The paint has held up quite well in my opinion, not perfect but I always get second looks and thumbs up.
http://farm8.staticflickr.com/7172/6...3bf73217_b.jpg
http://farm8.staticflickr.com/7026/6...d9eb0930_b.jpg
let me know how else I might help/
raven316 is offline   Reply With Quote
Old 01-31-2012, 06:50 PM   #7
raven316
Here's a shot of it after I had it painted
http://farm1.staticflickr.com/71/193...675c3546_o.jpg
and here I am working on it, no garage as you can see
http://farm1.staticflickr.com/73/193...957f256f_o.jpg
Old 01-31-2012, 06:53 PM   #8
raven316
It was $30 a gallon in 2005.
Here's a huge thread from Hotrodder.com. They finally closed it but it has information that will help anyone decide whatever they want to decide. I'm no chemist, but there are chemists on there, but it was inexpensive and did what I wanted it to do.
http://www.hotrodders.com/forum/john...ack-31993.html
I am in no way disagreeing with what you are saying, obviously you are in the business. Just offering my perspective as a cherry.
Old 01-31-2012, 07:22 PM   #9
losthope
losthope's Avatar
I painted my 54 ford blitz black it is cheap and turns out nice, i wanted the flat black hot rod primer look but with actual paint durability, the only problem i had was getting some in California since it is illegal here, but i got it. im pretty sure "Markb01" painted his stepside gmc blitz black and might be able to give you some tips...as far as mixing ratio i just followed the mixing ratio on the can...google blitz black and youll have tons of information.
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 01-31-2012, 07:29 PM   #10
VA72C10
VA72C10
VA72C10's Avatar
$60 for two gallons of JDB vs 300 for two gallons of the Hot rod flatz shows why many use it....
I've seen several trucks painted with it and they look great. Plus, it is made to hold up to the elements since farm equipment is used outside So it's pretty durable too.
That being said, I saw a hot rod flatz red paint job in person (5150's roadster blazer) and it looks great...
Old 01-31-2012, 07:31 PM   #11
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Talk to Mark.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-31-2012, 07:34 PM   #12
LostMy65
LostMy65's Avatar
Here you go:
http://67-72chevytrucks.com/vboard/s...d.php?t=432915
Old 01-31-2012, 09:10 PM   #13
purebred
Thank you Gents, just what I thought, At 174.00 a gallon for the JBD,I think I will go with the Blitz Black, if you can,t trust a farmer and rancher in Texas that paints their tractors and implements with it who can you trust. Especially at 34.00 a gallon at John Deere. Thanks for your opinions.
Old 01-31-2012, 09:13 PM   #14
purebred
Forgot to add, 8 parts paint to 1 part thinner, as for UV rating, here in this Texas sun, if UV rating is not good with this paint, than I don't know what product would be .
Old 01-31-2012, 09:45 PM   #15
bama63
bama63's Avatar
i have used a lot of the ppg synthetic enamels over the past years ppg #ALK200 can be mixed in most any color and can be used with or without hardener and comes ready to spray right out of the can,if you need to thin use the recommended xylene as a thinner and for $42.00 a gallon you cant beat it and it holds up very well to uv for many years
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 01-31-2012, 10:46 PM   #16
old cruiser
old cruiser's Avatar
If your wanting to repaint with different paint in the future jd blitz black will need to be totally removed before you do so , as far as I,m aware this stuff wont let other paints stick to it. I found this to be true with my trailer that I painted in blitz bl and when I practiced my striping on it even after a week or so when you rub on the stripes they wipe off.
Other paints may work but other than that the blck is as tough as nails.
old cruiser is offline   Reply With Quote
Old 01-31-2012, 11:15 PM   #17
markeb01
Senior Enthusiast
markeb01's Avatar
I painted my truck with Blitz Black in 2009. It does live in a garage, but has been driven in all weather conditions. On the rare occasions it gets washed, the finish looks the same as when the paint was applied. There has been no perceivable deterioration so far.
I always thin with Acrylic Enamel Reducer when spraying any enamel paint. It’s more expensive than acetone or mineral spirits and must be purchased at an auto paint supply store, but it allows you to change the properties of how the paint flows and the finish it produces. Many articles I’ve read suggest 6 to 1, 8 to 1, or 10 to 1 - paint to thinner ratio. I tested 7 different mixes before I came up with the finish I wanted. My final primary batch of paint was mixed 1 part slow temp acrylic enamel reducer to 10 parts paint, and sprayed on a day with temps in the high 80’s. It came out with a perfect flat/satin finish nearly identical to what comes out of the spray can, but in a much heavier flow coat.
I have been very pleased with this paint. It’s cheap and durable, and I’ve had more compliments on the truck wearing this paint than I ever did when it was gloss black lacquer. It hasn’t received any maintenance other than being washed.
Here are a few tips:
1. Test mix and test spray something else before you commit to paint the vehicle. This may require several tests until you get the finish you want. Apply a thin mist coat, wait 20 minutes, apply 1-2 more wet coats and then let it dry for about 30-45 minutes. That's what the final results will look like.
2. Mix more than you need to complete the whole job all at once before you start. You can always pour the leftover back into the can, if you do not use hardener.
3. Hardener will make it last longer and flow out nice, but the hardener contains isocyanates and should not be sprayed without breathing gear and a full bunny suit. Also don't use hardener if spraying over lacquer or it is likely to lift the old paint.
Here are a few shots of how the truck looks in different lighting conditions:
Old 02-01-2012, 08:41 AM   #18
purebred
MAN, ALL I CAN SAY IS GORGIOUS, hope mine comes out half as good, thanks for the info.
Old 02-01-2012, 09:26 AM   #19
scottofksu
scottofksu's Avatar
Originally Posted by purebred View Post
man, all i can say is gorgious, hope mine comes out half as good, thanks for the info.
x2!!!
scottofksu is offline   Reply With Quote
Old 02-01-2012, 10:30 AM   #20
erock805
erock805's Avatar
painted chassis with the stuff for a few years...once its on, its hell to get off...gums up flap discs and sanding pads
super tuff stuff.
"Do what you want to the girl, but leave me alone!"
erock805 is offline   Reply With Quote
Old 02-01-2012, 10:34 AM   #21
GMR-PERFORMANCE
I agree Marks truck is very sharp looking.
I went with a gun smoke grey and burgundy. But I guess the only down side is "if" there is repair to be done in the future the paint removal process.
here is the two colors I am using I have to upload more pics. the firewall is the Grey, and the dash and roof ( dusty) is the burgundy. These are single stage flat paints, with pearl and metallic in them. In the sun the burgundy really pops.
I had to laugh about the CA paint deal, we have a hard time getting lead weights to the wheels. Eveything has gone to steel, so we use dyna beads for the bikes now, but the amount of weights they have to install out here now is stupid as steel ways nothing compared to lead.
Old 02-01-2012, 11:24 AM   #22
grancuda
grancuda's Avatar
I too would go with the Hotrod Flatz or even a 2 stage with black and a flattner in the clear.
grancuda is offline   Reply With Quote
Old 02-01-2012, 11:29 AM   #23
chemlab
chemlab's Avatar
i have it on mine, blitz black is the satin, $30gal. , got it at the JD store in goodyear.
i believe the ratio on the can calls for 10:1
chemlab is offline   Reply With Quote
Old 02-03-2012, 09:12 PM   #24
McCoyAZ
McCoyAZ's Avatar
So i'm curious to know if the "blitz" paint comes in anything other than black?
I was watching a TV show, one of the West Coast Custom ones, and they were showing some of the projects that Jessee James had done. One of them was a 50's chevy truck and it was painted like a rust/red dead flat color. Looked real sharp.
Mark's truck is drop dead beautiful. I love that flat look.
McCoyAZ is offline   Reply With Quote
Old 02-03-2012, 10:28 PM   #25
biohazardbill
Doing some reading they also say you can get it at TSC. It is labelled Valspar Tractor & Implement Spray. Just repeating what I have read and that buying it at TSC doesnt have the JD markup. Can anyone confirm this?
biohazardbill is offline   Reply With Quote
