02-02-2012, 01:13 AM | #1 |
~~~WTB tach and fuel gauge all in one for my 78 chevy~~~~
looking for a cluster from a heavy duty truck that has the tach and fuel on the same gauge. Let me know what you got and how much to ship to 55060. Thanks, Charlie
02-02-2012, 01:24 AM | #2 |
yeller
Re: ~~~WTB tach and fuel gauge all in one for my 78 chevy~~~~
Chuck, I don't have the link handy, but there is a company that makes just the tach/fuel gauge insert, and all you have to do is swap out your existing fuel gauge for it and run the tack wiring. No cluster swap required. If you search the 73-87 forum, you will likely find it. I plan on getting one of these for my 75. I think they are just under $200...comparable to a medium duty cluster that may or may not work, and requires more installation time.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
02-02-2012, 08:24 AM | #3 |
From what year?? I have one from an early 70s and one from the 80s. The 80s has the 4k tach but will work on a gasser. I haven't had time to take pics and post up....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
02-02-2012, 10:59 AM | #4 |
I put one in my truck, super easy. It was $210 shipped. Look in the 73-87 message board for "combo Tach/Fuel gauge cluster" head.
John 82 Chevy Silverado 350ci/TH350 |
02-02-2012, 11:16 AM | #5 |
Roadtrip!
I have a couple... PM sent
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
02-02-2012, 11:56 AM | #6 |
I want to put it in my 78 big 10. Truck is completely stock but I just want a factory tach instead of a aftermarket one cluttering up my dash somewhere. Jeff you should call me
02-02-2012, 03:28 PM | #7 |
Roadtrip!
Here is one i have.
Not sure of the exact year, but should be close. The lens has some scratching, but i didn't try to clean it or anything.
02-02-2012, 03:54 PM | #8 |
yeller
Eric, that is an early one (amp gauge), and will not work with a late 70's truck (volt gauge). Wiring is completely different, and can cause problems if simply stabbed in the truck
02-02-2012, 03:57 PM | #9 |
Roadtrip!
Jeff, i thought the early ones had a mechanical oil gauge? What year would this cluster be? I also have one with an 85 mph speedo, but not the newer font style... 79-80 maybe?
02-02-2012, 09:29 PM | #10 |
That is weird. Has an AMP gauge but electric oil gauge. Mine is like that one but has the mech oil gauge, and a single air pressure gauge. I will get some pics this weekend....
02-02-2012, 09:45 PM | #11 |
Getting Old; Going Broke
The big trucks went longer with the old stuff. Chances are that cluster pictured is out of about a 75-77 C60 or something with a big 6 since it has a 5k tach. Still wired like the 73/74 smaller squares and I'd be a bit scared of the AMP part.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
02-03-2012, 01:37 AM | #12 |
I seriously only want the fuel gauge with tach! If i was to buy this will I be able to pull my stock fuel gauge and put this one in and hand wire tach? This is the problem I want to use my cluster its perfect with working clock. Just so used to driving a square with factory tach and this is one of only a few options my 78 is missing...... So any input here will help me out big time..Thanks guys!! And tms Thanks for posting pics! I like the whole vacum gauge and everything and I want that cluster but the only thing I would use is the tach part..... I'm interested in it for sure depending the hoops I have to jump through to make the fuel gauge work!!!!!
02-03-2012, 01:40 AM | #13 |
btw my 75 2wd shorty had a factory tach cluster with a amp gauge so why would the heavy trucks still run this? just curious???????
02-03-2012, 08:19 AM | #14 |
You can swap in just the tach/fuel gauge but need to swap the circuit board too. Not hard, but be easier just to unplug on cluster and plug in another. Also, there is a post somewhere how to convert amp to volt gauge, IIRC just a matter of moving one wire.
02-03-2012, 10:03 AM | #15 | |
yeller
Chuck, you might be able to get away with just swapping the gauge out and running your own wire for the tach...I don't know. To me, it makes sense just to buy the one J Knight purchased, plug and play install...doesn't get much easier and less confusing than that...looks OE too. I'll call you this weekend.
02-05-2012, 10:23 AM | #16 |
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
02-06-2012, 06:52 AM | #17 |
Charlie,
I have a tach/fuel combo by itself, but the needle is broken on the fuel gauge. Should be easy enough to swap one from another of the small gauges, but wanted to mention it. '70s style font, can't remember if it has the blue ring or not. I don't know what is involved with cutting the housing to fit the tach, or wiring the fuel gauge (without the proper circuit board)... I don't know if this is something you want or not, can get a pic if needed (at work now). Not sure what its worth, PM if interested... Thanks, Joe Posted via Mobile Device |
02-06-2012, 08:15 AM | #18 |
Clusters are the same between the two, just won't have the hole behind the tach for the wire harness to go thru. Circuits are totally different, but could modify it to work.
I just picked up another oddball one, out of an early 70s, 4K tach with small fuel gauge but has a vacuum gauge. I was under the impression only diesels got the 4k tach. Says "V-EIGHT" on the side of the truck. But that can be easily swapped.
02-08-2012, 09:22 PM | #19 |
78K & 79C Jimmys
you should be able to swap the volt gauge in,move a few wires around as needed
if the tach is for a six ,won't work for an 8 my 78 with tach,79 without....both blue rings
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
02-09-2012, 03:55 PM | #20 |
Thanks! Now to buy someones!!!
10-25-2012, 12:13 PM | #21 |
10-25-2012, 12:14 PM | #22 |
Too much stuff is tach still available?
10-28-2012, 12:12 AM | #23 |
If you want a 77-78 style tach/gauge cluster I have one-PM me if you want it or want to see pics-it's very nice and has complete tach harness as well. It is not a big series truck cluster-but is set up with a volt gauge, elec. oil psi gauge and of course the tach-and NO broken mounting tabs. $150 plus shipping takes it.
10-28-2012, 12:19 AM | #24 |
Here it is-I have two of these specific ones....this one is the nicer of the two.
10-28-2012, 08:40 AM | #25 |
how much?
