Equal opportunity joke ofender
![]() Join Date: Oct 2011
71' Blazer Rust bucket build
Well here goes......
I have put the 68' panel on hold after buying this Blazer. I feel since i have been out of the auto body business for the last 15 years I would give the Blazer a shot before messing with the panel. I found the truck on Craigs List a few months back and did not look real close at it before buying it. I knew it had some rust issues but was not quite prepared for what I pulled out of it today. Original intention was to buy the truck to part out but after I got it home and started looking at it ........sitting in it........looking at it some more, over and over I decided I wanted to save it instead. I must have more money than brains but that is my intention so far. Here are some pictures of it like I bought it.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
Re: 71' Blazer Rust bucket build
The previous owner removed the rear seat and installed 2nd Gen Blazer seats up front but it still has the original center console
Today I decided to start ripping the interior out so that i could see just how much rot there was in the floor areas.
The PO had placed a sheet of 1/2" plywood on the floor with carpet pad on top of that. Then they wrapped the entire floor, side walls and front floor in a black cloth. Needless to say with the leaks from the rear hatch and holes in the floor the plywood was not in real good shape.
As I was cleaning up the plywood mulch I noticed a lot of mud built up around the whell wells. I was like man gotta get that mess out so it can dry up then I can see how bad it really is. Well I did not have to wait, cause once I hauled my fat butt up in I realized hey, that ain't dirt
Here are the after shots
I assume at one time he must have had a problem with the gas tank
And...... I am almost certain he was a commercial roofer. I thought is was more bondo across the rear floor sill but it was actually aluminum tape with mastic material on it. Some places come up easy where they taped over dirt and grease but other cleaner areas are proving to be quite difficult to get off. The last picture is some of the bondo and roofing caulk that was pulled out from around the wheel wells, it was just heaped into the top of the cross bracing as well. The 2nd picture was a patch they made out of aluminum roofing metal and it was severely corroded.
I'm in on this one. I feel for ya man!!!
Looks like I am going to need some rear floor sections worse than I thought. The floor flanges are also gone on the wheel tubs so will need them as well. I assume they are same as pickups so should not be to hard to find them. good thing is when I tore the side boxes out of the rear I found a stash of some goodies. Misc. hatch hinges and hardware, K5 emblems Stainless sill plates, Extra hoses and belts and the missing black visors from the front. I did not realize the tops of the cabinets were made to come off.
Then I moved to the front floor area.....not much better but I have seen worse. The seats appear to be out of a 2nd gen Blazer because of the poor attempt at making the brackets work. I had to take a picture of the Pass side rear hold down because of the way it was mounted. PO had used spacers to lift it up off of the floor to compensate for the angle of the seat being off I suppose. After I removed the two bolts that were holding the front of the seat ( supposed to be four buts whos looking right) and removed the seat out of the truck, I started removing the rear hold down you will have to look at the pictures to see what the spacers were. ( and yes they are Sears brand LOL)
I cant find the picture of the driver side seat but PO installed a wooden 1x4 across the back of the seat bracket to kick it upand be able to use factory mounting holes. As if that was not bad enough once I moved the floor covering out of the way, what else did I find???? not to be outdone with the sockets on the pass side they used two nice Sears screwdrivers to shim the wood up and left them. I am hoping at the rate I am finding tools I may need to go get another box.
Thanks man, I got my work cut out for me but I think it will be worth it in the end.
Richard
I am still looking for a rear floor even if it is smaller sections. I could also use wheel wells and the inner 1/4 panel sections that the tubs bolt to
Richard
#15 |
Subscribed. Good thing you are a body guy. Glad you are saving it. It will be worth it in the end.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
#16 | |
KEEP AT IT IT WILL BE WORTH IT and place it in the wall once I get the truck in the garage. ![]()
#17 |
I'm glad that you are saving it too. I hate to see them forgotten about or even worse, junked. I'll definitely follow this one, I'm most interested in watching your inner/outer rocker replacement.
1972 K5 Auto 4x4 factory air 2007 Silverado extended cab Z71 |
#18 | |
Richard
#19 |
Here are some pictures of the front floor area and rocker area. I will be ordering the few parts I dont already have in the next few days so I can get started. Looks like its going to be a fun project. I have also decided to take the 68' clip off of the panel truck and put on this one. It needs a little work but not as much as the 71' clip, and I like the 68' style better anyway.
#20 |
Helps when you attach the pictures
#21 |
If you notice in the last picture above you can see the PO attemted to weld in some angle and flat bar bracing. Must have been 1st time with a mig. I pulled it all apart by hand. ZERO penetration on the welds.
The last picture shows the DS B pillar area. I am almost positive that it will not look any better once I start digging. More likely it will look like the pass. side.
#22 |
#23 |
Looks like mine, I just finished up the front floors and boxes and I can't believe I got all that done. Keep at it. Subscribed
#24 |
It is amazing what some people are completely ok with doing to "fix" their cars or trucks. I guess they feel that if the surface looks ok then everything is done right. I'm glad you are tearing into it. I had a "professional" body man, I use that term loosely, fix mine and I have ended up tearing it all apart to find they covered problems up.
1972 K5 Auto 4x4 factory air 2007 Silverado extended cab Z71 Last edited by Ridnhi; 02-05-2012 at 12:26 AM. |
#25 |
Ridni,
I learned years ago that the majority of the time only I am willing to take my projects as far as they need to go. Most shops around here basically want to get it covered and out the door. Warbucket thanks for the extra parts you had. They will get used. I could still use some floor pans and rear. Wheel tubs Richard Posted via Mobile Device
