01-26-2012, 04:01 PM | #176 |
I'm just glad to be here!
Re: Project Goldilocks, '66 C10 SWB BBW Build
Here is another link for performance parts for the 250 inline 6.
http://www.cliffordperformance.net/ Looks like they only have a split header for the 250. You could fab your own 6 into 1 header. on the 250 there IS 6 ports, but ports (2 & 3) and (4 & 5) only have bolt holes for the flange on the outter edges of the ports and not between them. If you look at the head and the gasket, those pairs of ports are divided by about a 1/4" of material making them separate ports. The cast split headers on the stovebolt web site look like 4 ports on the outside, but I bet they are split on the inside... I use to have a 6 in mine, made 250 hp easy. You could build 300 hp and still be steatable with a standard trans...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-26-2012, 07:25 PM | #177 | ||
Sweet! How much faster does it go now?!? I'm thinking of some sort of sheetmetal duct work and airbox that seals down on the air filters. Quote:
You're right, I was looking at dad's 292 from about 20 feet away when I was posting and only saw the four exhaust legs on the manifold. No problem making my own headers if I need to. The guys in brazil are getting 300+ hp at the wheels, the one guy I posted vids of is getting 373hp at the wheels with 15:1 CR and methanol!!
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
01-26-2012, 09:24 PM | #178 |
Pump fuel will probably be the limiting factor, the turbo will more than make up for the breathing limitations of a straight 6. I can't wait to see your progress, very cool stuff.
02-05-2012, 06:31 PM | #179 |
Nice build thread! I texted you last year about the extra bbw cab you had for sale, and I think I still have your number saved in my phone. I'm originally from Abbeville. I was looking through your posts and I think I recognize the place in some of your pics. Do you work at the place behind the high school right off of the 28 bypass? I remember taking a 50 Pontiac Chieftain convertible there to have a windshield put in when I worked at John's Rod Shop. After I left John's I worked at the Line-X right there across from the high school on 28 bypass.
64 Stepside.. A work in progress.. |
02-06-2012, 11:54 AM | #180 | ||
02-06-2012, 02:31 PM | #181 |
fantastic work... and well written thread too.
man, i'm enjoying your build. and thanks. |
02-06-2012, 07:43 PM | #182 | |
For my ram air I am thinking of a cowl induction not dissimilar to the old GTO RAM III and RAM IV but with one of those dog eared Oldsmobile air intakes. Fun times !!
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
02-06-2012, 08:21 PM | #183 |
[QUOTE=theastronaut;5170017]I'll use an electric pump and run the line thru a gutted stock pump. Best of both worlds.
Thanks McMurphy I am referring to octane, 93 pump gas will limit the horsepower for a street ride. Race fuel or octane boost if the compression is too high to hit the upper horsepower. I'm no builder, just what my builder told me. Do you have a way around that, or does the turbo compensate for the pump gas?
02-06-2012, 09:52 PM | #184 |
Thought I recognized the place. I'd love to check out your project sometime when I'm back down that way. I need to get down there within the next few weeks to get some work done on mine(It's at my parent's house in Abbeville). My frame is sitting outside in primer, and I've got to get it painted before it starts to rust lol.
02-07-2012, 01:00 AM | #185 | ||||
02-07-2012, 03:10 AM | #186 |
We have 105 octane E85 ethanol/gas blend at nearly every station around here and it's a good bit cheaper than regular 87 octane gasoline. It only has about 70-80% of the thermal energy that gasoline has, so it has to be jetted richer to compensate. It uses more fuel that way but since it's cheaper the cost per mile should be about the same. Since its 85% alcohol it also runs way cooler than gas does, so it helps the engine to run cool even with way high compression. For now I'll use three two barrel Dellorto carbs or triple throttle body efi. A turbo isn't out of the question but that would be way down the road after everything else is done and sorted out.
Aaaah the E85 didn't consider that, we don't have it here in canuck ville. I got into straight sixes when I had a '48 Chev Coupe, so I'm looking forward to your progress.
03-08-2012, 11:32 PM | #187 |
Well, it looks like it'll be even longer til I get started back on Goldilocks. The engine in my daily started knocking so I've got to fix that now. I got the engine out tonight and it's torn down to a short block, hope to have it back together in a few weeks, depending on the extent of damage and the time it takes for the trip to California and back for machine work. It's getting harder and harder to find quality parts for VW's and even tougher to find shops that know how to work on them. I'll try to get started back on the frame while everything is at the machine shop, the symptoms of C10 fever are still in full effect and I need a good dose of project progress!
03-09-2012, 12:17 AM | #188 |
Artist
or.... more cowbell!
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66 |
03-09-2012, 12:49 AM | #189 |
Check your email!!
03-09-2012, 01:28 AM | #190 |
Artist
Your killing me smalls!!
03-16-2012, 11:53 AM | #191 |
Ok, to keep everyone "in the know", I'd emailed MalibuKasey a link to a post on here about some KILLER custom billet 18x8 and 18x10 wheels that look just like stockers, even down to the rivets on the backside! I've been drooling over these things since they were first posted, but the price tag is, umm, "steep" to say the least. I'd have to sell Goldilocks and my VW to be able to afford them!
Details here: http://67-72chevytrucks.com/vboard/s...8&postcount=43
03-16-2012, 11:58 AM | #192 |
The VW knock turned out to be an easy and cheap fix, it was just a broken cam thrust flange. It didn't tear anything else up so no machine work needed, and only about $150 in parts to fix the damage and upgrade so it doesn't happen again. That means more cash left over for Goldilocks. I should be picking up a T56 soon so I can get everything mocked up.
03-16-2012, 02:52 PM | #193 |
Rollin' Old Skool
glad to hear about the Beetle...kinda wish i still had my '63, but with all the traffic around here i'll stick with my automatic S-10 (i'm no manual trans. expert, ha)....and that's interesting about the wheels...i subscribed just so i can keep up with whatever updates are made...but kinda like Scoti, it looks like i'll be sticking with 15's, lol
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
03-16-2012, 04:30 PM | #194 | |
I don't think I could drive an automatic daily, I'd go crazy! Our whole family only owns one automatic car, so I grew up driving stick and still love the extra driver interaction and the ablity to always to be in the right gear at the right time- something an auto can't always do.
03-16-2012, 09:06 PM | #195 | |
Rollin' Old Skool
http://smg.photobucket.com/albums/v6...20VW%20Beetle/
03-17-2012, 10:43 PM | #196 |
I am planning to go manual trans in mine too!!
03-24-2012, 03:45 PM | #197 |
I've been following you build and I would like to know if you ran into any issues when you flipped the center crossmember? I was considering buying a new dropped crossmember but I might change my mind after seeing what you did. I've seen builders just flip the trailing arm mounts (which is a lot of rivets to remove!) but not the whole crossmember.
03-24-2012, 08:18 PM | #198 | |
03-24-2012, 10:44 PM | #199 |
Since there no physical progress being accomplished, I'll post the "mental progress".
When I bought the truck it came with an old Esso filling station key chain, and the previous owner told me the history of the truck. It was bought new by a guy that started working at our local downtown Esso station when he was in high school. He eventually took over the station when the station owner retired. I've had a few guys tell me that they remember the truck being parked at the station, and usually inside if there was room for it. When he passed away (around '08) a family member got it and kept it until our mechanic bought it. So I'm thinking about doing some door art (?) with an Esso logo and the old address and phone number. I don't think I want it to cover a large part of the door though, like most guys have on their doors. Or I may not even put anything on the sides of the truck and just use the corner of the tailgate. Either way, I want to somehow get an Esso logo and the "Thomas Esso Station" name on the truck somewhere but do it more tastefully than the typical door art. Posted via Mobile Device
03-28-2012, 06:18 PM | #200 |
Finally some real progress!!!!
I pulled the column out today after work and started shortening it. Decided to go three inches since that seems to be about as much as you can shorten it, and I don't like being close to the steering wheel when driving. I put about 100 miles on the blue '65 I restored this weekend and the first thing I noticed was how close the steering wheel was. I disassembled it and stripped it to bare metal with a DA to have a clean starting point. Decided where my first cut would be. It would have been easier to move the cut back a little but I wanted to save the "M" in the split of the tube. I blacked out the area with a sharpie and used a sway bar clamp off my VW for an even edge to scribe the cut line. Then measured 3" over and made another scribed line, and cut out the middle. Reassembled on a piece of angle iron to align the two pieces. You can see how the clamps help make an even cut for a tight joint. I also beveled the edges slighly for better penetration. Welded up. And the welds ground down and smoothed with the DA. I cut out the groove where it was welded along the seam with a triangle file so the weld area matches the split along the length of the tube. Nobody will ever see it but that kinda stuff drives me crazy if I know its there.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 03-28-2012 at 06:29 PM. Reason: Add pic |
