Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: 1972 Chevy p/u NewType Build
Posted via Mobile Device you said it had,to do with sweat so I figured you were adding a/c. Dang it ya fooled me
![]() Posted via Mobile Device
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Well shoot bustin a-arms off deals with sweat lmao but hmm idk maybe
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
Well no progress as of right now still haven't ordered my clips either so guess I'm a bum this weekend. On the other hand the 71's running decent. Puffs a lol white smoke in startup and may make you pass out when waiting a long time in a drive-thru but hey she's golden
![]() On a side note graffiti summer is comin up this beginning if June I wanna try and et a big group to come to the car shows such as members from the c/10 club and what not as I see them most. Guess ill need to look around the region section. Posted via Mobile Device
So we've decided to not cut the LCA's and go with a different method. So here goes my father will be oblonging the original pressed hole so that he can fit a race car style threaded sleeve into it about 1/2" inwards giving me the amount I need to move the wheel in and straighten up the tire so there's no alignment issues. Hell then get the arm plated where needed and clean up the edge so that I won't have a rubbing issue. These arms are already gnarred up so its no real lose to do this to them.
Well be using Titan low friction ball joints as well as long as he can find a long enough about to fit through the lower spindle. I won't get many in progress updates but here's a couple idea shots of the work. ![]() ![]() ![]() ![]() Posted via Mobile Device
Also have decided that I will not be swapping my trans out for a different one.. I've come to the realization if something works really well why change it ya know? Going all out on motor though most definitely 350/330 hp 96-2000 motor with the dug thorley mid length pipes I was looking at to add a little shiny to the engine compartment. She'll guzzle some gas for a bit but I think I'll be plenty happy
C/10 junkie
Sounds like fun plans. Curious to see how the ball joints turn out.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#7 | |
Sorry if I missed something, but what is causing your alignment issues in the first place? I have a real bad issue with the driver side wheel leaning in at the top creating wear on the inside tread of the tire therefore causing a pull when driving and a nasty look when showing off the truck. So by moving the lower joint in the bottom scoots in and I can use less than the max amount of shims on the top which is where its at now. Posted via Mobile Device
I used some offset control arm shafts to solve that issue on my chevelle, not sure if they make them for these trucks though. I know they make them for the 73+ model years (moog problem solver).
1968 LWB C20 / AC / Wood Bed |
Those would be great to use but this may be my best solution for now. And yes I noticed that my moog ball joints seemed to have cracked in only under 2 years around the rubber they have. Very disappointed in that
Got in some goodies on Friday and I'm still working on my motor guy to sell me the darn thing, he's crackin finally but darnit gotta seal the deal soon or else I won't make Brothers this year :/
Anyway been working on my steering wheel as of late it just wasn't living up to my standards with the shotty cracking it was getting along with being gummy. So tear down begins I'll post the main stuff in my official thread tmrw for the in-depth stuff and keep the quick progress here. Also going to be ordering up my mid length Doug Thorley headers and Trick Flow steel center to perimeter adapters from summit as soon as the deals made on the motor. Given that maybe we need a sneak peek at what I'm actually getting?? hmm maybe another time ![]()
C/10 junkie
Looks like your making progress. Your down to less than a month to get th motor swapped.
#14 | |
it'll be a direct swap. The new motor already has its own intake, dist, water pump, and flywheel that is I they correspond to what I have now.. So I pull my carb, starter, fuel pump and serpentine pulley system from old motor and slap it to the new one bada-bing bada-boom. Should be do-able in a days work I'd say ![]() Posted via Mobile Device
#15 |
To prevent cracking, you are going to have to find a filler material with the same rate of expansion under varying temperatures as the steering wheel material. If the two materials do not expand and contract at the same rate, they will separate.
#16 | |
#17 |
Alright my arm was twisted
#18 |
did you twist it yourself?
![]() I like your plan. Hopefully it works out that way for you.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#19 |
Haha yes I'm too excited about this darn motor that I just want to go pick it up right now and start tearing into it but with suspension still apart that's hard to accomplish :/
And as do I guess I'll find out tonight how well the epoxy settled shoul be nice and warm after today. Posted via Mobile Device
#20 |
Little update, no work on the steering wheel last night. But I did manage to pick up a ball joint unfortunately it's just a little large for the bottom of my spindle
![]() Would my old ball joints be find to press back in?? Also removed my old power steering box last night. She has a little too much play for my likin and was "catching" a while back so out she goes to be replaced with another that ill be picking up Saturday. Gotta pull the pitman arm what's my best method about this? ![]() Posted via Mobile Device
#21 |
Do you have a gear puller?
#22 |
No but in sure I could rent one from oreillys tonight or tmrw evening
#23 |
![]() Join Date: Jul 2009
You can get a pitman arm puller. There only about $15 and can be used for several other uses.
Posted via Mobile Device |
#24 |
Right I stopped by oreillys last night as its literally down my street and rented one for a couple days. Pulled mine off in about a minutes time. Much quicker than a hammer
![]() I'm driving the 71 to work today then afterwards ill be pullin the box off her as well to get them both turned in for freshly rebuilt ones. 125$ a piece with 30$ rag joint so my front end should be pretty stout by Saturday night. I'm also going to try and repress one old ballpoint back in for now and I found out my driver side one was pretty jacked after the wheel fell off a couple years ago so that ones gettin replaced with a new one. Then I'm slapping the arms back on for time being until I can find the correct style threaded balljoint to put in. Steering wheel is in the pre primer stages as of now I should be havin my dad shoot the first two coats Saturday morning so she looks decent for Sunday's show. That's all for now ill be thrashing till she's drivable Saturday night ![]() Posted via Mobile Device
#25 |
Do yourself a favor and get the box for a 73 and also do the caster mod. It takes about 15 minutes to drill the holes for the mod since you already have the arms off and the 73 box has a better steering ratio, your truck will handle like a sports car. Ask me how I know!
Another 71 My truck In tank fuel pump how to LS factory gauges wiring how to-post 18 |
Tags |
1972 chevy c10, cheyenne super, rebuild, restoration, showtruck |
