Old 02-13-2012, 10:04 PM   #1
64GMCHorsepower
Justified!
Who has side exhaust?
I'm thinking of re-doing my exhaust, and having my exhaust come out in front of the rear tires.
Right now I have mid-length headers, with an x-pipe and 2 Pypes Violator mufflers......and I have it dumping over the rear axles.
Can I keep the x-pipe, or do I need to run just straight pipes, and a smaller muffler to be able to do this?
I have looked at maybe cherry bomb glasspacks or something along that style to try and make it fit.
So any help, what you run now, what you have run would be great!
And pics of course.....
Chad
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 02-14-2012, 08:09 AM   #2
rbar
rbar's Avatar
Re: Who has side exhaust?
My 63 has cherry bombs and dumps out in front of the tires. I don't have an x pipe, but I think it would fit fine. It dumps out quick enough that out may not matter. When I go through a drive through I have to shut it down because all they hear is the exhaust.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 02-14-2012, 09:23 AM   #3
krazy_texan
krazy_texan's Avatar
i guess it depends on what you do with the truck also. I have had trucks that dumped in front of the tires and ya it sounded cool and was plenty loud i wouldnt do it on a daily driver again. if it was just a weekend cruiser then ya. as far as mufflers go keeping the x pipe might limit you on what you can use in a big way especially on a short box depending on how far tucked under the truck you want them. i would go straight pipe myself maybe put an H in it somewhere and go with it.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 02-14-2012, 01:08 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I run 2.5" striaght to 2.5x18" magnaflow resonators (not mufflers), then right out the step.
Its loud, it does drone on the highway, and the position of the tips blows noise and hot air RIGHT into the window of most passenger cars. Perfect.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-14-2012, 01:34 PM   #5
Apache63
1# Drobmember in Germany
Apache63's Avatar
Here is mine ........with 2,5" and Flowmaster Series 44 Muffler , no X-pipe
Pat
Apache63 is offline   Reply With Quote
Old 02-14-2012, 02:02 PM   #6
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Here is what I have on both side. Cherry Bombs into these 4" X 24" tips. It sounds awesome!!
Here is the other side.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-14-2012, 03:41 PM   #7
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
I plan on using a rectangle exit but do not have them made at this point. I think Borla or mega flow has a few system that you could get some ideas from
GMR-PERFORMANCE is offline   Reply With Quote
Old 02-14-2012, 04:18 PM   #8
61_FL_Apache
Who Me?
Look into the Gen 4 Camaro tips. They are the shape your looking for.
Steve
2001 Blazer 4D 2WD
Old 02-14-2012, 05:29 PM   #9
forestb
forestb's Avatar
Are your mufflers in between or on the outside of your frame rails and if they are in between how do you get around your truck arms in the rear? I have a 62 and it seems like the only way for me to run my exhaust in front of the tire is to put the mufflers under the doors. But I am worried that that will cause two much noise inside the cab.
forestb is offline   Reply With Quote
Old 02-14-2012, 05:55 PM   #10
T Smith
T Smith's Avatar
I keep thinking about these under the bed steps...
http://www.jegs.com/i/JEGS-Performan...ductId=1353766
T Smith is offline   Reply With Quote
Old 02-14-2012, 06:04 PM   #11
GMR-PERFORMANCE
those are cool.
Old 02-14-2012, 06:55 PM   #12
theastronaut
theastronaut's Avatar
I'm planning for 3" side exit exhaust for my '66. Will be running it through the crossmember and frame for more ground clearance. I won't have room for over-the-axle pipes with the frame bracing that will eventually be welded in.
theastronaut is offline   Reply With Quote
Old 02-14-2012, 06:57 PM   #13
64GMCHorsepower
Justified!
Thanks guys, I'm not going to use this as a daily driver, so dumping in front of the tires is not a big deal for me.
I thought about trying to find some dual exhaust tips to put on it, I have seen a truck somewhere with that and it looked pretty cool.
Right now my exhaust is inside the frame rails also, so I might have to move it to outside to do this....
Chad
Old 02-14-2012, 08:11 PM   #14
vin63
It's Better With Nitro
vin63's Avatar
Three-inch exhaust to the outside of the frame, turn-outs in front of the rear tires...muffler mounted behind the cab. The exhaust is positioned above the bottom of the frame rails behind the front shocks...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-14-2012, 08:28 PM   #15
RockTonka
RockTonka's Avatar
2.5" Magna flows w/ 2.5" tubing in and out...
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 02-14-2012, 08:57 PM   #16
62 short step
62 short step's Avatar
Any drone in the cab with this set up?
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 02-14-2012, 10:37 PM   #17
Slow Build
Slow Build's Avatar
That looks like a pretty big hole you will be making in your frame rails. I think the outside the frame route would be easier and safer.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 02-14-2012, 11:35 PM   #18
MOTOIMPAIRED
MOTOIMPAIRED's Avatar
I was thinking the same thing..
MOTOIMPAIRED is offline   Reply With Quote
Old 02-14-2012, 11:49 PM   #19
theastronaut
The frame rail and crossmember will be boxed and also peice of thick wall 4" tubing welded in for the exhaust to pass through to strengthen the area. I've seen a couple other trucks with thru/frame exhaust, one of them being the Hotchkis C10.
Old 02-15-2012, 01:02 AM   #20
RockTonka
RockTonka's Avatar
Yea, a little. The V6 has a unique sound though and we don't find it all that unpleasant.
My build thread
Old 02-15-2012, 03:02 AM   #21
willyp
willyp's Avatar
dumps forward of the rear tire.
The price of cool aint cheap.
willyp is offline   Reply With Quote
Old 02-15-2012, 11:06 AM   #22
61_FL_Apache
Who Me?
Mine comes to an X near the end of the tranny then goes out at almost 45* angle infront of the rear tires. The mufflers are after the X and inside the frame. I dont have a true X pipe, but they are side by side there.
Steve
2001 Blazer 4D 2WD
Old 02-15-2012, 11:31 PM   #23
shortbed70
shortbed70's Avatar
This is how I did mine. I'm gonna weld some plates
On the inside just to strengthen it more. I am a certified welder so I'm not worried about mine not being strong enough.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 03-09-2012, 10:38 PM   #24
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Very cool solution. Looks nice!!
Alan's Classic is offline   Reply With Quote
Old 03-09-2012, 11:07 PM   #25
RockTonka
RockTonka's Avatar
We just did a burb the same way (2 1/4" in and out of Magnaflows)...good sound, good clearance, above the frame rails for the most part.
My build thread
